Price for new 2nd gen, 2010 DCSB TRD PRO Sport
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bfmlive, Apr 4, 2024.
  1. Apr 4, 2024 at 6:36 PM
    Bfmlive
    Bfmlive [OP] New Member
    Brian
    I am going to look at at this truck, 35,000 miles very clean. Any thoughts on a price I should offer.. I know the lady but not the maintenance history.
  2. Apr 4, 2024 at 6:38 PM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    TRD Pro sport does not exist
    It’s either a TRD Pro or TRD Sport
  3. Apr 4, 2024 at 6:41 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    There was never a 2010 Pro.
    Only Pro model in a 2nd Gen was a 2015. No other years were offered in a Pro.
  4. Apr 4, 2024 at 6:47 PM
    Just_A_Guy
    On the hunt
    A truck
    The Pro was only made in 2015? I could have sworn it was at least 2014-15
  5. Apr 4, 2024 at 7:16 PM
    TnShooter
    Deogee
    STOCK
    2015 was the first year.
    They did some Tx and Baja models before that.
    But the Pro was introduced in 2015.
  6. Apr 4, 2024 at 7:18 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    And with 35k miles it would be used, not new
  7. Apr 4, 2024 at 7:18 PM
    Jasskillman
    Jasskillman Well-Known Member
    SoCal
    2013 DCSB
    Is it even a 4x4?
  8. Apr 4, 2024 at 9:13 PM
    PapaBear15
    PapaBear15 Member
    Black 2012 TRD OR 4x4
    I Just got mine a few months ago. Same ish mileage but its a 2012 DCSB 4x4 TRD OR in low to mid 20s.
  9. Apr 4, 2024 at 11:50 PM
    TacoTuesday1
    SD CA
    in addition to what everyone has said
    Depends on options and condition. Miles don’t make much difference on these trucks.
    it’s not 3x more horsepower because of less miles.
    fatfurious2 likes this.
  10. Apr 5, 2024 at 6:27 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Pics of frame/underside mandatory
  11. Apr 6, 2024 at 3:26 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    $19k if it's in great shape,it's a 14 year old truck no matter the miles.
  12. Apr 6, 2024 at 5:11 AM
    ToyTruckMan69
    ToyTruckMan69 New Member
    Joseph
    2005 Taco TRD 2WD
    Tube steps, K&N filter; Joying 11.6" head unit; Hertz Legend 700.3 a pillar mounted in aluminum pods; 6'5 Focal Flax front doors; RE Audio 7" XXX back doors; RE Audio 10" SEX V2D4; Helix DSP.3s; Toppings D10s DAC; Soundstream Humain Reign HRU4; JL Audio 500/1 original US made (23 years old and still hammering); Soundstream Ref.4 760; Dual Battery AGM; Volt meter in dash for both sound system and batteries; 2008 dash for USB and seat heater switches; 2-3.1 usbs; 2 other usb for toppings and Joying inputs; tint; sound deadening; sound absorbing materials; bull pusher; seat jackers; led upgraded lights inside; led under door convenience lights; led headlights.
    First, do not call the thing that makes a lot of noise under the hood a motor. If it runs on fuel, it is an engine. A motor runs on electricity. Prior to Tesla, there were no motors. Steam engines. Internal combustion engines. But, no motors. He invented them for use with electricity.
    I have a 2005 TRD Sport 2wd - thus, I have the 4.0l. 277k miles. Just replaced the torque converter, and she still runs like a raped ape. Provided my main seal and tranny do not fail, I'm going for the record. In my opinion, the age of a vehicle is irrelevant. It is how well it has been maintained that is way more important. Like humans, they are an electrochemical machine that need TLC.
    So, not driving it is almost as bad as driving it excessively. At 35k, she probably has not had much done. Find out if she has taken it to any particular dealer for work. Ask them about maintenance records. Get the VIN and do a VIN check. Check the engine for leaks around timing chain cover and valve cover gaskets. If you don't run it, seals tend to leak. When you test drive it, check for smoke. If it is white, the main seal is bad. Another way to check is to pull the dip stick and smell the oil. If it smells like coolant, RUN! IF it is black, the rings are bad. RUN FASTER! Take it to a dealership or a mechanic you know to check it out. Go to AutoZone and have them run a code check if you don't have an OBDII reader (they are pretty cheap these days). Some codes are not always displayed right away. But, the reader will tell you it is about to throw the code. Look at the grooved part of the serpentine. If it has small cracks in the ribs, it is dry rotted and will need to be replaced. Listen to it while it is idle. Really listen. She will tell you if she is off somewhere. Loud clacking - valves need tightening. Rough idle - intake needs cleaning. Wee-ew sound when driving - U-Joints. IF the truck shakes while driving it, the wheels are out of balance. IF it shakes when you depress the brake, the rotors are warped. If it pulls to the left or right when you hit the brakes, one of the calipers has blown a seal and is not operating. It is the other side that is stopping the truck so if it pulls left, the right caliper is bad. I have bought rebuilt calipers from AutoZone several times, and they lose seals a lot. I just bought OEM calipers and will rebuild my own from now on. If you have not driven a Tacoma before, you might notice a "clunK" in the drivetrain when you stop. It is normal. It is weird and annoying but normal. Look up the threads on it. Check the frame. The 2nd gen.'s are notorious for rusted frames. There are some recalls so check to see if they have been done.
    If you buy it, put a bottle of Sea Foam in the gas and oil. Run it for 1k and then change the oil. It will remove any moisture and dried oil laying around from non-use. Take it for a nice long drive at 90mph to heat up the engine. Sea Foam works better that way. Change the plugs. They are only 15k plugs. I screwed that up and caused a misfire that ruined my driver's side cat. It is truly expensive to be an idiot. Have the tranny flushed too. It has sat so there is probably moisture and more metal shavings than usual. The moving parts requiring various lubricants dry out if the vehicle is not used. The next time it is used, these dried metal parts grind before the lubricants get to them. Engines are made to run, not sit in a garage.
    Finally, get a Pedal Commander. Was about to get a supercharger and came across it. Holly shirts and pants!
