Prestone toyota coolant
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bra, Apr 21, 2020.
  1. Apr 21, 2020 at 8:18 PM
    bra
    bra [OP] Well-Known Member
    2008 AC 4X4 TRD sport
    Badges off
    Hello,
    I will change my coolant fluid this week, however the toyota dealer in my country does not have toyota super long life coolant anymore
    Does anyone ever tried prestone toyota coolant in their 4.0 V6? Will go for it instead of the OEM if you recommend me
    Thanks guys
    http://prestone.com/products?detail=AF6200
  2. Apr 21, 2020 at 8:48 PM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    I bought mine on eBay if have that option
  3. Apr 21, 2020 at 9:59 PM
    bra
    Badges off
    Thanks for that but most of them don't ship internationally :( or the shipping is so expensive
  4. Apr 21, 2020 at 10:04 PM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    Honestly, prestone green is the same thing but cheaper. Prestone makes coolant for almost 99% of the manufacturer's and then makes it the color the manufacturer wants. Spoke with my friend who works at toyota and Prestone. They wont void warranties as well using green. As long as it's not DeX cool (orange), u good to go. Walmart has a bottle for like 12 bucks. Buy a gallon of distilled water and mix 50/50. Boom two gallons.
    bra[OP] likes this.
  5. Apr 22, 2020 at 12:03 AM
    bra
    Badges off
    Will do that thanks
  6. Apr 22, 2020 at 1:00 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Green can be used no problem. Just be ready to change it sooner than the original stuff.
    Toyota pink is made by Aisin, not too hard to source online for cheaper than Toyota
    bra[OP] likes this.
  7. Apr 22, 2020 at 1:11 AM
    bra
    Badges off
    Thanks for the tip
  8. Apr 22, 2020 at 6:25 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    How can you tell when coolant needs to be changed, pink, orange, or green?
  9. Apr 22, 2020 at 6:53 AM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
  10. Apr 22, 2020 at 6:55 AM
    Empty_Lord
    Dan
    A hydrometer can tell you if your coolants good or not
  11. Apr 22, 2020 at 6:56 AM
    Micbt25
    TM
    I typically stick to the manufacturer’s recommended service intervals. For the V6 4.0 engine Toyota recommends 100,000.
