Pressure washer
Discussion in 'Product Reviews' started by BigT, Jun 20, 2009.
  1. Jun 20, 2009 at 1:08 PM
    BigT
    BigT [OP] Active Member
    Pa.
    16 trd off road
    Can anyone recommend a good pressure washer, (prefer an electric)?
    My brother in law has a small Karcher he bought on QVC a few years ago, seems happy with it. I want one to clean the vinyl siding, lawn chairs,etc., so I don't want to spend a small fortune, but want something that will be reliable and do the job.:confused:
  2. Jun 20, 2009 at 2:50 PM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    i dunno about electric but anything with a honda engine is good...i think they sell them at lowe's under the troy built name
  3. Jun 20, 2009 at 3:08 PM
    thebigk
    thebigk 6 Double 5 3 2 1
    Ken....
    Odessa, TX
    I had an electric & it lasted 1 whole summer.
    I bought a gas one.....I think it's a BRUTE.....has a Briggs & Stratton 2500psi bought it at WalMart.
    Starts first pull every time
    EDIT:
    It's this one
  4. Jun 20, 2009 at 3:21 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    We have a gasser...
    A Cambell Hausfield. We've had it for many years.
    If you want the exact specs, let me know - I'll run outside and get the model number.
    We did have to replace a brass fitting on the main outlet. That's only because for many years of this thing sitting in the shed over the winters with no maintenance done to it.... :eek: The cold/water eventually cracked a brass fitting. Easy fix.... and it's still kicking. I"m actually surprised its been lasting this long.
  5. Jun 20, 2009 at 7:05 PM
    BigT
    Pa.
    16 trd off road
    What type of winter maintenance is needed? Which is better, horizontal or vertical shaft?
  6. Jun 20, 2009 at 7:38 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I bought an electric Karchar at Lowes for $100. I tried using it to clean my concrete patio but it was not very strong. It stopped working before I finished a 2 hour job. I returned it and bought a Troy-Built with the Honda engine at Lowes for $300.
    http://www.lowes.com/lowes/lkn?action=productDetail&productId=289035-348-20344&lpage=none
    I did a lot of research before purchasing this. I read a lot of poor reviews of the Briggs and Stratton engines (sucking oil). I never thought I would use the power washer as much as I do (siding, vehicles, concrete driveway / patios, decks, rugs, gutters, furniture and much more). If you can do it, you won't regret it.
    Very easy to maintain too. No mixing of gas and the oil needs drained and filled once a year (easy to do).
  7. Jun 20, 2009 at 11:49 PM
    kilgoja
    Alabama
    :mudding:
    yeah that's the one i got...lol
  8. Jun 21, 2009 at 2:03 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Mines from Honda, works all the time, everytime. That thing is a tank, and is used frequently as I own multiple properties.
    I would definitely recommend it because I've had two cheap ones that crapped out on me, so I said to hell with it and spent a 100$ more, and I've had this pressure washer for almost four years now with NO problems.
  9. Jun 21, 2009 at 3:21 AM
    Janster
    Jandy
    Lancaster, PA
    I think the most critical thing if you live in cold weather climates - is putting an antifreeze solution in the pump to prevent the water from freezing / expanding and ruining the pump.
    You can buy little cans of antifreeze with a special tube that should thread onto the pump - like this
    http://www.ultimatewasher.com/images/accessories/anti-free-action-big.jpg
  10. Jun 21, 2009 at 7:45 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    windsheild washer fluid works just as well as anything and is cheap. you need a short piece af garden hose and fitting to attach to washer. put the hose end in a gollon of washer fluid, turn on washer to advance the fluid throughout the pump...done.
    few powerwasher tips...
    try to get one that has a separate unloader valve, so that it can be repalced down the raod. a lot of the less expensive one's have this valve attached to the pump, so you have to replace the entire assembly if the unloader valve goes bad. (the unloader valve is what takes the "shock" of letting off the trigger)
    also, a unit with a hose with standard 3/8 pipe fittings will allow you to buy a quality hose to replace the factory one when you burn it on the exhast (seen this a bunch of times) or it gets a hole in it. most of the cost effective units come with a POS hose & wand and have a goofy threaded fitting that can be tough to find.
    make sure there is a valve & packing rebuild kit available for the model you choose. buy the kit when you get the washer, then put it somewhere you won't forget about....you will need it eventually.
    gallons per minute is more important than PSI. you want the most GPM you can get. 3.0 GPM at 2000 psi will anihilate a 1.5 GPM at 3000psi.
    do not pulse the trigger on the wand, (rapid depressing & releasing of the trigger) this will wear out the packing in the pump. look for a wond with quick change tips instead of an adjustable tip.
    don't run the unit at full speed if you have a gasoline engine. it (the engine) will last much longer if you set the throttle at about 75%.
    eventually, i will get a unit like this for myself...but have not had the funds available. (plus a buddy has a good one that is up for borrowing when i need it)
    LOWER RPM Means Higher Pump Life Expectancy and Less Heat Exchange
    Order Online or Call Toll Free 866-858-4982, 24 hrs. a day ​
    Belt Drive - Gas Powered Unit​
    Gas Powered Unit
    Model: PP-SSEB4040HC with CAT Pump
    Standard Features:
    • <LI class=justify>4,000 PSI at 4.0 GPM <LI class=justify>13 HP Honda Engine - GX390 (2 year warranty) <LI class=justify>Industrial Cat Pump (5 year warranty) <LI class=justify>16,000 Cleaning Units <LI class=justify>Chemical Injector Kit <LI class=justify>Oil Alert (low oil shutdown) <LI class=justify>EZ Start Adjustable Unloader <LI class=justify>50 FT High Pressure Hose <LI class=justify>4 Quick-Connect Spray Tips <LI class=justify>36" Insulated Lance <LI class=justify>4,000 PSI Trigger Gun <LI class=justify>10" Tubed pneumatic tires <LI class=justify>Stainless Steel Frame <LI class=justify>Belt Drive
    • Weight: 200 lbs
    one more thing...if you don't want to spend the cash, you can rent a good one at an equipment rental store for probably less than $50 a day. they can be found at the same places that rent skid steers, mini excavators, etc.
  11. Jun 21, 2009 at 11:19 AM
    BigT
    Pa.
    16 trd off road
    Thanks for all the info, I believe I will end up buying a gas powered with a Honda engine, already had a bad experience with B&S engine on a Craftsman riding mower. Now the fun begins, a quality unit to fit my budget!
  12. Aug 16, 2011 at 1:27 PM
    Manwithoutaplan
    ID
    i know this bring back a old topic but, What is good amount of pressure forlike cleaning atvs/dirtbikes and my truck from long day of off roading in themud???
  13. Aug 16, 2011 at 2:17 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Any entry level gas powered pressure washer will do. I would get something which puts out around 2000-2500psi.
  14. Aug 16, 2011 at 2:49 PM
    Manwithoutaplan
    ID
    ok cool thx. any recommend brands ???
  15. Aug 16, 2011 at 3:18 PM
    RCBS
    gallons per minute. Get something at least 3gpm. Look for a Honda 9hp engine. BTW, Honda does not make powerwashers, just engines. Pay close attention to the pump itself. Bigger pump head (shiny brass part) = better. The pump manufacturers I would recommend: General Pump, AR pump, Comet, or if you're loaded with cash CAT pump.
    I know you can go to lowes and buy something for $250 that may do the job, but for how long? Look at a washer as a tool...better to invest a little more up front than to have it fail when most needed. Gear reduction and belt drive models much> direct drive (pump bolted directly to engine). Steer clear of undermounted and round shaped pumps. Again, look for a quality wand/hose setup. If it has a pastic knob on either end of the hose, it cannot be repaired, only replaced. Good hoses will have steel in them and can easily be repaired at a truck shop or hydraulic shop for $20.
    I'm not talking out my ass here either. I work on powerwashers almost daily. Our shop won't even look at the cheapos because repairs cost as much as the entire unit can be bought new for. Try Craigslist for a good used unit that won't break the bank if you don't have a lot to spend.
    Almost forgot...be sure to winterize the pump if you live in a cold climate. Also, if a small engine is going to be stored for more than 2 months don't turn it off with the ignition switch. Turn off the gas and let the engine purge the carburetor till it dies. This will ensure you don't have a bunch of black Goo in the carburetor when you next want to use the machine.
  16. Aug 16, 2011 at 3:20 PM
    Manwithoutaplan
    ID
    ok cool thxs for the info.
  17. Aug 16, 2011 at 3:25 PM
    Manwithoutaplan
    ID
  18. Aug 16, 2011 at 3:26 PM
    RCBS
    No problem. If you find something you're interested in, post it up and ill do my best to critique it for you.
