Price to fix?
Discussion in '1st Gen. Tacomas (1995-2004)' started by brigas, Jul 27, 2012.
  1. Jul 27, 2012 at 2:09 PM
    brigas
    brigas [OP] Active Member
    How much would it cost for a decent job to get this painted at a paint shop?
    What about doing it myself?
    Thanks
  2. Jul 27, 2012 at 2:12 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    in order to paint that id think you would have to paint your whole cab to get it to look right.....
    just my first thought, i dont know much about painting.
  3. Jul 27, 2012 at 2:12 PM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    As far as cost I don't know. If you have never sprayed auto paint before and don't know how to blend the paint I wouldn't try that yourself.
  4. Jul 27, 2012 at 3:57 PM
    Smokey11
    Smokey11 You Can't Fix Stupid !
    Jeremy
    Anchorage, Ak
    99 ex-cab TRD 2.7L 4X4
    OME 881, 10MM top plate spacer,nitros,wheelers 5 pack, 1.25 Daystar Shackles,265-75-16 Duratracs on 16X8 Pro Comps,leer shell, husky liners, sway bar removed, X-runner badges, tint, auto start, BPV relocate, extended rear brake line.
    ^This....dont try it yourself if you have never painted and you want it to look factory. To do it correct you would have to blend it down the A,B and C pillar which isnt that bad and would take a shop about 2 days to do if they arent busy. I would say anywhere from $500-$1000 depending on which shop you go to.
  5. Jul 27, 2012 at 4:24 PM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    I'd paint the whole truck, I'm thinking to patch that up it'll be around $600+ Hows the side paint?
  6. Jul 27, 2012 at 4:26 PM
    TherealScuba
    TherealScuba Well-Known Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Why paint the whole truck if its just the roof?
    Its not like everyone is going to look for different shades of black on top of a truck. :rolleyes:
  7. Jul 27, 2012 at 4:27 PM
    brigas
    Everything else is in OK condition. Just the roof bugs me a lot
  8. Jul 27, 2012 at 4:31 PM
    pippen
    Pippen
    Eastern NC
    04 PreRunner Ext.
    Ok then if the rest is fine then yea I can see fixing that bad part is ok enough. I'd take it to a couple shops and ask for a quote, unless you've sprayed before it can be challenging for some. For me the clearcoat is the hardest.
  9. Jul 27, 2012 at 4:32 PM
    Smokey11
    Jeremy
    Anchorage, Ak
    Depends on how long you want it to last as well, get it done for a couple hundred at MACCO but wont last but maybe a couple years. If you plan on keeping the truck I would take it and have it done right the first time.
  10. Jul 29, 2012 at 1:12 AM
    DarkShark
    DarkShark Well-Known Member
    Clark
    Medford/Southern Oregon
    03 DCab 4wd
    Icons, Camburg and custom stuff......
    ^^x2
    Never use dish soap on your truck(that could be what did it atleast on my old mans truck it is lol) wax it once a year or more.
  11. Jul 29, 2012 at 3:23 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    The same thing happened to my visor that I had on my '99. I took it to Maaco and let them put a coat on it for about $100. After that, I clay barred and waxed the rest of the truck. Everything blended pretty nice. About 3-4 years later, the frame rust kicked in and the truck went back to the factory. At that point though, it still looked great. And that was 3-4 years of NJ winters. Just my thoughts.
  12. Jul 29, 2012 at 8:55 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Well if I were to repair that I would not have Maco touch it unless the truck is a piece of shit and you were looking to sell it. Remember you get what you pay for.
    A decent complete would run at least $5K.
    Painting the cab roof is a lot of work as the whole truck would have to be protected from over spray. ( Something Maco would try and fail at.)
    Most of the time when doing a panel repair the problem is where to stop, if I do the roof should I do the whole cab, then whats the that going to look like, is it going to match compared to the rest of the truck if its faded, you can't add some fade to the paint cup, to get a close match!
    When I was painting for a living customers would say as long as you have some paint in the gun, could you spray this or that, the hard part is getting to the point where you fill the gun with paint ( preparation ).
    A good shop can blend the pillars and I think the price is going to be close to $1K for a decent job.
    I refinished the box, tailgate, and front and rear bumpers, and had $500 in material alone.
  13. Jul 29, 2012 at 8:59 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    I'd plasti dip the roof no question. 20 bucks...
  14. Jul 29, 2012 at 11:28 AM
    BrianLV
    BrianLV Well-Known Member
    Las Vegas
    04 Prerunner SR5
    Herculiner, less than $100 lol
  15. Jul 29, 2012 at 1:12 PM
    magic
    magic Well-Known Member
    what if he did all the preperation ( sanding/removeal of plastic pieces) then took it to a place for a cheaper paint job like 400-500 bucks then put all the pieces back on himself?
  16. Jul 29, 2012 at 1:31 PM
    brigas
    Plastidip sounds like a good cheap temporary fix. How long will it last in good weather?
  17. Jul 29, 2012 at 1:34 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    No... NO! :eek:
  18. Jul 29, 2012 at 1:55 PM
    brigas
    Why not?
  19. Jul 29, 2012 at 1:59 PM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Why would spending hours applying cheap, ugly spray on rubber coating be better than just having faded clearcoat? :confused:
  20. Jul 30, 2012 at 5:47 AM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    That would be OK if that person had the tools and knowledge on how to remove and prep.
    I would of course not guarantee that the top coat would be in factory like condition after spraying as armatures have no idea what they are doing, they contaminate the surface with dirty hands,sand body oil into the existing finish, don't use the proper chemicals to clean the surface before sanding, the proper grit sand paper, that produces fish eye's, and just a poor finish.
    Ya have to pay if you want to play, with quality base coat costing upward to $100 a pt, not to include the rest of the items needed why try to do it on the cheap if you don't know what you are doing!
