Preventing rust from salt air?? Best tips?
Discussion in 'Performance and Tuning' started by tacoma1389, Oct 27, 2019.
  1. Oct 27, 2019 at 6:32 AM
    tacoma1389
    tacoma1389 [OP] Active Member
    Looking to buy a Tacoma soon.
    Hey gang, looking to pick up a Tacoma soon. My current f150 is suffering from body rust, I live in a coastal city right on the ocean. Salt water/air is always a factor, esp since we drive on the beach a lot. What are some ideas on preventing salt corrosion over time? (besides hosing it off after being on the beach). Thanks for any advice!
  2. Oct 27, 2019 at 6:33 AM
    Clearwater Bill
    Billy
    Largo Florida
    Do a forum search on Fluid Film.
    And keep hosing it off anyway.
  3. Oct 27, 2019 at 6:37 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    I’d hit the entire frame, brake lines, etc with a rust protectant.
    seeing as you hit the beach you probably want to avoid a viscous coat like Fluid film cause I’m foreseeing a ton of sand caked to the frame. Maybe Amsoil HDMP, or plain Corrosion X or something along those lines that puts a thinner/drier coat that won’t pull so much crap. Inside of the frame I’d do the thick stuff.
    it will mean you have to reapply more often though.
    I’d also pull the rocker panel plugs and spray all inside and call it a day on those.
    also hit your fuel cover plate hinge with some protectant.
    tacoma1389[OP] likes this.
  4. Oct 27, 2019 at 6:39 AM
    tacoma1389
    Thank you! Will look into that!
  5. Oct 27, 2019 at 6:41 AM
    JdevTac
    Josh
    GA/WA
    2nd gen
    Don’t forget your spare tire hoist either.
  6. Oct 27, 2019 at 6:43 AM
    tacoma1389
    Ah good point!
