Prinsu Access Cab Install
Discussion in 'PrInSu Design Studio' started by GHOST SHIP, Mar 16, 2016.
  1. May 6, 2017 at 7:56 PM
    #181
    GHOST SHIP
    GHOST SHIP [OP] hates you.
    GHOST
    Me and the truck owner (about 180 lbs each) both stood on top of the rack once we had it on. It's super sturdy.
    :muscleflexing:
  2. May 7, 2017 at 6:46 PM
    #182
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I siliconed the hell out of the inside of the rivnnuts, and put the bolts back in. Lets hope i stay dry from now on
    DaveEli and GHOST SHIP[OP] like this.
  3. May 7, 2017 at 8:57 PM
    #183
    GHOST SHIP
    GHOST
    One thing I found when applying silicone is if you add just enough around the surface where the bolt shoulder will sit so that when you tighten everything down, you should get a nice even swell of silicone around the bolt. A lot of people try to smear it around thinking it'll seal better, but I advise to resist that urge and just let it dry and you should be good to go.
    DaveEli and fatfurious2[QUOTED] like this.
  4. May 8, 2017 at 4:39 AM
    #184
    fatfurious2
    David
    Ashburn, VA
    I didn't smear it around the bolt heads, but i kinda did a 2nd bead around the rivnut, and i tried to connect it there. Don't know if it will work. I might try it today. Its been about 12 hours of curing
    DaveEli likes this.
  5. May 10, 2017 at 4:57 PM
    #185
    fatfurious2
    David
    Ashburn, VA
    @DaveEli when are you installing the Prinsu?
    DaveEli likes this.
  6. May 10, 2017 at 5:02 PM
    #186
    DaveEli
    DaveEli Well- Known Member
    David
    Virginia Beach
    2011 Tacoma Sport 4X4
    Icon Extended Travel Coilovers, King 700lb springs, All-Pro Expo leaf springs, All-pro U-Bolt flip kit, Icon 2.0 Series custom length rear shocks, Wheelers Superbump Bumpstops, All-Pro extended rear brake lines, Warn 86255 VR10000 10,000 lb winch, Warn 90287 wireless remote, Redline Hood Struts, AVS Bugflector II, Pelfreybilt front bumper with Rigid 92031 SR- Series White 20" Spot/Flood lightbar, Brute Force rear bumper with short swingarm, Famous Fabrication Rock Sliders, Pelfreybilt Skid Plates, Rigid 50231 D2 Driving Lights, Rigid 20221 Dually Spotlights, Rigid 98000 SR-M backup lights, ARB CKMTA12 "12V"on-board twin high performance air compressor, Dick Cepek DC-2 17x9" wheels, 285/70R17 Goodyear MTRs with Kevlar tires, Wet Okole seat covers,Airflow snorkle, ARE CX HD cap, Front Runner Slimline II cap rack, TRD cat back exhaust, AVS in channel window vents, Toyota door sill protectors, Pop & Lock tailgate lock, Husky Rear floorliners, WeatherTech Front Floorliners, DeeZee bed mat, Window tint, TRD drop in air filter, Plasmaglow led bed lights, Hi-Lift jack mounted on bed rail, IMMRYO Rear View Mirror Relocate, ARB 63 Quart fridge freezer, Arb ARB209 Snatch Block, ARB ARB730US 3" x 10' Tree saver, ARB ARB705US 2-3/8" x 30' recovery strap, Bubba Rope 7/8" x 30' original rope 28600 lbs, Bubba Rope Gator Jaw soft shackle 7/16.
    Not sure.
    fatfurious2 likes this.
  7. May 10, 2017 at 5:05 PM
    #187
    fatfurious2
    David
    Ashburn, VA
    this weekend?
  8. May 10, 2017 at 5:08 PM
    #188
    DaveEli
    David
    Virginia Beach
    No it will be awhile. Have some family issues to take care of.
  9. May 10, 2017 at 9:41 PM
    #189
    kingk0ng
    kingk0ng Well-Known Member
    11 TRD OR AC
    just a few things.
    how long does this install take? im interested in getting the rack but scared about the air bag part. if i go to you @GHOST SHIP can you help me out?
    DaveEli likes this.
  10. May 10, 2017 at 10:47 PM
    #190
    GHOST SHIP
    GHOST
    I don't mind helping but it's really not that bad. Patience is the key and going slow will help you avoid damage. Just remember you're not drilling into a 2x4 and let the drill bit do the work.
  11. May 11, 2017 at 4:27 AM
    #191
    DaveEli
    David
    Virginia Beach
    Make sure to remove the headliner. Don't drill blind.
  12. May 11, 2017 at 4:32 AM
    #192
    fatfurious2
    David
    Ashburn, VA
    A 2nd person helps
  13. May 11, 2017 at 4:35 AM
    #193
    DaveEli
    David
    Virginia Beach
    Definitely.
  14. May 11, 2017 at 4:39 AM
    #194
    fatfurious2
    David
    Ashburn, VA
    This is the final test of mine. Hopefully its not leaking!! :annoyed:
    DaveEli likes this.
  15. May 11, 2017 at 5:23 AM
    #195
    fatfurious2
    David
    Ashburn, VA
    It didnt leak on the way to work. I was dry! :bananadance:
    kingk0ng, GHOST SHIP[OP] and DaveEli like this.
  16. May 11, 2017 at 11:36 AM
    #196
    fatfurious2
    David
    Ashburn, VA
    Test number 2.. raining for 6 hours
    DaveEli likes this.
  17. May 11, 2017 at 11:39 AM
    #197
    fatfurious2
    David
    Ashburn, VA
    All dry! Id say we are good!
  18. May 11, 2017 at 11:44 AM
    #198
    DaveEli
    David
    Virginia Beach
    Sounds like you are good to go. :thumbsup:
    fatfurious2[QUOTED] likes this.
  19. May 11, 2017 at 2:19 PM
    #199
    GHOST SHIP
    GHOST
    Since you did get a little water intrusion before that, I'd recommend dropping the headliner to double check for rust. The tiny metal shavings that were made when you drilled the holes the first time will rust incredibly fast. This could potentially leave rust stains in your headliner or worse, spread to other hidden sheet metal. I know it sounds like a PITA, but an ounce of prevention and all that.
  20. May 11, 2017 at 2:28 PM
    #200
    fatfurious2
    David
    Ashburn, VA
    I may do this when its going to be dry for a while. I kind of want to apply more silicon from the bottom as well.
    Thanks for the heads up. I did blow all of those metal shavings out of the roof channel, and as many as I could find on the inside of my cab. Im not sure if any are on the headliner
    DaveEli likes this.
