Prinsu AccessRac Physics!? No this isn't April Fools.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Comatose, Apr 1, 2018.
  1. Apr 1, 2018 at 9:08 PM
    badger
    badger Well-Known Member
    07 SR5
    you could build a recoilless spud cannon.
    Comatose[OP] likes this.
  2. Apr 1, 2018 at 9:08 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    My $.02:
    Rivnuts are not high torque fasteners. Meaning that they are made of material that is specifically meant to be bent (during install). The threads are made of that same material so if you torque down on them, the fastener will easily strip the threads. That being said, their use in installing a prinsu rack is justifiable because you aren’t “pulling” the rack away from the truck, on the contrary any weight that you add to the rack is pushing it down and the rivnuts are just there to keep the assembly from sliding off the roof of your truck.
    Think of it like those plastic drywall anchors. Sure they’re strong, but they have their limits. More anchors means “more stronger”, but again- within limits.
    That being said, recoil forces would put lateral force (shear tension) on the fasteners (bolts), not the rivnuts, so I think you should be good to go. I have no experience with spud guns but can’t inagine they’d rip out all your rivnuts as long as everything is mounted properly.
    Worst case scenario, replacing rivnuts is an easy fix. :notsure:
  3. Apr 1, 2018 at 9:09 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    noted.
    carry spare rivnuts
  4. Apr 1, 2018 at 9:11 PM
    Comatose
    Comatose [OP] You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    Possibly spare roof as well. :anonymous:
    Biscuits likes this.
  5. Apr 1, 2018 at 9:13 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    As kids we used to pack them full of spuds soaked in paint thinner and ignite them with starting fluid. Home made :bananadead: launcher. Hypothetically speaking
    Kmalloy and Comatose[OP] like this.
  6. Apr 1, 2018 at 9:19 PM
    Comatose
    Miguel
    San Diego, CA
    To peak your interests in this further, I would hypothetically tie a video feed into the backup camera input for my deck. For targeting :infantry:
  7. Apr 1, 2018 at 9:34 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Hypothetically speaking, how soon would this be completed?
  8. Apr 1, 2018 at 9:38 PM
    Comatose
    Miguel
    San Diego, CA
    Well seeing as I'm hypothetically in the CAD phase, quite some time.
  9. Apr 1, 2018 at 9:46 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    In testing the best we could do was 1 kilometer. This was a propane and zippo fluid hybrid. It was able to penetrate a 70’s Winnebago from 30’. Lesson for camping with animals. Don’t bang the girl who broke up with the best buddy of the owner of the potatoe cannon an hour ago. That is unless your RV needs more ventilation.
  10. Apr 2, 2018 at 4:31 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Compressed air...remote fill? To what pressure? Too bad you can’t auto-load spuds. Drop a bag of potatoes in a hopper...
  11. Apr 2, 2018 at 4:43 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    But you could use a hopper full of tennis balls.
  12. Apr 2, 2018 at 7:39 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    So. Much. Like.
    You could also use it to air launch baited lines off the beach for shark fishing :rofl:
  13. Apr 2, 2018 at 7:42 AM
    FourBanger99
    FourBanger99 4 Banger Taco
    Bayne
    Birmingham
    2012 Black Tacoma 2.7 AC SR5 4x4
    Full OME Suspension CB Diff Breather Duratracs
    Wtf is going on here lol
  14. Apr 2, 2018 at 7:45 AM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    My guess would be thats why he's building it. Bunker buster for the win!
    Chase8059[QUOTED] likes this.
  15. Apr 2, 2018 at 7:54 AM
    #35
    Chase8059
    Chase
    ESVA
    I think the better question should be, how many beers did Mike have before posting this on TW last night?
    Gunshot-6A likes this.
  16. Apr 2, 2018 at 11:01 AM
    #36
    ThomasMore66
    We all knew this was true, but it doesn't detract from the awesomeness of the idea. Some of my greatest thoughts have come after 1 or 3 too many. I like the tennis-ball idea. Now I want one.
  17. Apr 2, 2018 at 11:04 AM
    #37
    Comatose
    Miguel
    San Diego, CA
    I'm working on that.
  18. Apr 2, 2018 at 11:07 AM
    #38
    Comatose
    Miguel
    San Diego, CA
    Surprisingly sober. I was at work on the island til 5 this morning. But the beers required to bring this to fruition. That's going to be the staggering number.
    Biscuits and EatSleepTacos like this.
  19. Apr 2, 2018 at 11:09 AM
    #39
    Chase8059
    Chase
    ESVA
    Ah make sense. When's the Prinsu going on?
  20. Apr 2, 2018 at 11:10 AM
    #40
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
