Previous owner jacked up oil pan
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JNL, Dec 10, 2009.
  1. Dec 10, 2009 at 5:53 AM
    JNL
    JNL [OP] Well-Known Member
    Jamie
    Atlanta
    08 DC Prerunner TRD Sport
    So yesterday when I was jacking up the front end of my truck to install my Spidertrax spacers, I noticed that the oil pan had an indentation in it exactly the same size as the cup on a typical floor jack. It looks like some one tried to jack it up under the oil pan:facepalm:. The indentation is probably 1/2" in but there aren't any cracks or leaks. Is this something I need to worry about? How much would a new oil pan be? Is it a simple unbolt and rebolt/change oil job? What about the torque specs on the oil pan? Is thread locker needed?
    Thanks for all your help.
  2. Dec 10, 2009 at 6:24 AM
    JNL
    Jamie
    Atlanta
    So nobody wants to help out a cute girl?
  3. Dec 10, 2009 at 6:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    If it isn't leaking, I wouldn't worry about it.
  4. Dec 10, 2009 at 6:30 AM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    :EDIT: ya what he said
    i wouldn't worry about it if there is no leaking. if you go to sell it soon i would recommend replacing it tho.
  5. Dec 10, 2009 at 6:40 AM
    JNL
    Jamie
    Atlanta
    How much would a replacement be?
    I don't like the fact that there will be two small spots where the oil won't drain all the way due to the indentation
  6. Dec 10, 2009 at 6:43 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    You only know now because you jacked it up. If it aint leaking I'd leave it.
  7. Dec 10, 2009 at 6:44 AM
    ak47
    Anthony
    Washington
    stock 2nd owner
  8. Dec 10, 2009 at 6:44 AM
    ak47
    Anthony
    Washington
    stock 2nd owner
    about 60 bucks alot cheaper then i thought. i would probably replace it now.
  9. Dec 10, 2009 at 6:48 AM
    2009Silver
    2009Silver Well-Known Member
    Wisconsin
    2009 Silver 4x4 DC TRD Sport
    WeatherTechs Bed Extender Bed Mat 3" Lift Spidertrax Clarion DVD HU Overhead Monitor
    I'm sure somebody here would do it for you if you post pics...
  10. Dec 10, 2009 at 6:49 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    1) Take off the helmet and prove it! :p Although given your choices in transportation and mods, I'm not sure if it matters.
    2) You've heard already above that if it's not leaking don't spend any time on it, but you also need to watch out for where the oil pump pickup is in relation to the dents. If the pickup is in the area of the dent, oil pickup and pressure can be affected. Not sure myself where the pickup is, or where you're dents are, but I would be spending some time finding that info out.
  11. Dec 10, 2009 at 6:58 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    Yeah, you can't just get on here and claim you are hot without proving it. That's just not fair.
    And I would watch for leaks and leave it alone. That's pretty dumb to jack it up there. Could it have been a rock? Are there other scratches around it?
  12. Dec 10, 2009 at 7:33 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Off topic but somewhat related, check your engine mounts next time you're under your truck. They're not exactly designed to support the weight of the truck, especially in the direction the forces would have been applied if the front of the truck was actually lifted off the ground by the oil pan.
  13. Dec 10, 2009 at 9:00 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    depends on if the truck was actually lifted. i bet the oil pan dented before any tire came off the ground.
    i would fix it...my personality wouldnt allow me any peaceful sleep knowing there was some stupid damage to the pan. ESPECIALLY if i did the damage.
  14. Dec 10, 2009 at 11:46 AM
    TacoMOnster07
    TacoMOnster07 Well-Known Member
    Pennsylvania
    07 DC 6speed 4x4 BSP Sr5
    BHLM, Grillcraft, Urd SS, Urd TCAI, Urd MAF Calibrator, AeroTurbine Exhaust, TacoTune Single Din, Two 8" Infinity Subs, 12-13000 HID's, Xtreme Bedrack light bar with two KC 4 by 6 lights.
    I think we need to see the damage. Take a picture asap.
  15. Dec 10, 2009 at 11:53 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Just bang it out with a hammer :D
    Seriously though, I doubt much oil is getting left behind with a little indentation. You can take it off and really do straighten it out with a hammer. That way you don't have to buy a new one. Just a gasket. As someone else already said, check the engine mounts.
    Maybe it was taken to Jiffy Lube by the previous owner.
  16. Dec 10, 2009 at 11:57 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Gonna need to see some pics to verify that ;)
    I can't see there being any damage if it's just a dent.
  17. Dec 10, 2009 at 5:56 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  18. Dec 10, 2009 at 6:58 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I would just replace it, the OEM oil pan costs $50 at the dealer. I was gonna replace mine cause the threads got stripped but I just took it off and took it to a machine shop and rethreaded it with a bigger bolt. BTW the oil pan doesn't have an OEM paper gasket, you have to use the liquid gasket in the tube (that is what was used originally).
  19. Dec 10, 2009 at 7:34 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    ... I would deffinatly replace it, without hesitation. I'm not sure on this motor, but on previous cars I've had, denting the oil pan like that can cause oil starvation for some cylindars, which could lead to a hell of a lot more costly repairs than a $60 oil pan, gasket, oil change, and an hour or so time... It's a cheap insurance policy. That, and it'd be out of the back of your head wondering if it could be causing damage.
  20. Dec 11, 2009 at 4:35 AM
    JNL
    Jamie
    Atlanta
    I can do it myself thank you very much....just cause I'm a girl doesn't mean I don't know how to use a wrench ;)
    The dent is in the center of the oil pan.
    no scratches around it....definitely an impression from a jack
    They dont show any sort of gasket in that illustration....usually they will show it, or at least note to seal it with something like a high temp RTV sealant. Am I missing something?
    I'll take a pic when I get the chance
    See below
    Should I use something like RTV high temp silicone? How much should I use? I really don't want excess silicone inside the oil pan.
    Here's a pic from Halloween.....I'm the one on the right:
