Previous owner jacked up oil pan
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JNL, Dec 10, 2009.
  1. Dec 11, 2009 at 5:08 AM
    98tacoma27
    Ben
    Not Beech Creek
    If you do replace it, get a rubber gasket. No RTV is required for a rubber gasket.
  2. Dec 11, 2009 at 5:36 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I'm sure there would be many members more than willing to help you out in fixing your oil pan. I doubt my wife would let me drive the ~650 miles to offer assistance though ;)
    GL on the fixing. Make sure and get a pic of the dented pan too. Might be easier once you get it off the truck.
  3. Dec 11, 2009 at 5:38 AM
    Boomtacoma01
    Boomtacoma01 Well-Known Member
    Houston
    When you pick up your oil pan, just get an OEM gasket also.
    Cute pic BTW.
  4. Dec 11, 2009 at 5:51 AM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    Cute? Are you looking at the same picture I am? The word "Hot" comes to mind in the picture I see !
    There probably isn't a gasket on there now, just a factory sealant. If you get the pan from the dealer, check with the service dept. on the proper sealing procedure.
    Marc M
  5. Dec 11, 2009 at 5:55 AM
    Boomtacoma01
    Houston
    Cute as in the pose. Hot Ladies indeed!
  6. Dec 11, 2009 at 9:08 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    It seems that most newer toyotas dont require a gasket for the oil pan or transmission pan. What you should use is a product called "the right stuff" made by permatex. It, im my opinion, is the best gasket maker on the market. Its like silicone and superglue. Works amazing. Cost around $15 for a tube
    http://www.permatex.com/brand_right_stuff.htm
  7. Dec 11, 2009 at 5:11 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    hondabond also is some good stuff.
  8. Dec 11, 2009 at 5:16 PM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    x2!
  9. Dec 12, 2009 at 7:52 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    How about this story? Today coming back from Clear lake Ca. to San fran. Was raining cats and dogs. In this area with a hill to the right of the road, one stone the size of a football come down the hill right in front of my truck. No time to avoid, and I rolled over it and heard a big bang under the truck. I stop and looked, and oil is leaking on the pavement. I pulled over and after o inspection I've seen a bent and broken oil pan.
    After I called a bunch a tow comp, I decide to fix the problem my self. I was 45 miles away to the closest town, and the cheapest price was $11 per mile with a 45min delay. The oil drained itself out in 4-6 minutes. I took a hitch ride with some guy to the nearest town, got JB weld, 7 quarts of oil and come back. I cleaned the area very good, sand papered the paint around the hole, About the size of 1/16 by 1/8 cut, apply the epoxy and half a hour later added the new oil. In top of the hole repair I put a shop towel and duct taped it as you see in the picture. I had 2 quarts left over in case of some leaks, but was not necessary. The truck rests in front of my home, 140 miles away and still have 2 quarts of oil left. NO LEAKS. Monday I'll get a new oil pan.
    Now how the hell can I atach images. (i have them, this is not joke)
