Pressure Washer recommendations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wcartee, Apr 7, 2019.
  1. Apr 7, 2019 at 6:55 PM
    wcartee
    wcartee [OP] Well-Known Member
    Billy
    Seattle, WA
    2021 Toyota Tacoma TRD Offroad 4x4 AC
    Wondering what everyone is running for pressure washers? Thanks.
  2. Apr 7, 2019 at 7:50 PM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    My recommendation is to never use a pressure washer on anything that you want to keep looking good. It's so easy to mess up the paint. You asked. :anonymous:
    GillyLink and SurfratTX like this.
  3. Apr 7, 2019 at 7:51 PM
    edjukappy
    edjukappy Well-Known Member
    Pennsylvania
    2019 TRD Sport 1k - 2008 SR5 185k - 1998 SR 192k
    Ryobi electric 1700psi 1.2gpm... have for 2 years works good for $150... had a few Karchers that worked great, when they worked.
    Rockoma5 and JS760 like this.
  4. Apr 7, 2019 at 7:51 PM
    Shellshock
    Iowa
  5. Apr 7, 2019 at 7:52 PM
    Shellshock
    Iowa
    Good thing my paint is already messed up from actually using my truck :anonymous:
    71tattooguy likes this.
  6. Apr 7, 2019 at 7:53 PM
    Burro09
    Burro09 Well-Known Member
    Miami, FL
    2017 Tacoma TRD Pro Cement MT
    As long as you use common sense and dont literally put the nozzle on the paint, there is no problem with pressure washers.
    I use one sold at costco. Powerstroke 1800 psi i believe. Works excellent and i can return it indefinitely when it does break. And they dont last forever.
    Works great with w foam cannon and on the underbody and wheel wells.
  7. Apr 7, 2019 at 7:56 PM
    edjukappy
    Pennsylvania
    Yeah great with a foam cannon... use the nozzle recommended for car washing, not the one for cleaning cement.B7468A3C-7B78-431D-883C-974EAD44D55B.jpg
  8. Apr 7, 2019 at 7:57 PM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Gonna end up getting a Stihl with a brigs engine. Good price excellent parts and customer support.
  9. Apr 7, 2019 at 8:00 PM
    SA4runner
    SA4runner Well-Known Member
    Jesse
    2018 Cement DCSB OR 4x4
  10. Apr 7, 2019 at 8:03 PM
    Gixerkiller
    Dennis
    Taylor, TX
    jsinnard and AR15xAR10 like this.
  11. Apr 7, 2019 at 8:06 PM
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    That’s the one I bought specifically for car washing as the psi is not crazy. Does light duty house clean up too. Cleaning sidewalks and cement would definitely need something better, but it will do in a pinch
  12. Apr 7, 2019 at 8:06 PM
    Bishop84
    Bishop84 Well-Known Member
    Electric is fine and you won't overdo it on the paint. I worry about the higher pressure ones with the wrong nozzles damaging paint. My old house has some damaged brick and painted 2x10's with my name written on them haha.
  13. Apr 7, 2019 at 8:09 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
  14. Apr 7, 2019 at 8:13 PM
    sfr4dr
    sfr4dr Well-Known Member
    Truckee/Tahoe CA
    Currently trying to pick my next Toyota!
    I can say that electric can be nice if you aren't using it very often since there's no need to drain the gas when you're done but if you're washing more often or need it for larger home projects, gas is better for power and longevity. I sprung for a Goodyear hose and high quality quick connects too. We use ours quite a bit once a year to prep our wood log siding and decks for stain.
    Dominic4Lo and shakerhood like this.
  15. Apr 7, 2019 at 8:25 PM
    whoispurplegoo
    whoispurplegoo Well-Known Member
    SE Florida
    2018 MGM Sport 4x4 DCSB
    i'm using a greenworks 1950 psi, 1.2 gpm (model GPW 1953). it was $140 through the greenworks website (i believe it's last year's model).
    i was initially hesitant about getting an electric pressure washer, but since it was only going to be used for washing cars, i didn't want to deal with gasoline. At $140, i don't care if it quits in 2 years.
    only complaint is that i wish the flow rate was higher.
    if you're curious, obsessed garage did a pretty thorough evaluation on youtube of almost every electric power washer available on Amazon.
    AR15xAR10 likes this.
  16. Apr 7, 2019 at 8:30 PM
    TacoMateo
    TacoMateo Well-Known Member
    Nor Cal
    2019 DBLB TRDOR CEMENT
    But what if your truck is cement color? :crapstorm:
    jenot, pinochle and AR15xAR10 like this.
  17. Apr 7, 2019 at 8:33 PM
    AR15xAR10
    Exactly, mine has an adjustable head. 15°, 40°, 800psi, and two soap functions if you want to use the built in soap tank (i never have)
    Most foam cannons only produce 200psi or less. So they can’t really damage anything...if anyone was curious and didn’t know. :) @Tullie D
    Dominic4Lo likes this.
  18. Apr 7, 2019 at 8:39 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  19. Apr 7, 2019 at 8:49 PM
    whoispurplegoo
    SE Florida
  20. Apr 7, 2019 at 9:14 PM
    SA4runner
    Jesse
    I don't know what this means.
