Preventative Maintenance
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scoobarooo, Aug 15, 2015.
  1. Aug 15, 2015 at 7:37 PM
    Scoobarooo
    Scoobarooo [OP] Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    I have a '02 double cab with a 2.7 in her and I'm always looking to getting her everything she needs to keep her strong. At 122k, what is suggested to get done?
  2. Aug 15, 2015 at 7:54 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    flush and replace all fluids in tranny, power steering, brake reservoir and lines
    check and or replace brake hoses
    check and or replace brakes and rotors
    check front end for torn dust boots and loose front end parts, especially ball joints
    check and or replace carrier bearing (1/4" of play or less is ok)
    check all the u-joints
    check and or replace vacuum lines and anything rubber under the hood like belts and hoses
    check tires for dry rot cracks in sidewalls
    and of course the standard maint of new spark plugs, oil change, and air filter
    01TacomaV6 likes this.
