Previos Owner cut headlights conectors pretty bad….
Discussion in 'FBC Harness Solutions' started by Jorgetj, Feb 11, 2023.
  1. Feb 11, 2023 at 3:17 PM
    Jorgetj
    Jorgetj [OP] New Member
    Jorge
    Tacoma trd off road 2017
    Hi,
    I recently purchased a tacoma trd offroad 2017. As a first modification I wanted to switch to oem led headligths. The issue is that previous owner cut conectors pretty bad so I know that I will need to do some soldering stuff. What would you recommend? Can you male a kit for my situation?
    thank you!
  2. Feb 11, 2023 at 3:57 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Three choices:
    1. Halogen pigtails from me or a junk yard. I actually have these pre made as someone else once requested. Another guy also asked but wound up getting what he needed from a junkyard. Color matched so you’d just heat shrink butt connector then heat shrink over the top. Then add a conversion harness.
    2. LED pigtail. Might be harder to find these at a junkyard but I can do this too. Same heat shrink but connectors. Heat shrink over the unused sidemarker or cap it. Then you’d plug right in.
    3. Order a pair of female MX-150’s and crimp directly to the OEM wire.
    I’d probably crimp direct myself in this situation.
  3. Feb 11, 2023 at 3:58 PM
    daveeasa
    David
    PNW
  4. Feb 11, 2023 at 7:09 PM
    Jorgetj
    Jorge
    Wow! Thank you!
  5. Feb 11, 2023 at 7:11 PM
    daveeasa
    David
    PNW
    Lemme know if you need links for specifics. Don’t decide immediately, I’d think about it for a day or two.
