preventing a frozen windshield
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rvcahawaii808, Dec 9, 2009.
  1. Dec 9, 2009 at 11:54 PM
    rvcahawaii808
    rvcahawaii808 [OP] Well-Known Member
    cameron
    beaverton
    04 limited T4R 4x4
    first time this ever happened to me. im from hawaii but i shipped my truck to oregon for school. i was driving down I-5 at night and it was probably around 20ish degrees outside, i was going maybe 70-75. i decided to clean my windshield and as i pulled the wiper control to make the water come out, it instantly froze and created a layer of frozen water covering my entire windshield, i slowed down and pulled over and just broke it off, but it got me wondering. do you guys use a certain type of washerfluid? im just using water right now but if anyones got any suggestions thatd be great.
  2. Dec 9, 2009 at 11:56 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Go to Wal-Mart. They sell winter washer fluid that won't freeze unless it's like -35. :p
    The kind I get when I'm up there is orange. It works great!
  3. Dec 9, 2009 at 11:58 PM
    rvcahawaii808
    cameron
    beaverton
    04 limited T4R 4x4
    thanks man, my first time driving up here in the mainland during the winter. love playing around in empty parking lots!
  4. Dec 10, 2009 at 12:01 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Yeah, good luck testing out the PreRunner dude!
  5. Dec 10, 2009 at 12:07 AM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    x2 what he said. it's what i use hear in the frozen rockies
  6. Dec 10, 2009 at 12:09 AM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Welcome to the NW.
    You'll want to get some winter wipers also. They are designed differently. Winter wipers will be made of higher strength material because rubber degrades quicker in cold weather. Also, they are coated to shed snow and ice.
    I live in Portland OR and this year is shaping up to look like we'll have some pretty cold days ahead. My truck read 18 degrees at 9am this morning. Brrr.
  7. Dec 10, 2009 at 12:12 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Not at all.
  8. Dec 10, 2009 at 12:12 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    It's just like any other windshield washer fluid, it's just orange and has some different compounds in it. :p
  9. Dec 10, 2009 at 12:40 AM
    mountainwolfpup
    Vancouver, WA
    Actually wiper fluid can and does damage paint. If it contains ethanol and/or methanol. The corrosive effects of ethanol, methanol, and other components, with regard to paint, rubber, car wax, and plastics is well documented.
    In wintertime you have no other option because other solutions will freeze.
    But in summer I make my own wiper fluid by mixing 50/50 white vinegar and distilled water. Ends up costing me about $3 a gallon but its environmentally safe and safe for my paint too.
  10. Dec 10, 2009 at 12:45 AM
    rvcahawaii808
    cameron
    beaverton
    04 limited T4R 4x4
    thanks for all the advice, the weather is pretty cold but at least its been sunny most of the time. mt.hood has spring like conditions, except with windchill its like -6 somedays
  11. Dec 10, 2009 at 1:32 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    I stand corrected! :eek:
    Apparently there is ethanol, methanol and other components in windshield washer fluid that is corrosive to paint. :p
  12. Dec 10, 2009 at 4:16 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Anytime its cold out.... I always put the defroster on (max warmth) and leave it on the entire trip. That directs all the warm air on the windshield and keeps it warm enough that things don't freeze up.
    That is...it works for me in my PA climate.
  13. Dec 10, 2009 at 4:31 AM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    Welcome to cold winter weather!
  14. Dec 10, 2009 at 7:44 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    As mentioned get some good winter wiper fluid and some quality winter wipers.
    Each fall/spring I dump the contents of the windshield washer fluid reservoir and refill with the appropriate fluid for the time of year. It only takes 2-3 minutes to remove the reservoir. There are two small bolts with a 10mm head on them. Once removed, unplug the wiring harness from the washer pump that is attached to the reservoir. Unplug the hose also and the reservoir will pull right out.
    If you don't have much fluid left in the reservoir I wouldn't worry about it. Just top it off with winter fluid and be done with it.
    I use Rain X Winter fluid with De Icer. I find it pretty good and also causes the water to bead off the windshield similar to how a fresh coat of wax allows water to bead off your paint.
  15. Dec 10, 2009 at 9:08 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    I use the rain-x deicer like posted above...it definitely works especially on those really cold days...I'm constantly up on the mountains snowboarding every weekend...:D
  16. Dec 10, 2009 at 9:21 AM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    Sorry to thread jack...but as you've been helped already, I'm curious - how much did it cost to ship your truck?
  17. Dec 10, 2009 at 3:02 PM
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    I tried the rainx one time and it worked in a good rain but when it was misty sprinkly type rain and I used the wipers the water just smeared and made it hard to see out. It took a long time for that stuff to finally clear off of the windshield. Has this happened with anyone else who tried it?
  18. Dec 10, 2009 at 3:12 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Not with me. It might've been your blades.
  19. Dec 10, 2009 at 3:32 PM
    sachou
    Sam
    Happened to me. I could actually see better if I had the windshield wipers off, tuning them on every 40 seconds or so. This was on the freeway at night after a huge downpour and I was following an SUV.
    It worked...but not with my wipers.
  20. Dec 10, 2009 at 6:25 PM
    Old Soul
    NC
    could have been the blades, this was my first truck 15 years ago so i was just learning about how to maintain a vehicle and didn't know much..
    that's what I remember, worked great until the rain stopped and there was not enough volume of water to roll off the windshield from its own weight, the tiny drops just stuck there until I used the blade then they smeared all over the place, nighttime was the worst
