price of new key
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MSCOFF, Mar 14, 2011.
  1. Mar 14, 2011 at 7:34 AM
    MSCOFF
    MSCOFF [OP] Well-Known Member
    Mark
    CT
    2017 SR5 AC 4WD
    On a new 4L V6 Access cab. I was at the dealer thismorning and asked the parts counter how much for a new key(with the chip) and how much to program it. The guy sid $45 for the key plus 1 hour labor (minimum). So the whole caper with tax at this particular dealer is about $150. Of course the key is no good without the programing. Is this what you guys are paying. I have the two programed keys that came with the truck. I've read that this is a dealer thing, so I probably should shop around if I want the third key .Thanks. Mark S.
  2. Mar 14, 2011 at 7:38 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    What do you need the 3rd key for if you don't mind me asking? You can get one with out a chip to unlock the doors, you can use it to turn the ignition to Aux and to on, just won't start it.
  3. Mar 14, 2011 at 7:41 AM
    KCin HBCA
    KCin HBCA Well-Known Member
    Keith
    Huntington Beach
    09 Dbl Cab PreRunner
    Check your local ACE hardware... they sell the key with programing for $69 (at least here that is the price). Works fine just doesn't have the Toyota logo on it.
  4. Mar 14, 2011 at 9:26 AM
    MSCOFF
    Mark
    CT
    2017 SR5 AC 4WD
    Thanks guys. If I can loose something, I will. So better to get the extra one now before I have to go for the new one without the masters. Thanks for the heads up about ACE hardware.
  5. Mar 14, 2011 at 9:53 AM
    enigma429ad
    enigma429ad Well-Known Member
    Olive Branch, MS
    07 PreRunner SR5 DC LB
    I've been told close to $300 when I've asked around. I only got one with mine and one copy to unlock that doesn't have a chip.
  6. Mar 14, 2011 at 11:10 AM
    Jefenator
    Jefenator Taco Truck Noob
    Oregon
    2010 2WD Reg Cab Stick Shift
    My local ACE isn't that sophisticated yet, but I noticed the locksmith now claims to be up to the task.
  7. Mar 14, 2011 at 12:43 PM
    sixdoubleseven
    sixdoubleseven Wrangler Convert
    Dave
    Boston
    2014 DC 4x4 Pyrite SR5
    That seems like a waste. Why not wait to see if you loose one in the first place? Got money to burn?
  8. Mar 14, 2011 at 6:39 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    I wouldn't stick an unchipped key in the ignition.Fine for the locks.
  9. Mar 14, 2011 at 7:11 PM
    HomeGrown
    HomeGrown Well-Known Member
    Bill
    South Bend, IN
    2014 Reg Cab 4WD
    UNchipped key sounds totally useless, unless you happened to lock your keys in the truck.
    OP, you don't need the original keys to have replacements cut, they can duplicate your key with the VIN (only at the dealer, of course). If a replacement key was $3.00 then great. But upwards of $150 for the sake of "what if"? Invest in a better key ring and be careful with it.
  10. Mar 14, 2011 at 7:24 PM
    joes06tacoma
    Joe
    Central Coast, CA
    that price sounds about right for dealership. I bought three keys on ebay, OEM keys from a dealer in San Diego, had them cut locally, then programmed at my local dealer. Wound up paying 170 for all three. If you think you'll ever need more than one spare, get them all at the same time and save that programming fee.
  11. Mar 14, 2011 at 7:54 PM
    Sheppymach
    Sheppymach Well-Known Member
    Sheppy
    Philadelphia, Pa
    2014 4Runner trail edition
    BLU LOGIC bt, avid, weather tech mats & rain guards, 285/70/17, BenWA's totally AWESOME power sliding window mod.
    the chipped key doesnt need to be in the actual ign to start it just real close, so get spares made unchipped and zip tie the chipped key up under the dash.
  12. Mar 14, 2011 at 7:58 PM
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    PreRunner SR5 TRD Sport
    Bull bar, wet suit seat covers, Accessory meter repair, Fog Lights with stick on, console lock.
    I Got three chipped keys with mine. 2 black,1 grey. I thought the gray one was not chipped, but it started the truck when turned. Also have the little tag with the key code on it.
  13. Mar 14, 2011 at 9:19 PM
    AKTACO420
    AKTACO420 Well-Known Member
    RETODD
    Anchorage AK
    2009 tacoma
    bucket seats grille craft mesh grille and lights behind grille
    i had a key made for a couple of dollars and it unlocks the doors and will start my truck.but i think its because i have the reg cab 4x4 without all the bells and whistles
  14. Mar 14, 2011 at 9:21 PM
    AKTACO420
    RETODD
    Anchorage AK
    2009 tacoma
    im pretty sure it has to be in the ignition or a chip in the key would be pointless
  15. Mar 15, 2011 at 4:40 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    It does not hurt anything. It just won't start the truck, you can turn it to start but nothing. I keep an unchipped key in my wallet, a key without the plastic on it, just flat metal. So I always have a key with me if I lock mine inside. When I'm at work, I don't like to to keep my keys in my pocket cause its to bulky, I lock them in my locker. So sometime when I'm outside on lunch and say its a warm day, I might want to crack the windows so I have my key in my wallet, open the door, turn it to on, and I can crack my windows. Works out great for me.
  16. Mar 15, 2011 at 8:34 AM
    Cmatt1605
    Cmatt1605 Well-Known Member
    Cody
    Mount Pleasant, South Carolina
    Squeaky leaf fix
    $60 at my store :D
  17. Mar 15, 2011 at 8:56 AM
    jrdbrn
    jrdbrn Borne Fishing
    Jared
    Louisiana
    '16 Inferno Tacoma TSS
    The gray is a valet key. It's meant to do everything but unlock your glove compartment.
  18. Mar 15, 2011 at 8:59 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Which never made any sense to me, being that there is no lock on the glove box!
  19. Mar 15, 2011 at 9:10 AM
    jrdbrn
    Jared
    Louisiana
    Interesting LOL
    I never noticed.
  20. Mar 15, 2011 at 9:11 AM
    jrgroucho
    jrgroucho Well-Known Member
    Jeremy
    Michigan
    2010 AC SR5 BSP
    Hose Clamp, No Seatbelt Chime, Husky Floor Liners, BHLM, sockmonkey Tailgate Decal, Wet Okole Covers/Armrests,
    Makes me glad I don't have chipped keys. I got a copy of mine from Ace for less than two dollars to put in my wallet (cut off a bit on both sides to make it low profile). I haven't done it much, but I've locked myself out enough to have one on me. :cool:
