Price on DT Long Tubes GOING UP!!!
Discussion in 'Underdog Racing Development' started by Gadget@URD, Dec 11, 2010.
  1. Dec 11, 2010 at 8:36 AM
    Gadget@URD
    Gadget@URD [OP] Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    Thorley had made some improvements in their Long Tube Headers for the 4.0L.
    They have a larger primary tube now, 1 5/8" up from 1 1/2".
    The tubing is now 304 stainless instead of mild steel. Flanges are still mild steel.
    Still come with the bright ceramic coating inside and out.
    I got them to install two O2 bungs per side. The normal location in the center primary tube is still there. I got them to add a second one on the collector. You can screw a wideband sensor in there if you want, or you can get an extension harness from URD that will allow you to relocate the front O2 sensor to the collector. This is good for people running the X-1 so it will sample the AFR from all the cylinders under power for controlling the fuel mixture instead of just one.
    These improvements have caused the price to go up. I still have them on the URD site at $515 but will be going to up to $545 next week.
    I just got a big shipment in and can ship right away.
    If you want to get a set before the price increase act now!!
    http://www.urdusa.com/product_info.php?cPath=93_120&products_id=1260519027
    G
  2. Dec 15, 2010 at 3:22 PM
    ironman_jon
    ironman_jon Well-Known Member
    Jonathan
    Prerunner Sport
    URD TCAI Wicked Flow 18" 2 10in alpine type r 1500 watt amp MB 72 matte black Custom Bumper Debadged Glassworks fenders McNeil bedsides Helix TB Spacer Intake Manifold Spacer Custom Roof Rack 5x 55w HID SK2 projectors 55w DDM 5k Bulbs Camburg Long Travel Fox Coilovers
    So are the ones I got in today stamped with the date 11-8-10 the new design or the old one ....I ordered these at the beginning of the month
  3. Dec 15, 2010 at 9:21 PM
    Gadget@URD
    New.
    Should have two bungs in each header.
    G
