Prestone coolant
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldentaco03, May 22, 2016.
  1. May 22, 2016 at 10:06 AM
    goldentaco03
    goldentaco03 [OP] Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    I flushed my radiator and got almost all the Toyota red out. Still a very light tint after 5 flushes. I added Prestone 50/50 universal. Is this okay?
  2. May 22, 2016 at 10:18 AM
    Clearwater Bill
    Billy
    Largo Florida
    Why ask after it's done?
    What does Prestones web site say about using it as a replacement for OE products?
  3. May 22, 2016 at 10:21 AM
    STOCKTRD
    STOCKTRD Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Nachos, Lemon Heads, My Truck Is Stock!
  4. May 22, 2016 at 10:23 AM
    goldentaco03
    Liam
    NJ
    Just wondering cause I was unable to get all the red out. I'll check the Prestone website but the bottle insists its good for all types of cars. However I have seen the speculation over this online but I thought it was mainly that it can't be mixed or used to top off Toyota red.
  5. May 22, 2016 at 5:48 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I don't see any problem with it. I run the universal stuff in all my vehicles, no problems at all. I don't see the point in paying $30 per gallon of the Toyota stuff just because it says Toyota on it when the universal stuff does the job just fine.
  6. May 22, 2016 at 6:10 PM
    ashleyroachclip
    ashleyroachclip Well-Known Member
    I agree with the last poster.
    It is almost impossible to get every last drop of coolant out , and in my opinion, you have probably done the best humanly possible.
    As long as you are using a product that is compatible with all other products, I don't see a problem.
  7. May 23, 2016 at 6:51 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Why do people say to use distilled water then?
  8. May 23, 2016 at 7:03 AM
    ashleyroachclip
    Hard water, when heated to close to , or boiling will create calcium formations when it cools back dowm.
    These are in the form of scales.
    Over time the scales get larger and start to block circularion, and eat at the metals and plastics in the cooling system.
    Resulting in failure.
    An engine , with a 190* thermostate, 16 pound radiator cap ,will actually have a coolant temperature well over boiling .
    And this is how those deposits form.
  9. May 23, 2016 at 4:53 PM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    It's called "hind-sight"... o_O
  10. May 23, 2016 at 5:00 PM
    ashleyroachclip
    So you know if you messed up, or REALLY MESSED UP.
    The distilled water is reall a buckshot scam.
    Most of you that live in the public water supply system, don't even need to worry about it.
    It is those of us that would be considered country folk, have god water, right from the river, or ground , or stream....
  11. May 23, 2016 at 5:30 PM
    goldentaco03
    Liam
    NJ
    Yup I had to buy jugs of distilled water cause I have a well and very hard water. And I ran out of jugs with an empty radiator and no way to go get more. Poor judgement for sure.
