Prinsu Access Cab Install
Discussion in 'PrInSu Design Studio' started by GHOST SHIP, Mar 16, 2016.
  1. Sep 6, 2016 at 4:03 PM
    #41
    DaveEli
    DaveEli Well- Known Member
    David
    Virginia Beach
    2011 Tacoma Sport 4X4
    Icon Extended Travel Coilovers, King 700lb springs, All-Pro Expo leaf springs, All-pro U-Bolt flip kit, Icon 2.0 Series custom length rear shocks, Wheelers Superbump Bumpstops, All-Pro extended rear brake lines, Warn 86255 VR10000 10,000 lb winch, Warn 90287 wireless remote, Redline Hood Struts, AVS Bugflector II, Pelfreybilt front bumper with Rigid 92031 SR- Series White 20" Spot/Flood lightbar, Brute Force rear bumper with short swingarm, Famous Fabrication Rock Sliders, Pelfreybilt Skid Plates, Rigid 50231 D2 Driving Lights, Rigid 20221 Dually Spotlights, Rigid 98000 SR-M backup lights, ARB CKMTA12 "12V"on-board twin high performance air compressor, Dick Cepek DC-2 17x9" wheels, 285/70R17 Goodyear MTRs with Kevlar tires, Wet Okole seat covers,Airflow snorkle, ARE CX HD cap, Front Runner Slimline II cap rack, TRD cat back exhaust, AVS in channel window vents, Toyota door sill protectors, Pop & Lock tailgate lock, Husky Rear floorliners, WeatherTech Front Floorliners, DeeZee bed mat, Window tint, TRD drop in air filter, Plasmaglow led bed lights, Hi-Lift jack mounted on bed rail, IMMRYO Rear View Mirror Relocate, ARB 63 Quart fridge freezer, Arb ARB209 Snatch Block, ARB ARB730US 3" x 10' Tree saver, ARB ARB705US 2-3/8" x 30' recovery strap, Bubba Rope 7/8" x 30' original rope 28600 lbs, Bubba Rope Gator Jaw soft shackle 7/16.
    I have access to one of those tools from work.
    I'm not going to use the plusnuts at all. I'm going to use regular steel nontwist rivet nuts, and lock them in from the inside with washers and nylock nuts. Since I'm removing the headliner it will be easy. I'll be a lot happier not dealing with the plusnuts, they have my number. Thanks again for your help.
    GHOST SHIP[OP] likes this.
  2. Sep 6, 2016 at 5:36 PM
    #42
    GHOST SHIP
    GHOST SHIP [OP] hates you.
    GHOST
    If you're going to go through the trouble of dropping the headliner, you could just use stainless nuts and bolts with washers as a cheaper alternative. But it's your call.
    Also if you need help with dropping the headliner i got you:
    https://www.tacomaworld.com/threads/removing-your-headliner-and-insulating-sound-deadening.394469/
    DaveEli[QUOTED] likes this.
  3. Sep 6, 2016 at 6:12 PM
    #43
    DaveEli
    David
    Virginia Beach
    I've got all the hardware already. Been reading your posts about the headliner and sound deadening already. It's been a big help.
  4. Sep 6, 2016 at 6:26 PM
    #44
    GHOST SHIP
    GHOST
    Sweet! Good luck man. Be sure to post up pictures or reach out if you need anything else.
    :thumbsup:
    DaveEli likes this.
  5. Sep 6, 2016 at 6:30 PM
    #45
    DaveEli
    David
    Virginia Beach
    Will do.
  6. Sep 9, 2016 at 7:37 AM
    #46
    DaveEli
    David
    Virginia Beach
    Not looking to good for me. No way to drill for the rear mount. Airbags run from the dash to the rear window. The bags and the brackets for the bags are right up against the channel in the rear right where i need to drill. Good thing I dropped the headliner. Even in I moved the bags to drill and install the nuts there wouldn't be room for the screws. I don't really want to move the airbags. Any ideas?
  7. Sep 9, 2016 at 8:56 AM
    #47
    GHOST SHIP
    GHOST
    We had that issue with the center mounts. The airbags were right up against the channel and we had to be super careful drilling those holes. We had just enough room to wedge the airbags to the side and drill the hole and get the rivnut in. If you feel like the hardware might be an issue, perhaps a shorter fastener would help. The bolts only need to catch the threads of the rivnut to be secure, anything past that is unnecessary. Since you're using different hardware im not sure if that will work for you in the same way, but a visual might help us come up with a solution. Maybe post a picture of the clearance issue?
  8. Sep 9, 2016 at 9:08 AM
    #48
    DaveEli
    David
    Virginia Beach
  9. Sep 9, 2016 at 9:09 AM
    #49
    DaveEli
    David
    Virginia Beach
    The silver bracket is touching the channel. How are people doing this with the headliner in?:eek:
  10. Sep 9, 2016 at 9:19 AM
    #50
    GHOST SHIP
    GHOST
    Oh wow, that is tight. When we did ours, I started by drilling a small pilot hole and slowly moved up in size with a unibit checking for clearance each time I sized up the hole. I don't exactly remember but I believe that there is the slightest amount of clearance there behind the sheet metal and the airbags. So other than saying your prayers and going slow from the top, the only thing I can think of would be to try to find a way to move the bracket/bag. Is there any way to remove the bracket temporarily or otherwise get it out of harms way?
  11. Sep 9, 2016 at 9:25 AM
    #51
    DaveEli
    David
    Virginia Beach
    It's possible, but with the nut sticking down after install, ( will stick down as much as a plusnut) not sure I'll be able to get everything back in place. Then get all the plastic pieces back on properly. I'm kind of at a loss as what to do. Don't want to drill only to find out it won't work. This sucks.
  12. Sep 9, 2016 at 9:41 AM
    #52
    GHOST SHIP
    GHOST
    Sorry to hear man. If you were closer I'd help you out. Give it a day to think about it and a solution might present itself. It always helps to take a step back for a minute.
  13. Sep 9, 2016 at 9:45 AM
    #53
    DaveEli
    David
    Virginia Beach
    Thanks. I'm going to install the soundproof stuff tonight and keep looking at it. I haven't totally given up yet. How much strength do you think I would loose if I only used one bolt in the back mount? I would loose the front screw in the back mount. Just thinking.
  14. Sep 9, 2016 at 9:51 AM
    #54
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    Op do you have more pics of the installed rack?
  15. Sep 9, 2016 at 9:51 AM
    #55
    GHOST SHIP
    GHOST
    You actually wouldn't loose too much strength. Once everything else is bolted in, it all braces against itself and is really sturdy. IMO, You should be fine missing just the one.
  16. Sep 9, 2016 at 9:52 AM
    #56
    GHOST SHIP
    GHOST
    I can get some. What do you need?
  17. Sep 9, 2016 at 9:54 AM
    #57
    DaveEli
    David
    Virginia Beach
    Hopefully I'll figure something out. Did you disconnect the batt when you were working around the airbags? I'll keep you posted what I decide.
  18. Sep 9, 2016 at 9:54 AM
    #58
    THE CALICO
    Colton
    Nashville
    Just curious around were it actually mounts in the channel and the overall look. I saw in another post where some one installed one of these on an access cab and it looked a little funky. From the pic I saw of yours it looked great just wanted to verify.
    EDIT: I'm was thinking of where some one put a front runner rack on an access cab looking funky. Not the Prinsu.
  19. Sep 9, 2016 at 9:56 AM
    #59
    GHOST SHIP
    GHOST
    Battery stayed in place. Good luck.
  20. Sep 9, 2016 at 10:00 AM
    #60
    GHOST SHIP
    GHOST
    How's that? I added those to the first post.
