Pressure Washers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by YotaTRD, May 26, 2018.
  1. May 26, 2018 at 7:14 AM
    YotaTRD
    YotaTRD [OP] Well-Known Member
    Michael
    2018 MGM Tacoma TRD Off road DCSB
    Tacoma bed mat RokBlokz mud flaps Baja Designs Squadron Sport WC fog lights 2nd Gen running boards
    What is the best pressure washer to use when washing your truck? Please and thank you.
  2. May 26, 2018 at 7:15 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    A garden hose. Pressure washers will damage the paint, especially if used incorrectly
    Skyllr, GR8APE and Joe23 like this.
  3. May 26, 2018 at 7:20 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    One under 2500psi and only with the two lower pressure orifice ones
  4. May 26, 2018 at 7:26 AM
    TacomaBlu
    TacomaBlu Well-Known Member
    2017 TRD Sport
    6in Procomp 35in Toyo M/T 18x9 Mamba M13
    Been using one for 6+ years. Electric 1800psi, can't remember the brand. Works perfect. By the time I'm done rinsing before hand wash the dirt is mostly gone.
    Highly recommend getting one.
    DubfromGA, Heepspo and YotaTRD[OP] like this.
  5. May 26, 2018 at 7:35 AM
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    I have Benn using my 3200psi wit 40 degree for 2 years no issues at all. Now don't go put is 2 inches away from the paint keep couple of feet and u should be good.
    YotaTRD[OP] and 2016Tacoman like this.
  6. May 26, 2018 at 7:45 AM
    V4VADER
    V4VADER Active Member
    VA
    2018 Cement TRD OR
    I’ve been using a 2000 psi sunjoe electric one that has been getting the job done well.
  7. May 26, 2018 at 8:10 AM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    I see no issue if you use an electric one with lower psi, especially when coupled with a soap gun.
    I'd never touch my truck with my bigger pressure washer though... 13hp 4,000 psi 3.5gpm. Would blow through paint, metal, tires, etc.
    DubfromGA and YotaTRD[OP] like this.
  8. May 26, 2018 at 9:15 AM
    Vitalzone
    Vitalzone Well-Known Member
    Arizona
    2016 TRD OR 4x4 DCSB 6 spd manual
    -ADS coil overs with RR, and compression adjusters -ADS triple bypass rear shocks -Mcm UCAs -Deaver U402 stage 1 leaf packs -ADS bumps in the rear with Icon U bolt flip striker plates -Relentless Offroad U bolts -Wheeler superbumps in front -SCS 17" Ray 10s -285/75/17 BFG KM2s -Nitro 5.29 gears -Pelfteybilt armor front to back with HC rear bumper. T- case skid cut to fit Spec U exhaust. -RCI diff skid -Avid bed bars with basket holding spare. Poison Spyder 3-way strap. Hi-lift jack,and shovel mounted to basket. - SDHQ ditch light brackets with BD Squadron Pro spots. -BD Squadron Pro wide cornering in F. bumper. -BD S8 30" bar in F. bumper -Smittybilt 10k X20 winch -Factor 55 fairlead, and prolink -Switch pro 9100, with custom machined aluminum switch bezel. -BAMF grille insert -URD short throw shifter -URD Spec U exhaust cut over axle. Exhaust looks like it was fabricated by a blind child. -Suntek carbon XP 18% tint all around -ARB single compressor, mounted on Slee bracket. Lines to front, and rear bumper. -Rear diff breather mod,ran to bed cubby. -Ovtune 1.05 FOB 91 -Sprint-booster -Clutch accumalator delete mod -Hella Sharptone horns -Crown +4” extended brake lines, with modified factory brackets to fit lines. -Hypertech speedo calibrator -Custom pinstripes, and trail rash done by the beautiful AZ desert.
    I use a 2800 psi Ryobi with Honda engine , mated with a Simple Chuck dual canister deionizer. Works awesome no paint damage, and I get close with the nozzle. Simple Chuck is expensive at $400, but it works great eliminating spots from the terrible hard water here in AZ.
  9. May 26, 2018 at 10:39 AM
    SigSense
    SigSense Well-Known Member
    13 TRD Sport DCLB 4X4
  10. May 26, 2018 at 11:48 AM
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    Any electric pressure washer is fine. Gas is fine as well plenty of people use them in the detail industry.
    IMO gas is overkill and paying for gas is a huge downfall as prices are increasing.
    I’m assuming you want a pressure washer for a foam cannon?
    YotaTRD[OP] likes this.
  11. May 26, 2018 at 12:26 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Have a gas powered for house and got me an electric one on Amazon for cars. Then i got a pistal grip and got rid of that long arm that comes with it. Works awesome and especially with a foam cannon.
  12. May 26, 2018 at 6:10 PM
    YotaTRD
    Michael
    Yes, I am wanting to get a foam cannon.
    DubfromGA and oscolivar1[QUOTED] like this.
  13. May 26, 2018 at 6:38 PM
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    Figured. If it’s electric, make sure it’s a cannon built for the lower psi.
    Tip don’t fall for the expensive foam cannons. AFAIK and YouTube the Amazon cheaper models do just fine. There’s modification to a foam cannon you can do it costs like 8-12 bucks if you research it to produce crazy foam/suds.
    I have the chemical guys for the electric and does a damn good job buts it’s expensive (didn’t know at the time). All the foam cannons are the same just priced up for the name of the company.
    That being said....don’t fall for the gimmick of “omg it’s produces an extreme amount of foam and sits on your paint for 10-15min” I don’t believe anymore of the idea that the soap somehow lift up dirt...its there for lubrication to pick up dirt from a wash mitt without scratching your paint.
    As long as it sits on your paint for a couple of mins it’s fine...You can just powerwash with just water and get the bulk of the dirt off and achieve the same results. Just my opinion though.
    If you wanna save money but an aerator. That’s what I did. More efficient and cost effective. It gets old putting together the powerwash and foam cannon.
    https://www.theragcompany.com/ik-foam-1-5-sprayer-35oz/
    YotaTRD[QUOTED][OP] likes this.
  14. May 26, 2018 at 6:40 PM
    Techsan
    Techsan Well-Known Member
    South Texas
    2017 BBPDC
    This.
    Paid $129 on Amazon. Looks like the price point moves but you can still get it for about that. Works perfectly.
  15. May 26, 2018 at 6:48 PM
    Deathray
    Deathray Are we there yet? ...Are we there yet?
    Jeff
    Central Illinois
    2021 Mazda3 AWD Hatchback
    I have a Karcher Follow Me 1800psi electric. Love it for washing the truck!
    It has four wheels, with two of them on casters, so you just pull it behind you.
    ...and it kind of looks like a moon rover, so that’s cool LOL
  16. Jun 2, 2018 at 7:11 PM
    MillCreek
    MillCreek Well-Known Member
    Snohomish County, Washington USA
    2016 TRD Sport 4x4 DCSB AT
    I took Oscolivar1's advice and bought a Chapin foam aerator for $ 40 off of Amazon. I bought a gallon of inexpensive Zip Wax car wash from WalMart, filled up the aerator, set the dilution ratio to '3' and went to town washing both cars. This worked really well: lot of thick suds on the cars, I washed with the microfiber sponge, and then I disconnected the hose nozzle via the quick-release on the aerator to rinse. Much, much easier than dragging out the SunJoe electric pressure washer, getting everything hooked up, and using the foam cannon.
    https://www.amazon.com/gp/product/B07BJFDQTL/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
    Alder932 and oscolivar1 like this.
  17. Jun 2, 2018 at 7:21 PM
    no vtec 4me
    no vtec 4me Well-Known Member
    Kevin
    West Chester, Pa
    2017 Tacoma TRD Sport
    I just picked up a ryobi 2000psi electric power washer from Home Depot for $179. It’s perfect for washing the truck and using a foam cannon I wouldn’t even consider a gas one.
    JS760 likes this.
  18. Jun 2, 2018 at 7:36 PM
    necrodiety
    necrodiety Well-Known Member
    Orlando
    2018 Silver TRD Sport
    OV Tune, Bakflip F1, Redline hood struts, faux pro headlights and tails, Meso: bucket, map and dome lights, fuse cover.
    I have been using something similar for the last 11 years on my 07 taco and everyone thought my paint looked brand new when I traded it in a few weeks back. It works well.
  19. Jun 3, 2018 at 10:46 AM
    '16goingon'17
    '16goingon'17 Well-Known Member
    Trailslayer
    NoVA by way of NWA
    2017 TRDOR 4x4 DCSB MT
    JBA STD UCAs. 6112/5160 @6/5. Wheelers 1.5" 3AAL with Superbumps. BROG molle headrest covers. GMRS & Ham radios with roof-mounted NMO Laird Phantom antenna. Thinkware front/rear dashcams, FreshMexicanTaco's DMM, Meso's dome/map LEDs & Flipfob, Swingcase on driver side. Accumulator Delete Mod (ADM). Two-wheel drive Low Range Mod (2LM). Overland Tailor Tune (OTT) 7.0. Extra juicy oil spill on the bed mat.
    Definitely do NOT get a Karcher K2 Ergo. I am baffled by how poorly designed all the fittings are and how much it leaks. I wish I could return it but I started using it past the deadline on Amazon.
  20. Jun 3, 2018 at 12:47 PM
    MillCreek
    I had a couple of Karchers (gas and electric) over the years. The proprietary hoses/wands/accessories were a pain in the rear end. They were expensive and difficult to locate. When I gave away the last Karcher and went with the SunJoe electric, using standard connectors, hoses, wands and accessories was a paramount consideration for me. It is much easier dropping by the local Lowe's/Home Depot/Farm and Fleet to pick up a connector, brush or the like.
