Prinsu 1x1 crossbar question.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigBeej, Dec 31, 2018.
  1. Dec 31, 2018 at 9:51 AM
    BigBeej
    BigBeej [OP] Well-Known Member
    Bryan
    Vista, Ca
    About to install my new prinsu and wanted to know a couple things about the 1x1 crossbar for the rear of it. One, where is the best place to get one and two, what length is needed if I was to source from say Tnutz or somewhere?
  2. Dec 31, 2018 at 10:02 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Cbi has them, or any Prinsu distributor. I left the last bar off on our 3rd Gen.
    In fact I actually drilled out another hole to be able to mount the last bar vetical behind the shark fin. I did it that way do that when carrying our Canoe up top I could put the rear bar on- but otherwise it’s a 5 bar setup.
  3. Dec 31, 2018 at 10:21 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    You want 47” wide and Tnutz is the cheapest place I have found.
  4. Dec 31, 2018 at 10:31 AM
    BigBeej
    Bryan
    Vista, Ca
    Perfect, thank you. Also, do you know what the ends are tapped at? 1/4-20 or M6? Guessing the M6?
    Sub_Par[QUOTED] likes this.
  5. Dec 31, 2018 at 11:17 AM
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    1/4-20
