Pricey TOYOTA a/c panel lights
Discussion in 'Technical Chat' started by Geezertaco, Feb 20, 2016.
  1. Feb 20, 2016 at 9:42 PM
    Geezertaco
    Geezertaco [OP] Member
    2006 tacoma TuRD 4x4
    Driveline disconnect for towing behind mohome.
    I'm new to the site. I have an '06 TuRD TACO 4x4. The a/c panel lights died a few moons back and Toyota wants my first born in payment for one bulb. Not bad except I need two. I went to Amazon and got some LEDs that were supposed to fit my vehicle. They didn't. I contacted the vendor thru Amazon and 'splained the issue. He/she said to turn the LED 180 degs and it should work. Uh...The hole's too SMALL. Ok, I attempted to install after turning the LED 180 degs and hey! Check it out... The hole's STILL to small.
    Let me back up a bit. Prior to trying to insert the light, I checked for juice and I had 7.5 vdc at both sockets. after attempting a second insertion, I have no volts. None! I do have instrument lights at the speedo etc
    I checked the fuses under the dash on the drivers side as well as under the hood. Can't locate any fuse marked cluster except the 7.5 amp under the dash marked Gauges.
    Anyone have any ideas aside from use a flashlight? Anybody?
    DustStorm4x4 likes this.
  2. Feb 21, 2016 at 5:43 AM
    Cohutta
    Cohutta Well-Known Member
    Georgia
    2011 4x4 AC 2.7
    Dog hair
    Have you lost any other lights since the voltage disappeared at the sockets? Certainly sounds like a fuse issue, but if you've been through them already I can't imagine what else it would be.
    Unlike you, I took out a second mortgage on my house and bought two of those bulbs from a dealership. How two incandescent bulbs the size of a fucking a thumb tack can cost $12 each is beyond me...
  3. Feb 21, 2016 at 5:51 AM
    awhitfield4
    awhitfield4 Well-Known Member
    Knoxville, TN
    $12 bucks! Dang, but now that I have read this I will probably pay it when the time comes to avoid the hassle. That does for sure sound like a fuse issue though.
  4. Feb 21, 2016 at 2:48 PM
    Geezertaco
    I still have my dash lights such as speedo, tach, etc. Lost my 4x4 rotary switch light and lockup button light. But I lost those a couple of years back. I just recently decided to see 'bout replacing the a/c panel lights. Guess I shoulda stayed with the flash light.
    The only major thing I would want to if it could be done is to replace the electro controlled transfer case with a unit with a neutral position so I can tow it without a driveline disconnect.
    I've thought of perhaps using a plugin map light to illuminate the panel.
  5. Feb 21, 2016 at 2:55 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB, '97 4Runner SR5 5spd
  6. Feb 22, 2016 at 1:30 PM
    Geezertaco
    Ok...2 days later...I decided to check my parking lights and found they weren't coming on. And this putz checked the tail light fuse and YUP....You guessed it. Blown. Changed it and now I got juice at the light sockets. Now to try to shave a LED to see if it will give me lite.
  7. Feb 22, 2016 at 2:21 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    Just remember, LEDs are polarity specific, if they don't work the first time, turn them 180° in the socket
    Clean off the ridges from the PC board edge, that's what was blocking mine for going in
  8. Feb 23, 2016 at 8:41 PM
    Geezertaco
    After some filing the edges of the LED back boards I was able to coach them in. Still not happy I had to modify what was supposed to be a fit, but they still work. thanks for the info.
  9. Feb 24, 2016 at 3:20 AM
    Blkvoodoo
    Kevin
    Near Clayton NC
    Look at it this way, NO, they aren't a perfect fit, but for the little elbow grease involved, you paid less for 6 of those than ONE crazy over priced bulb from Toyota.
    That's a win
