Prices for 3 and 6in lifts?
Discussion in 'Suspension' started by Bigbizzle, Feb 14, 2010.
  1. Feb 14, 2010 at 4:21 PM
    Bigbizzle
    Bigbizzle [OP] Member
    05 PreRunner SR5
    chrome nerf bar, kenwood head unit
    I'm lookin for a lift but i'm tight on money what are some rough estimates for the cheapest 3in suspension lift and cheapest 6in suspension lift?
  2. Feb 14, 2010 at 4:24 PM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    Well you can pick up a 3 in, OME for about $700. You can pick up a Pro comp stage 1 spacer lift for around $1800.
  3. Feb 14, 2010 at 4:27 PM
    Bigbizzle
    05 PreRunner SR5
    do you know around how much it would be for a 3in suspesion lift with a 3in body lift on top of that?
  4. Feb 14, 2010 at 4:33 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    cheapest and lift dont go together.save up and do it right.
  5. Feb 14, 2010 at 4:36 PM
    dgalleon
    dgalleon Well-Known Member
    Central Florida
    09 TRD Sport 4x4 Dbl Cab LB
    TRD CAI, Flowmaster 40 series, 6" Fabtech Lift, Dirt Logic rear shocks
    ^^^^ what he said:eek:
  6. Feb 14, 2010 at 4:58 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Haha, like that would happen;)
  7. Feb 14, 2010 at 5:05 PM
    The End
    The End Support our troops!
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    2.5 King RR in front, LR ucs' s, 2.0 King RR rear, B.A.M.F shock mounts, ATO shackle flip, 4X sliders, ARB front bumper with XRC8, CBI hc rear, weathertechs, Leer cap, Thule rack, ubolt flip, etc.
    3 inch pro comp suspension lift $377 shipped, truckaddons.com. But I would get the toytec because they are a sponsor here and have heard nothing but praise.
  8. Feb 14, 2010 at 5:12 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    6" breakdown:
    well, 4" spindle will run $1000, then get some ext brake lines for the spindle for $90, then get some 5100s for ~$200 and set them at 2.5", then get an AAL for $70, then get some longer rear shocks for ~$180, then get some 285s for ~$700, then get an alignment for ~$60. dont forget about labor on the install or the new brake fluid required for a bleed w/ the install of the front lines.
    as you can see, nothing is cheap when lifting a truck, your looking at least $2400 for the above.
    3" breakdown:
    pick up some 5100s from downsouthmotorsports.com for ~$300, then get an alignment for ~$60. this will cover front at 2.5" lift, and brand new rear shocks. it doesnt look bad at all running the stock 265 tires either...
    ...but you would have already known all the above if you simply would have searched, read the lift sticky, or just browsed some lift threads...
