Preventative maintenance: when to replace AT fluid?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DrRoboto, Jun 29, 2021.
  1. Jun 29, 2021 at 1:16 PM
    DrRoboto
    DrRoboto [OP] Well-Known Member
    David
    Salt Lake City, UT
    <s>2017 AC Off-Road</s>
    GoFastCamper. OME 886. Medium Dakars. SSO slimline bumper + Warn VR10-S. OGE dual battery system. Mobtown skids.
    Toyota's maintenance schedule states 120,000 miles for the first replacement of ATF. I am skeptical. How far are folks actually driving before replacement?
  2. Jun 29, 2021 at 1:18 PM
    Timetraveler66
    Timetraveler66 Well-Known Member
    Let's see, hmmm. Toyota factory engineers, Or, hmmmm. Strange people on a forum. I'll take engineers.
  3. Jun 29, 2021 at 1:21 PM
    Tacospike
    Two Trucks
    Some people change at 30K intervals if not more, some people drive 200k+ and never change it. Some people haul a lot and some people don't.
    I would go buy the book.
    hiPSI and Skydvrr like this.
  4. Jun 29, 2021 at 1:23 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I'll take strange people on the internet who want something last longer than the engineers do. I do a full fluid change of EVERYTHING every 50,000 miles (except oil which is done at 5,000 miles). Remember the engineers call it "lifetime' fluid because they want the lifetime to be 100,000 miles.
  5. Jun 29, 2021 at 1:31 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I do 30K mile interval between drain and fills.
    cryptolyme and ernscott like this.
  6. Jun 29, 2021 at 1:31 PM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
    My plan was to do a drain and fill every 30,000 miles and a filter every other. But that is what makes me sleep good at night. Been doing that to my wife 2005 RX350, and so far so good with 140,000 on it. Fluid looks great. I did small bus maintenance for a living and it seemed my customers were happy also with those intervals. It's a roll of the dice that really has no answer, but transmissions these days are treated as throw aways in my opinion. I'm old school and like to change my fluids - but don't care for a complete flush. I'm fine missing a little couch time under my vehicles, and so far haven't missed a meal on maintenance money spent. Regards Scott
  7. Jun 29, 2021 at 2:34 PM
    knayrb
    Bryan
    Pure stock
    It's a waste of money when you turn in your truck every 30,000 miles at the end of your lease.
  8. Jun 29, 2021 at 5:19 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Something about not changing oil for 60k :anonymous:
  9. Jun 29, 2021 at 5:29 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    People will pick some arbitrary mileage number. You might as well and be as righteous as any of them. Go for it.
  10. Jun 29, 2021 at 5:30 PM
    knayrb
    Bryan
    Pure stock
    I’ll agree to disagree.
  11. Jun 29, 2021 at 5:36 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I flushed mine at 64,000 mi and tech said it wasn't bad at all . Now your transfer case is a different story
  12. Jun 29, 2021 at 10:27 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    I do a drain & fill every year. 3 quarts. So every other engine oil change, i'll take an extra 15 minutes for the ATF.
    usmc2msu likes this.
  13. Jun 29, 2021 at 11:59 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I check the fluid condition when I do regular maintenance but unless something is happening that makes me think it need to flush or fluid change…I do it at the service interval that it was intended.
    If Toyota says, 10,000 for oil…then I do oil around every 10,000. Toyota says spark plugs at 60,000…you guessed it…I replace spark plugs at or around 60,000…anything more than that is just dicking around and I don’t have time for all that.
    GOLFISHUNTS and Screaminpotato like this.
  14. Jun 30, 2021 at 12:47 AM
    verlaryder
    verlaryder Well-Known Member
    I keep wondering if the do-it-yourself owners might be overfilling their trannies? Seems like most do-it-yourself owners report their trannies were underfilled from the factory by about 1/2 quart. But I worry the factory amount is actually correct and so they might be overlooking an important step when refilling that is causing them to add 1/2 quart more than they should?
    Silentshredr, Hooper89 and RedWings44 like this.
  15. Jun 30, 2021 at 3:54 AM
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    I’d say they are actually low (in an acceptable range though) given many are doing it per the Toyota procedure. I followed it word for word and mine was a bit low too. Either way, even if overfilled by owners, no one that I’ve seen has experienced a negative outcome. At least not yet.
    cryptolyme likes this.
  16. Jun 30, 2021 at 4:19 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    I do drain and fill every 30K
    ernscott, cryptolyme and usmc2msu like this.
  17. Jun 30, 2021 at 6:24 AM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    Unless you are towing or off-roading every day i'd say 75-100k is probably right.
    GOLFISHUNTS likes this.
  18. Jun 30, 2021 at 6:43 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Follow the Maintenance Schedule for your truck. If you tow or haul or fit the Severe Service group, then shorten the service interval.
    My 2nd Gen recommends drain/filter change at 100,000 miles. I did the service at 105 kmiles.
    And no, the tranny won't destroy itself if you go over the interval a bit. Doubtful, if it will last longer with frequent changes, but there are many opinions and anecdote on the internet.
  19. Jun 30, 2021 at 7:56 AM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    I think the manual says to check/replace at 60k
  20. Jun 30, 2021 at 1:23 PM
    Timetraveler66
    I have seen way too many slipping or hard shifting transmissions after changing fluid. If it ain't broke, don't fix it.
