PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Jun 13, 2016 at 10:03 AM
    #3941
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    you have 7x4 (2 per each side)
    Blackout14 likes this.
  2. Jun 13, 2016 at 10:13 AM
    #3942
    The_Hodge
    SC
    sounds good. i'll do a screw count w/ the extras tonight and see if i have the 4 extra to even it out. heading to OBX saturday and need all the bars for kayaks, so an actual removal wouldn't be until after then.
  3. Jun 13, 2016 at 10:26 AM
    #3943
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Got the details all set for picking up my bedrack and installing my RTT this friday. Thanks @zscott . I appreciate all the help!
    scott96929 likes this.
  4. Jun 13, 2016 at 4:29 PM
    #3944
    The_Hodge
    SC
    sooooo......do you have the standard or HD bars on the ones w/ the bare bolts?
  5. Jun 13, 2016 at 5:03 PM
    #3945
    The_Hodge
    SC
    my standard bars have the bare bolts. my HD bars have different sized bolts than the standard bars.
  6. Jun 13, 2016 at 5:15 PM
    #3946
    The_Hodge
    SC
    i didnt realize they were different sizes until i saw the 2 on my bench.
  7. Jun 13, 2016 at 5:18 PM
    #3947
    The_Hodge
    SC
    yeah...bare in the standards are larger. oh well.
  8. Jun 13, 2016 at 10:28 PM
    #3948
    HandOfGod
    HandOfGod Well-Known Member
    Tacoma TRD 4x4
    Stock
    Most people installing their rack with or without the weather stripping? I am leaning towards with the weather stripping but it looks like a pain to do. I don't trust myself to be precise enough to cut out the holes.
  9. Jun 14, 2016 at 5:34 AM
    #3949
    The_Hodge
    SC
    i marked mine and cut out the holes w/ a 3/4" hole saw drill attachment, IIRC. spacers fit pretty snug inside the holes.
  10. Jun 14, 2016 at 11:13 AM
    #3950
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Took the canoe out for a rip on the weekend, ran into a bit of a problem..
    I've got the Malone Bigfoot system mounted on the Cabrac;
    It's good, but I've still got to figure out how to raise the back mount about 2-3" to make sure the tip of the canoe clears the back end of the canopy. Last weekend I used a few foam blocks but the road in to the lake bumped both of them out. It took a pool noodle sacrifice to get the boat back home.
    I'm almost thinking something like a lift block slipped in above the bar but under the mount with longer bolts would be the best route.
  11. Jun 19, 2016 at 7:42 AM
    #3951
    bcubed
    bcubed Well-Known Member
    Brent
    Calgary AB
    Anyone figured out how to clean the oxidation off the powdercoat of the wind fairing? She's looking like a 13 year old who works at McDonald's
    pruchai likes this.
  12. Jun 19, 2016 at 8:57 AM
    #3952
    pruchai
    pruchai KAMA3
    San Diego, CA
    ‘07 Saab 9-7x 4.2i (it identifies as a Tacoma)
    Not enough...
    Mine is oxidized as hell too. Would be nice to find something that cleans that.
    EDIT: looks like Harely guys use S100 on their podercoated crank cases. Have to try that.
    http://www.s100.com/s100_eb.htm
  13. Jun 19, 2016 at 11:03 AM
    #3953
    zscott
    zscott [OP] Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Not sure if what I have is oxidization, only happens in the winter with all the road salt here, but I used scrubbing bubbles (Spray it on and let it foam up) and then some magic black detailer and it cleaned up nicely.
  14. Jun 19, 2016 at 11:54 AM
    #3954
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Other than cleaning every so often, would clear coating the fairing work?
  15. Jun 22, 2016 at 6:15 PM
    #3955
    DarkShark
    DarkShark Well-Known Member
    Clark
    Medford/Southern Oregon
    03 DCab 4wd
    Icons, Camburg and custom stuff......
    Still no 1st Gen D-Cab love?
    BYJOSHCOOK likes this.
  16. Jun 23, 2016 at 11:42 AM
    #3956
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    I may be wrong, but I think it has to do with the roof not being strong enough to support it. I'll let others confirm or refute this though.
  17. Jun 23, 2016 at 11:50 AM
    #3957
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    x2 on that^^^^
  18. Jun 23, 2016 at 11:53 AM
    #3958
    zscott
    Zach
    Utah
    These days I haven't had much time to work on new models. The 1st gen double cabs are low on the list anyway because any cost effective way of mounting the rack requires drilling which most people are not interested in. The roofs are weaker on the 1st gens just because it is a solid sheet metal piece. The second gens have a nice gutter area where two the top of the roof and the sides are welded together. That weld and the channel formed into the roof add a lot of rigidity making it much better for a rack.
  19. Jun 26, 2016 at 8:49 PM
    #3959
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    so this means no lover for the GX (120 series) either than huh?...
  20. Jun 26, 2016 at 9:49 PM
    #3960
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    Placed my order for both cab and canopy racks a few days ago. Pretty stoked!
    llibrm and BYJOSHCOOK like this.
