Preventative Maintenance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mr.mike8525, May 25, 2012.
  1. May 25, 2012 at 5:35 AM
    mr.mike8525
    mr.mike8525 [OP] Well-Known Member
    Riverside, California
    07' V6 preRunner SR5
    I was wondering if anyone with the knowledge would be kind enough create a list of preventative maintenance time frames such as...
    OIL CHANGE- Every 3-5K
    TRANSMISSION FLUSH- Every 60-100K
    WHEEL BEARINGS-
    SPARK PLUGS-
    CLEAN MAF/THROTTLE BODY-
    etc etc.
    Im not sure if this has been done yet by any of our members but I know something like this would be of great help for those who either flat out dont know or are unsure of when these things are to be done.
  2. May 25, 2012 at 5:38 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Look at your service manual - Toyota put one together for you already.
    Other then that grease your cam bolts otherwise you'll be cutting them out.
  3. May 25, 2012 at 5:42 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    x2, crack the Owner's Manual for scheduled maintenance.
    Stuff like brake pads, rotors, wheel bearings, cv joints and u-joints really depend on the driving conditions. Some may trash their bearings and cv's at 40k miles and some may make it to 140k miles before needing them replaced.
    Cleaning the MAF sensor and throttle body is one of those things that the Owner's Manual does not address but should be done at the owner's discretion. If you feel the truck is maybe idling rough, slow to respond to the throttle, etc, you might want to start with cleaning those items. I'm at 70k miles now and have never cleaned either but probably will at some point in the near future.
  4. May 25, 2012 at 7:12 AM
    mr.mike8525
    Cool, i'll have to borrow an owners manual or purchase one somewhere. Thanks for the imput. :cool:
  5. May 25, 2012 at 7:17 AM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    Greasing your cam bolts... Is this something like "muffler bearings" or "Blinker fluid"? or is that something legitimate that I have never heard of before?
  6. May 25, 2012 at 7:52 AM
    Pugga
    Massachusetts
    F-150 Mod
    Legit. The cam bolts rust inside the LCA bushings and, over time, the only way to get them out is to cut them. Ask either of us how we figured that one out... :mad: This is caused by Toyota's inability to use either neverseize or grease from the factory.
  7. May 25, 2012 at 7:57 AM
    A_Ninja_Racer
    Tampa, FL
    Oh I got you. I was thinking of the bolts that hold the the retaining Caps over the Cam shafts. :D
    But for real though. How does one go about greasing them? is this something that requires those bolts to be removed and then when replaced needs an alignment?
  8. May 25, 2012 at 7:59 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    North DFW
    07 DCSB Sport 2wd
    5100s @ 0.85, Grom iPod/Bluetooth adapter, mud flaps removed, clear turn signal bulbs, two extra D-rings, debadged, fog light anytime, OEM bed mat, Undercover classic, Falken Wildpeak A/T3W, Fumoto valve
    www.toyota.com/owners/
    Sign up there with your truck. You can look up the owner's and service manuals in pdf, view your service history at dealerships, etc.
  9. May 25, 2012 at 8:01 AM
    Pugga
    Massachusetts
    F-150 Mod
    Yes, you'd need an alignment afterwards so it'd be best to do it right before a scheduled alignment. You can use a grease pen to mark everything before hand to make sure everything goes back together at least close to where it was.
  10. May 25, 2012 at 8:06 AM
    XXXX
    sKiP
    05 Prius
    Ill be finishing my write up sooner then later...just been busy lately
    here are some threads that will end up helping
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/217265-lca-question.html#post5003636
    http://www.tacomaworld.com/forum/su...-replacement-2005-tacoma-4x4.html#post3691528
    http://www.tacomaworld.com/forum/su...-cam-replacement-2005-tacoma.html#post5088138
