Price for new door?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zark, Mar 29, 2013.
  1. Mar 29, 2013 at 11:50 AM
    Zark
    Zark [OP] Member
    Canada
    SR5
    Happaned an hour ago, gonna need new door. Other shit buffed too, but door is main thing
  2. Mar 29, 2013 at 11:55 AM
    Manwithoutaplan
    ID
    :eek: :eek: door are not cheap :S.
  3. Mar 29, 2013 at 11:58 AM
    Tommy27
    Tommy27 Well-Known Member
    Tommy
    Boise,ID
    White 09 AC 4x4 2.7 5spd SR5
    Leer shell, Bed mat, Grill Guard
    Look at parts yards, but other than that for a whole new door you would be pushing almost 1000$. You could have your door re-skinned.
  4. Mar 29, 2013 at 12:02 PM
    Zark
    Zark [OP] Member
    Canada
    SR5
    Yeah everything seems intact as far as the farm goes. Other then the door being pushed in, didnt know if a reskin could fix this
  5. Mar 29, 2013 at 12:08 PM
    nocaltaco
    nocaltaco Well-Known Member
    DTM
    san jose, ca
    Hella stuff
    Try to find a used door --car-part.com
    Skin it but toor I-beam could be damaged as well as jamb. If you just replace the door the painter better be damn good to butt match the paint because if he Ain't blending the fender and rear door it will be mismatched. Unless the painter is damn good.
    GLWR
  6. Mar 29, 2013 at 12:22 PM
    Zark
    Zark [OP] Member
    Canada
    SR5
    framing looks to be fine
  7. Mar 29, 2013 at 12:35 PM
    KJaikaran
    KJaikaran Well-Known Member
    Orlando FL
    2011 Tacoma DCSB TRD Sport
    URD intake/maf calibrator, Icon extended travel coilovers, Icon UCA, OME Dakar leaf packs, Bilstein extended rear shocks, 3 degree axle shims, Carrier bearing drop bracket, DS2 retro, 5k HID bulds top and bottom
    As long as the frame of the door wasn't compromised i think you can just replace the outside skin of the door.
    I don't know if you have ever heard of LKQ, but they might have the skin for a really good price.
  8. Mar 29, 2013 at 1:02 PM
    Zark
    Zark [OP] Member
    Canada
    SR5
    Looked it over more, frame and cab is pushed in and bent.
    Might have to write it off
  9. Mar 29, 2013 at 1:24 PM
    KJaikaran
    Orlando FL
    The frame under the truck, or door frame is bent ? If your talking about the rocker panel under your door that can either be pulled, or cut out and replaced. Cut out and replaced is the best way in fixing it. I think rocker panels are usually double panel so it might not be able to just be pull out. They actually sell the rocker panel from factory for this same reason. They are usually tack welded into place from factory and body work is applied to the seems.
  10. Mar 29, 2013 at 2:18 PM
    Zark
    Zark [OP] Member
    Canada
    SR5
    door frame, the cab I guess.
    Decided to go thru insurance, since I have a forgiveness anyways( I think)
    Taking it to a good body shop in the city, there gonna tow it on monday and then assess it, and i just wait
  11. Mar 29, 2013 at 2:21 PM
    SportyHeretic
    SportyHeretic Well-Known Member
    Jeremy
    Wyoming/South Carolina
    2010 Sport
    Icon Stage 3 Suspension, Diff Drop, MagnaFlow Cat-Back Exhaust, Tonneau Cover
    good luck its expensive, let the insurance take care of it
  12. Mar 29, 2013 at 2:29 PM
    SuperWhiteSLT11
    SuperWhiteSLT11 Active Member
    STEVE
    PHILA. PA.
    SLT LONG BED
    SUNTEK WINDOW TINT 15% FRONT & 20% REAR DOORS & SLIDER , EGR WINDOW SHADES ,
    As a licensed auto adjuster , just look at your photos it will probably be 2500 to 3000 thousand by the time you done , most time a clean factory built used door makes for a better repair, most of all make sure you take it to a good shop .
