Prestone VS red Toyota coolant from dealer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gregzz, Feb 16, 2017.
  1. Feb 20, 2017 at 1:16 PM
    #41
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    You can call BS all you want but antifreeze mixed to 50/50 will not gel where straight 100% antifreeze will gel. The "thicker" antifreeze won't flow as well in the cooling system. Tecnically 50/50 antifreeze will freeze to a solid before say 30/70 antifreeze but until the 50/50 freezes it will have a lower viscosity (the important part). I have personaly had straight antifreeze and mixed antifreeze in -40C and you can notice the different pour rates of the two.
    Also did you not notice the warning on the jug saying not to mix it more than 70%?
  2. Feb 20, 2017 at 1:20 PM
    #42
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    I thought newer Gen Tacoma's used premixed Toyota pink and not red still that needs to be mixed with 50/50?
  3. Feb 20, 2017 at 1:40 PM
    #43
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    They only truely work when placed up the rectum.
  4. Feb 20, 2017 at 1:50 PM
    #44
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    Changing your message of 60 percent water and 40 percent coolant being superior protectant?
    Also where was straight coolant or more than 70/30 ever mentioned?
    Just get your facts straight and don't report "fake news". :)
  5. Feb 20, 2017 at 1:58 PM
    #45
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Yep. So the moral of the story is, if you use generic Prestone coolant, you should change it more frequently than Toyota's book interval.
    Correct. Red is "Long Life Coolant (LLC)". Pink is "Super Long Life Coolant (SLLC)".
    Example:
    2002 Tacoma specified with LLC has coolant change every 60k / 4 years.
    http://www.toyota.com/t3Portal/document/om/OM35786U/xhtml/OM35786U_OM0018.html?locale=en
    http://www.toyota.com/t3Portal/document/omms/MSTOY02_MS0003/xhtml/MSTOY02_MS0003f.html?locale=en
    2004 Tacoma specified with SLLC has coolant change initially at 100k / 10 years, and every 50k / 5 years thereafter.
    http://www.toyota.com/t3Portal/document/om-s/OM35814U/xhtml/OM35814U.html?locale=en
    http://www.toyota.com/t3Portal/docu...MS0017/xhtml/MSTOYALL04_MS0017.html?locale=en
    Note both are 1st gen Tacos with the same cooling system. The increased interval is made possible by coolant formulation.
  6. Feb 20, 2017 at 2:31 PM
    #46
    fla_sun
    I have a friend who is a retired doctor. He always replies to certain comments with "what scientific proof can you show me"? I have to refer to his wisdom on this one.
    "Long life, super long life", it's all an advertising gimmick. Coolant replacement is not something you want to extend as long as possible. Unless you intend to trade in before too many years or miles accumulate and beware sucker buyer.
    Just look at all the posts about clogged heater cores and radiators.
    MolonLabeTaco likes this.
  7. Feb 20, 2017 at 2:32 PM
    #47
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    I switched it to 50/50 because that was what was on the bottle. Some manufactures do have a mixing ratio of 60/40. Look at your jug closely and I'm sure you will discover the precaution of mixing it over 70% but then again you did vote Trump so I suspect you don't inspect things that closely.
  8. Feb 20, 2017 at 2:49 PM
    #48
    fla_sun
    Another fake news reporter.
    Show me the mention of over 70% mix?
    Good grief, get a life.
  9. Feb 20, 2017 at 2:53 PM
    #49
    Zacowacko
    Zacowacko Well-Known Member
    Zack
    SW, OK
    2013 DCSB TE 4x4 6spd
    TRD Pro Susp., Icon AAL, Bags w/cradles, US OR Bumper w/Smitty, 2Lo Mod
    What are "inhinpbitors"? Do they bite inhin's? Lol o_O
    fla_sun likes this.
  10. Feb 20, 2017 at 3:00 PM
    #50
    fla_sun
    Enlighten me and just show me one manufacturer who recommends 60/40!
  11. Feb 20, 2017 at 3:18 PM
    #51
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Wut?...
  12. Feb 20, 2017 at 3:37 PM
    #52
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Not sure why you quoted my post on 100 vs. 50-50 or some such ratio. I did not reference any mix ratio in my post. But if I were to, I shoot for between 50 and 60 mix as I am more concerned with hot temp than cold.
    fla_sun likes this.
  13. Feb 20, 2017 at 4:03 PM
    #53
    KenLyns
    Belly of the Beast
    As I posted my message, Toyota's recommended interval went from 4 years with LLC to 10 years with SLLC. The cooling system hasn't changed between 2002 and 2004, so the only difference is in the coolant formulation. Now, if you don't trust Toyota's recommended interval, that's a different story.
    Fewer of these on 2nd gens.
  14. Feb 20, 2017 at 4:14 PM
    #54
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Should read foreign vehicle just being PC.....:D
  15. Feb 20, 2017 at 4:15 PM
    #55
    IPNPULZ
    going to be fun!
    LMFAO! :thumbsup:
  16. Feb 20, 2017 at 5:25 PM
    #56
    IPNPULZ
    going to be fun!
    Well,shit anyone in Fl knows a composite shingle roof is good for 14-16 years I never had one last more than 15/16 years and that was with proper care.......:D
    That's why I went to standing seam metal.......
    fla_sun[QUOTED] likes this.
  17. Feb 20, 2017 at 6:07 PM
    #57
    IPNPULZ
    going to be fun!
    Was by my old house in Seminole Heights in Nov and the roof still looks good been on since the mid 90's ........
  18. Feb 20, 2017 at 6:23 PM
    #58
    KenLyns
    Belly of the Beast
    Sloth likes this.
  19. Feb 20, 2017 at 6:35 PM
    #59
    Pigpen
    Dan
    Northwest Montana
    I've always mixed my own too. Lots of old trucks and tractors. Taco is past 85k miles, so I'm not too far off from a coolant flush.
  20. Feb 20, 2017 at 6:56 PM
    #60
    jokker1978
    jokker1978 Well-Known Member
    southeast texas
    2012 TRD sport 4dr 4x4 white
    Ok, so my 05 4x4 double cab, had 189k on it with the factory coolant, it would still have that coolant in it if a F250 didn't hit it parked doing 75mph.
    Why do you change the coolant ?
