Prinsu+bed rack+tent+kayak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MoonCreek, Aug 29, 2019.
  1. Aug 29, 2019 at 6:35 PM
    MoonCreek
    MoonCreek [OP] New Member
    2001 tacoma dbl cab 4x4
    2.5" lift. 15x10 bulletholes wil nexus M/T 31/10.50/15
    Does anyone have an ideal setup for the following..
    2019 Tacoma trd offroad shortbed
    I currently have a prinsu cabrack.
    My goal is to be able to to haul 2 kayaks and a rooftop tent ..
    My concern is what size bed rack should I get to accommodate a tent and still have clearance for kayaks mounted on the prinsu. Any ideas ?
  2. Aug 29, 2019 at 9:43 PM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    I don’t think you can reasonable fit a tent and two kayaks. But I’d love for you to prove me wrong. Only think I can think of is staking the kayaks on top of the tent but to me that is beyond reasonable/safe.
  3. Aug 29, 2019 at 9:44 PM
    raskal311
    S. Cal
    If the kayaks are small and light enough maybe fab up something that will allow them to hang off the side?
  4. Aug 30, 2019 at 6:34 AM
    GoGoGadget
    GoGoGadget Well-Known Member
    2017 DCLB OR
    Why would it be unsafe to have the kayaks on top of the tent? Lay some foam down so the kayaks clear the ladder and strap them down. That is my plan when I move my RTT over to my C4 Fab mid height bars. Should just clear the roof rack. If not, I will use the roof rack.
  5. Aug 30, 2019 at 6:36 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    I've put boats on top of my tent. No big deal, just ratchet them down
    With that being said, a tent + kayaks on your roof is going to suck with wind resistance, noise, and body sway (Ask me how I know). But it will work
  6. Aug 30, 2019 at 6:36 AM
    raskal311
    S. Cal
    Just seem like common sense to me but to each his own.
  7. Aug 30, 2019 at 6:41 AM
    GoGoGadget
    2017 DCLB OR
    Look for a bed rack that list the top of the RTT as being flush with roof line. Which will probably limit you to bed bars, not a bedrack. The C4 Fab bars are 10" and put the RTT above the roof rack. So I imagine you need something that is only 6" or so off the bedsides. Unless you have a hardshell tent which tends to be lower, or using using a carrier that lifts it up enough off the roof rack to clear.
  8. Aug 30, 2019 at 6:45 AM
    GoGoGadget
    2017 DCLB OR
    Ghost_ed. and Atl_taco_ like this.
  9. Aug 30, 2019 at 6:50 AM
    Billy_trd
    Billy_trd Active Member
    2018 Tacoma TRD OR
    I had a custom bed rack fab'd up that has 9" of lift off of the bed rails. I have a prinsu and I just clear the top of my smittybilt RTT with the cab rack. I'll try to get a pic later.
    MoonCreek[OP] likes this.
  10. Aug 30, 2019 at 6:52 AM
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    I think the KB Voodoo Hi Rise bed bars are low enough that you could put the kayaks on teh prinsu over the top of a RTT on the bed bars. Plus, if you used j-bars for the kayaks, the curve of the kayaks on their side would give you even more room (maybe even enough to have a mid-height bed bar system).
    I doubt you'll be able to open the RTT with kayaks on the truck.
    Edit: I think people are misreading your question. You want a RTT on a bed rack system, kayaks on the roof rack, and are asking which bed bars will work, right?
  11. Aug 30, 2019 at 7:24 AM
    MoonCreek
    Thank you for all of the replys.. what I kinda Invisioned is 1 or 2 12ft kayaks on top of the roof rack. Which will hang over the bed several feet. I would probably need a bed rack short enough for the tent to sandwich between the rack and the kayaks.
  12. Aug 30, 2019 at 7:27 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I’d set up a spacer bar that you can temporarily put on the bed rack to level the kayaks when using the RTT, then take it off if you don’t have the RTT mounted.
    I have the same issue with my ARE MX shell, and have leveled it by putting a carrier on top of the shell when using the RTT. But we ended up not using that for the kayaks we got unless it’s just a short haul like from takeout back to camp. We got 2 double 18-footers that I can carry in the bed (Folbots).
    If you are using Tupperware kayaks, I’d think leveling isnt as critical as it would be for mine.
    MoonCreek[QUOTED][OP] likes this.
  13. Aug 30, 2019 at 8:40 AM
    jayandersen5
    jayandersen5 Well-Known Member
    Jay
    South Carolina
    2017 TRD Pro
    OTT Tuned Yukon 5.29s 35x12.50r17 Yokohama MTs RRW RR7-H Wheels Dobinsons MRRs RRW hybrid front bumper ATH rear swing out high clearance bumper Alucab Explorer Canopy iKamper skycamp 2.0 Diode Dynamics SS3 (x4) and SSC2 SOS Sliders C4 full skids Smittybilt X20 Gen3 10k winch Prinsu Cabrack Expedition Essentials 3TPAM Caliraised 40" light bar ExtremeLED 30" light bar Total Chaos spindle/cam tab gussets and bed stiffeners Switch Pro SP9100 Power Tray
    Think your best bet is to run some bed bars - KB Voodoo and Mobtown Offroad sell some that are low profile and also work with tonneau covers. Those should be short enough where the RTT doesn't sit above the cab so you can run the RTT and kayaks. However, as @Hextall mentioned you would need to remove the kayaks before setting up the tent.
  14. Aug 30, 2019 at 8:55 AM
    Yorick80
    Yorick80 Member
    I've thought about similar needs with a SUP, roof rack and RTT.
    Another option would be the iKamper X-cover, and mount your kayaks to that - it has its own crossbars that can support up to 65lbs.
    Or as mentioned earlier - very low profile like KBVoodoo Hi Rise crossbars with a normal RTT, and your kayaks on the prinsu.
  15. Aug 31, 2019 at 2:11 AM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    Gen 2 here without prinsu (I use a Thule set up) but I used KB hi Rise and more than enough room for a Kayak to clear. I just upgraded to a KBV mid length and still should have room for clearance.
