Pressure washer for apartment life?
Discussion in 'Detailing' started by WZ00R2, Aug 8, 2018.
  1. Aug 8, 2018 at 9:01 AM
    WZ00R2
    WZ00R2 [OP] Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    My apartment complex does not have any outdoor faucet connections. Currently, I take all my washing equipment to the quarter car wash in town when my Tacoma needs a bath to use their pressure washers. Are there any options for utilizing a pressure washer when outdoor water connections are not available?
  2. Aug 8, 2018 at 9:27 AM
    Stephen_m64
    Stephen_m64 Well-Known Member
    NorCal
    '18 Taco TRD OR ACLB
    Other then a pressure washer with a integrated water tank to fill i don't know of any other options, for those imprisoned within restrictive apartment complexes.
    Depending on the severity of the dirt you can look into using "waterless wash" and a whole bunch of plush microfiber cloths.
  3. Aug 8, 2018 at 9:40 AM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    Not sure how far you are from a sink?
    But I have used a sink to hose adapter and run my pressure washer off that.
    Not great for pressure washer but works.
    Got mine on ebay for just few bucks.
    Make sure to get metal.
  4. Aug 8, 2018 at 9:42 AM
    WZ00R2
    TN
    2020 Cement OR
    I've considered that but I wasn't sure if a standard kitchen sink would have enough flow to use with a pressure washer.
  5. Aug 8, 2018 at 9:51 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Tell a buddy you’ll give him a case of beer if he lets you use his driveway and hose??
    Gunshot-6A likes this.
  6. Aug 8, 2018 at 9:53 AM
    Stephen_m64
    NorCal
    if your apartments don't have outdoor faucets, getting around that fact by using a sink adapter may be against their rules.
    CusterFan likes this.
  7. Aug 8, 2018 at 9:54 AM
    JDMjeremy
    JDMjeremy Well-Known Member
    Jeremy
    Las Vegas
    12 TRD OR
    I would talk to management about this prior to you going through the hassle of trying to make it work. I live in apartments at the moment as well, and I do have a faucet right out front my door. I asked if I could run my washer a couple times a month and was given a firm no. "Trying to keep the water costs down". Lame.
  8. Aug 8, 2018 at 9:56 AM
    WZ00R2
    TN
    2020 Cement OR
    My water usage is for my single unit. I have a typical water usage bill every month so that's not an issue.
  9. Aug 8, 2018 at 10:04 AM
    Admiral_Akbar
    Admiral_Akbar Well-Known Member
    '17
    Have you looked into the Worx Hydroshot? The pressure washer is battery operated. I believe if you can’t connect to a garden hose, you can use a bucket of water instead.
  10. Aug 8, 2018 at 10:08 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    If you had a large enough container and a submersible pump you could run it off that but seems problematic for you. Say a plastic 55 gal drum or even a 20 gal. But youd need a way to transport and fill. Just a thought but not a very good one...
  11. Aug 8, 2018 at 10:09 AM
    ChemDawg
    Maine
    2005 sr5 4x4
    It has work well for me many times.
    I have a black max 2800psi.
    I have pressure washed a bunch of decks and my own truck using the sink adapter.
    Works fine for me.
    Like I said it may not be what's best for the pressure washer but it only cost me $250 and I made that $ back on my first few jobs:thumbsup:
  12. Aug 8, 2018 at 10:11 AM
    ChemDawg
    Maine
    2005 sr5 4x4
    The flex hoses work well in the sink..if you leave a small bit of hose in sink.
    The reg hose a small amount of water runs down hose onto floor. Over time builds up
  13. Aug 8, 2018 at 1:10 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I live in a apartment and cannot use the garden hose. I just go to the local carwash early in the morning, like at daybreak. I can hand wash, rinse, and even wax without having to move for someone wanting to wash their car. I just take a bucket of soapy water along with what I need to get the job done. I do miss having access to a garden hose though.
  14. Aug 8, 2018 at 1:11 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I too love in a apartment.
    Waterless wash and spray wax is your friend.
  15. Aug 8, 2018 at 7:05 PM
    CusterFan
    ....and help him drink the beer. ;)
    Ensemble88 likes this.
  16. Aug 14, 2018 at 11:43 PM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    Rinseless wash like Optimum No Rinse or Quick n East Wash using two buckets would be a good solution for you.
