Preventative Maintenance
Discussion in '1st Gen. Tacomas (1995-2004)' started by MadbumsBum, Nov 5, 2017.
  1. Nov 5, 2017 at 12:42 PM
    MadbumsBum
    MadbumsBum [OP] Well-Known Member
    NW WA
    1999 Tacoma TRD 4x4
    I've tried searching this topic but could only really find a few sporadic posts about new purchases and not one "master list." I have a 2001 2.7L Xtra cab Auto 4x4 with 195k and want to do a pretty good overhaul in the next 6 months to get it purring. I'm working on a small budget so would like to prioritize things in terms of importance to long term health, but also want to make sure that I replace things "in order." What I mean by this is, for example, should I replace the fuel filter and fuel pump at the same time. Will just replacing the fuel filter mean that it degrades faster if I don't also change out the pump? Or can I stagger these replacements and be just fine? Here is my total "To-Do" list, and would like to know what you would do first with your first $300 or so, and what I am forgetting. I have pretty basic mechanical knowledge but am a quick learner and have some good mechanic friends.
    Maintenance to-do:
    - Fuel Filter
    - Fuel Pump
    - MAF sensor
    - O2 sensor
    - Alternator (new or rebuild?)
    - Water Pump
    - Valve covers
    - Grease driveshaft U-Joints
    - Replace drive belts
    - Brake pads and calipers (running a little squeaky but have life left)
    I also have a random note about lower ball joints, driveshaft carrier bearing, wheel bearings and rear axle seals.
    Apart from draining the fluid and replacing filter, is there anything else I can do for the transmission aside from a rebuild? It is shifting fine but it could be a little smoother. Previous owner was not a maintenance hound so I want to get a good jumpstart on all of these before they become problems. I'm also planning a suspension overhaul with Blistein 4600s and OEM coils for comfort, but that will probably be in a year because $$$. Thank you and if I have missed a really obvious thread on this then I apologize and please delete this and shame me properly.
    m3bassman likes this.
  2. Nov 5, 2017 at 1:05 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Here's a link to the YouTube channel my buddy Sean and I started: https://www.youtube.com/channel/UC9EMiD9KPy61kJ6hdXcbjxA
    We cover many of things you're talking about doing. I think you'll find the videos very helpful. If you like what you see, I suggest you subscribe so you'll be notified every time we upload a new video.
    Dalandser and MadbumsBum[OP] like this.
  3. Nov 5, 2017 at 1:08 PM
    MadbumsBum
    NW WA
    1999 Tacoma TRD 4x4
    Already subscribed thank you you guys make very easy to understand videos. I appreciate your work!
    Dalandser and Timmah! like this.
  4. Nov 5, 2017 at 3:21 PM
    kbeefy
    kbeefy Active Member
    Ken
    Bend, Oregon
    2002 DCSB 3.4 AT 4x4
    Warn 9.5XP, E-Locker, Bil 5100
    Most of this list are repairs, and done based on Condition of the part.
    Start by fixing the broke parts (Valve Covers Leaking? Alternator not charging? Fuel Pump not pumping?)
    Then do your maintenance (Replace Belts, Filters and ALL Fluids, Grease Steering and Drivelines, Clean and Re-lube brake calipers and guides, Clean MAF)
  5. Nov 5, 2017 at 3:23 PM
    MadbumsBum
    NW WA
    1999 Tacoma TRD 4x4
    This is exactly what I was looking for tbh. I don't have any good reason to think things are not working, I just want to get ahead. In that case I guess I will do my maintenance and tackle my brakes first until something else comes up. Thank you.
  6. Nov 5, 2017 at 3:26 PM
    kbeefy
    Ken
    Bend, Oregon
    at 200k your due your second set of spark plugs if their platinum, and your 6th set if their copper/conventional.
    MadbumsBum[OP] likes this.
