Prinsu Access Rack Cautionary Tale
Discussion in 'Product Reviews' started by Bman4X5, Mar 12, 2015.
  1. Mar 12, 2015 at 10:19 AM
    Bman4X5
    Bman4X5 [OP] There is no substitute for square inches.
    Bruce
    Upland CA
    '15 AC/OR
    Bilstein, Dakar/Icon, Prinsu, CBI, Pelfreybilt, Tepui
    I took delivery of my Prinsu rack and installed it last month on my '15 Access Cab Off Road. Access cabs lack factory bolts under the weather stripping, and so it is necessary to drill through the sheet metal and install plusnuts. The install went OK, and the rack is stout and good looking. No complaints regarding the rack itself.
    When drilling the plusnut holes, I followed Zach's advice and started with smaller bits and worked my way up. Brand new heavy duty bits. Several times the drill grabbed the sheet metal and forcefully drove itself farther than necessary into the roof. I was actually worried that I might pierce the headliner, but that didn't happen. Got the holes drilled and the rack installed. Home free, right?
    I noticed that the dome and map lights weren't working, so took it to the dealer this morning. They told me that whoever installed the rack (me...) drilled right into the wiring harness on the driver's side, and that IF they can repair the harness it will cost me $670. I don't even want to know what the tab will be if they have to replace that section of harness...
    So, if you are going to install an Access Rack, you need to figure out a way to drill JUST FAR ENOUGH to get a smooth hole for the plusnut. Perhaps a step-drill would be the solution.
    I love the rack, as does everyone else, but keep this issue in mind when installing.
  2. Mar 12, 2015 at 10:21 AM
    Large
    Large Red
    With your skill set you could fix the harness yourself for under $10 and it would take an hour. This is good info nonetheless to anyone wanting to install the rack. Maybe the 15s had their harnesses moved?
  3. Mar 28, 2015 at 8:25 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Typically, not bashing, but any time I drill or cut, I look behind and make sure nothing is behind. While it could have been mentioned in instructions, I wouldn't let the stealership do it for 650+. An hour or two tops with some wire, shrink tube, and a soldering iron can save you serious cash.
  4. Jul 28, 2015 at 9:59 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
  5. Jul 28, 2015 at 10:18 AM
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    "Drilling for prinsu access cab rack cautionary tale"
