Pressure washer issue
Discussion in 'Off-Topic Discussion' started by SCFirefighter, Jun 23, 2010.
  1. Jun 23, 2010 at 9:22 AM
    SCFirefighter
    SCFirefighter [OP] on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    My pressure washer won't work properly. I need to choke it to start it, that's fine. However, when I push the choke pin back in (even when done vewwie vewwie slowly) the engine will die.
    It runs with the choke out, but it doesn't seem to generate as much pressure as it should, and the engine of course doesn't sound right. Not sure if running it like this actually damages the engine.Why can't I undo the choke? Any small engine experts here?
    I cleaned my entire truck that way, and even after that the choke pin will kill the engine. So it's not that the engine is still cold ..
    --- FIXED: carburetor needed cleaning. As suggested it was all gummed up. Thanks everyone!
  2. Jun 23, 2010 at 9:24 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    When was the last time you ran it and it worked right?? When is the last time before today that you ran in at all??
  3. Jun 23, 2010 at 9:28 AM
    stick114
    stick114 Active Member
    Hot Springs, Arkansas
    TRD SPORT
    Try a new spark plug and clean or replace the air filter. Not an expert but my lawnmower does the same thing.
  4. Jun 23, 2010 at 9:29 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Does it take a mix of fuel/oil? If so maybe it's a bad mixture or possibly just old fuel from last year?
  5. Jun 23, 2010 at 9:29 AM
    SCFirefighter
    Stephan
    Cary, NC
    ... it's been a while. Last season?
  6. Jun 23, 2010 at 9:30 AM
    SCFirefighter
    Stephan
    Cary, NC
    It takes pure gasoline. I'm sure it's from last year. Would that make a difference with the choke/no-choke? (No mechanic here).
  7. Jun 23, 2010 at 9:31 AM
    SCFirefighter
    Stephan
    Cary, NC
    Air filter is clean; I checked it. Didn't think about the spark plug. Will look into it.
  8. Jun 23, 2010 at 9:33 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    I've always heard if you have gas for a long time the effectiveness goes down. Not sure why but I've heard don't keep gas more than about 6 months.
  9. Jun 23, 2010 at 9:35 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Ditto on the bad gas or maybe even varnish in the carb. You can try to clean it yourself or get a small engine mech to tune it up for you.
    STABIL or some seafoam might help....but I'm not positive...
  10. Jun 23, 2010 at 9:37 AM
    SCFirefighter
    Stephan
    Cary, NC
    Where can I guy the fuel stabilizer?
  11. Jun 23, 2010 at 9:38 AM
    SCFirefighter
    Stephan
    Cary, NC
    This is separate from the fuel stabilizer right?
  12. Jun 23, 2010 at 9:40 AM
    98tacoma27
    Ben
    Not Beech Creek
    Any parts store or even Walmart.
  13. Jun 23, 2010 at 9:42 AM
    SCFirefighter
    Stephan
    Cary, NC
    Having never taken anything apart before, is this something I could do by myself just by trying? (lol) I'm good with puzzles! :)
    How much with it take to have someone take it apart and clean it? $40? $80 $150?
  14. Jun 23, 2010 at 9:43 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    after you clean it, drain the existing fuel and fill it up with premeum gass. lots of two stroke engines can't run (or run poorly) with the ethenol that is put into the low/mid grads gassoline. our lawn mower was doing the same exact thing as your pressure washer, and premeum seems to do the trick
  15. Jun 23, 2010 at 9:44 AM
    huntinggunns
    huntinggunns Lifes a garden, dig it.
    Fred
    Oklahoma
    2014 MGM SR5 DC SB TSS 4x4
    In progress
    If you leave fuel in a carburetor for too long the waxes in the fuel will separate and turn to gum. More than likely the main jet is plugged. The main jet comes straight out of the float bowl up into the venturi. If it is plugged (the holes in the main jet are very small), the vaccuum from the engine can not draw fuel through the main. With the choke pulled you are giving the engine just enough fuel to run but not enough to run properly as the choke just enriches the fuel/air mixture for cold starts. I would pull the carb and take off the float bowl. You will see the main jet at that point. Clean the main, re-assemble, and you should be good to go.:D:D
    Fred.
  16. Jun 23, 2010 at 10:03 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Yeah what you need to do is take the carb off, and remove the varnish residue, and since it only runs with the choke on most likely the pilot jet is clogged, but also check the main jet. Get some good carb cleaner from the depot and a tooth brush, but be carful of the throttle cable and the float valve.
  17. Jun 23, 2010 at 10:17 AM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    I had this problem too. I found some tutorial to take part of the engine apart and cleaned off the o-rings and it started running better again but it still had the same problem a little bit but not as much. I cant remember where I found the tutorial though
  18. Jun 23, 2010 at 10:47 AM
    SCFirefighter
    Stephan
    Cary, NC
    Thanks everyone. I think I got myself another weekend project lol
  19. Jun 23, 2010 at 1:19 PM
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    x2. i usually change the spark plug and the air filter. Home depot or lowes usually has a tune up kit for small engines.
  20. Jun 23, 2010 at 1:22 PM
    mntbiker2008
    Aaron
    Cincinnati, OH
    yeh. gas turns "gummy" even after a few weeks of sitting. (learned this when i had a motorcycle) the gas could be bad. drain the gas and put fresh gas in there.
    if it has a carb, seafoam should work.
