Price of new OEM tonneau
Discussion in 'Tonneau Covers, Caps and Shells' started by JBerg, Nov 24, 2019.
  1. Nov 24, 2019 at 1:36 PM
    JBerg
    JBerg [OP] Well-Known Member
    Josh
    4x2 2016 SR5
    I’m about to purchase a lightly used OEM tonneau for 2016 tacoma. Just wondering what a good price is to negotiate around? 200-400$ I was thinking
  2. Nov 24, 2019 at 1:37 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Make sure to include the rail caps as well, look at it carefully and see what I mean. People usually just swap them out for free with the seller.
  3. Nov 24, 2019 at 1:39 PM
    JBerg
    Josh
    4x2 2016 SR5
    So what parts are there for the OEMs? Just rail caps?
  4. Nov 24, 2019 at 1:41 PM
    OnHartung'sRoad
    You have to replace the two side rails and the corner rubber pieces. There’s also a support brace that mounts in those two holes right below your rear window in front of the bed.
    Is the seller including those? If you’re nearby, just swap them out with him. It usually works out really well that way.
  5. Nov 24, 2019 at 1:43 PM
    OnHartung'sRoad
    I forget the exact part number, but I had to end up buying two new side rail caps and they were over $100 each. It was because I stupidly shipped them off to New York from California, and the buyer did not want to send back the swapped rails. Big mistake don’t do this!
  6. Nov 24, 2019 at 1:49 PM
    OnHartung'sRoad
    Also, be sure to check the cover carefully before you buy it, there are some support posts built into it to hold the first and second leaves level when it is opened up that break off rather easily if there is a lot of pressure on top of the cover when it is opened up (Like from an idiot sitting or standing on it). I’ve seen several of those support posts broken, even on used Tacomas at the dealer.
  7. Nov 24, 2019 at 1:57 PM
    JBerg
    Josh
    4x2 2016 SR5
    Got my thank you. Yes he’s near by so that works out well. I’ll be sure to install it with him there.
