Pretty sure head gasket is leaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wonderbread, Jul 25, 2025.
  1. Jul 26, 2025 at 8:35 AM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Totally understand …. I would definitely look into head gasket replacement seeing it never overheated :)
  2. Jul 26, 2025 at 10:04 AM
    wonderbread
    wonderbread [OP] Well-Known Member
    Steven
    PNW
    08 Tacoma TRD 4.0 4x4 auto w Loc
    Bilstein 5100 adjustable w TRD Exhaust
    Thanks for the advice Dave! I was thinking the same thing as you where as you just don’t know if a used engine was properly maintained? Gonna aim for HG replacement
    T-yoda[QUOTED] likes this.
  3. Jul 26, 2025 at 10:19 AM
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Yes. you know your truck was maintained…. No idea if the used one was and can easily follow down a dark rabbit hole
  4. Jul 26, 2025 at 10:37 AM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    My 2.7 recently had a blown head gasket, the head was just barely warped so I think they took like .004 off of it. This also helped in the fact I didnt have to bother scraping the 20 year old stuck on gasket material off also. It may have been okay to bolt back on without machining, but this also saved me time and ensured the new gasket had an ideal surface to adhere to. They also cleaned it up and checked that the valves weren't leaking by for it also.
    This all cost me $150 cash at a local machine shop.
    I'd say if you have the head already off to go ahead and get it check for flatness, it'll probably need to be machined but its your money. Would suck to have to redo the entire job if the headgasket blows in a short time.
  5. Jul 26, 2025 at 11:50 AM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    Correct and correct
