PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Aug 1, 2015 at 12:34 AM
    #2281
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Same here. That roof is tougher than I thought.
    Chauncey Bronson likes this.
  2. Aug 1, 2015 at 9:58 AM
    #2282
    Mako99
    Mako99 Well-Known Member
    Virginia
    2012 Taco Sport
    Has anyone taken the deflector off to see if that helps with the noise? Or using weather stripping to close the gap?
  3. Aug 1, 2015 at 10:16 PM
    #2283
    StG
    StG Well-Known Member
    Valley of the Sun, AZ
    15 DCSB TRD
    I stuffed some sections of foam pipe insulation and a pool noodle under the fairing & it helped a bit with the noise.
  4. Aug 2, 2015 at 12:58 AM
    #2284
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    So..haven't looked in here in a while...
    1st gen double cab love???
  5. Aug 2, 2015 at 5:40 AM
    #2285
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I've asked a few times with no answer :pout:
  6. Aug 2, 2015 at 9:27 AM
    #2286
    Blackdawg
    Monte
    Wyoming/St. Louis
    well wtf @zscott lol
  7. Aug 3, 2015 at 2:46 PM
    #2287
    zscott
    zscott [OP] Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Nothing for the Double Cab yet. I measured Box rockets truck and did the design but until someone local is willing to drill some holes in the roof so I can install one, it won't be happening.
  8. Aug 3, 2015 at 7:54 PM
    #2288
    pruchai
    pruchai KAMA3
    San Diego, CA
    ‘07 Saab 9-7x 4.2i (it identifies as a Tacoma)
    Not enough...
    Just picked up a set of roof Thule roof rack tracks for the shell from a local dude. He had a band new set for $70 and a used one with brand new end caps for $40, so I picked up the used one. It's in perfect condition.
    Turns out my shell roof is reinforced or whatever, but I can't find any max load rating for it. Does anyone know? I have Leer 100XQ.
    Also, these tracks came without mounting hardware, so I need to pick some up. Any suggestions on the bold length/size? Need something that wont put a hole in my skull later. Looking at the factory installed tracks, they have some king of flat bar under the roof carpet, for load distribution, I assume. Do I need to find one, or I should I just use 2" washers there and get it over with?
  9. Aug 3, 2015 at 9:11 PM
    #2289
    Trent_G
    Trent_G Well-Known Member
    Central Oregon
    Ordered a cabrac and toprac earlier this week. Can't wait.....
    One question getting ready to put Yakima base rail on canopy. As long as I stay about the same distance apart as the cab rail should I be okay? Does anyone know the exact width of the mounting holes? Are they slotted for variance? Thx
    scott96929 likes this.
  10. Aug 3, 2015 at 9:12 PM
    #2290
    Blackdawg
    Monte
    Wyoming/St. Louis
    Shame I'm not closer. Id do it
  11. Aug 3, 2015 at 9:16 PM
    #2291
    pruchai
    pruchai KAMA3
    San Diego, CA
    Not enough...
    Yes. I asked Zach about it. That's what he said
    However.... This does not compute.... my Leer 100XQ only has 41-1/2" from gutter to gutter, so I am not sure how this will work. I guess I will wait for the racks to come in and see. There is also cap roof reinforcement inside the shell, from gutter to gutter, so I would have to drill though that, which is not really a recommended thing to do....
  12. Aug 3, 2015 at 9:19 PM
    #2292
    Trent_G
    Central Oregon
    I was hoping to do it before the rack came in just to hurry the mounting process. ;) But I may have to wait if no one chimes in that knows for sure.
    On a side not I can take some pictures for you of my uninstalled Yakima kit and measure bolts to give you an idea of what you need.
  13. Aug 3, 2015 at 9:20 PM
    #2293
    pruchai
    pruchai KAMA3
    San Diego, CA
    Not enough...
    Yeah I was going to install it before the racks came, but now I'll probably have to wait....
  14. Aug 3, 2015 at 9:33 PM
    #2294
    Trent_G
    Central Oregon
    Here are some pictures of a part and tool list that may help. This is for a 52" (I'm cutting it down). Bolts are 1 1/8". Could get away with shorter ones if you didn't want to buy the end caps. I personally would just cut the excess bolt flush to the nut.
    pruchai likes this.
  15. Aug 3, 2015 at 9:40 PM
    #2295
    pruchai
    pruchai KAMA3
    San Diego, CA
    Not enough...
    Sweet! Thanks. Looks like I can purchase a set of bolts and cap nuts here for $15. May have to purchase 2 sets because I have 8 holes in each track and this kit only has 12 bolts/nuts/washers
    http://www.etrailer.com/Accessories-and-Parts/Yakima/Y8810155.html
    Trent_G[QUOTED] likes this.
  16. Aug 4, 2015 at 8:52 AM
    #2296
    zscott
    Zach
    Utah
    Large fender washers should be fine for the tracks. Both of my shells have had those and been fine. As for the bolt length, it really is going to depend on the thickness of the roof of the canopy I would get a couple sizes to test in the right range and decide on the best length.
  17. Aug 4, 2015 at 8:53 AM
    #2297
    zscott
    Zach
    Utah
    What do you mean from gutter to gutter?
  18. Aug 4, 2015 at 9:09 AM
    #2298
    pruchai
    pruchai KAMA3
    San Diego, CA
    Not enough...
    I don't know if I used a right word.... i think they are gutters? Basically the topper roof is not completely flat/smooth from side to side, but has these raised ridges on each side with 41-1/2" between them. But they do line up with the outside edges of cab weather stripping where roof racks go
  19. Aug 4, 2015 at 12:18 PM
    #2299
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Quick question for all you who have ordered...
    Do you have the driver side rubber trim piece I can have? Pretty please? Mine fell off somewhere....
  20. Aug 4, 2015 at 12:27 PM
    #2300
    pruchai
    pruchai KAMA3
    San Diego, CA
    Not enough...
    I'm keeping mine on. Just gonna punch holes in it for the risers
