PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Jul 20, 2016 at 9:10 AM
    #4081
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I wouldn't mind getting a road shower at some point.. Have it run down the length of the Prinsu.
    Mad T likes this.
  2. Jul 20, 2016 at 9:12 AM
    #4082
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Also, for those of you that mounted a Plano case or the like, what were your methods of mounting? I have an idea, but curious.
    Thinking of findind a few bolts, run the head through the Prinsu cross bars, then through the case, wingnut on the inside. Then obviously washers, including rubber ones to dampen vibes and noise.
    Mad T likes this.
  3. Jul 20, 2016 at 9:13 AM
    #4083
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    Duct tape?
    geekhouse23[QUOTED] likes this.
  4. Jul 20, 2016 at 9:16 AM
    #4084
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    @Mad T will have pics, but he used u-bolts and drilled holes in the case
    XPOTRPR[QUOTED] likes this.
  5. Jul 20, 2016 at 9:23 AM
    #4085
    Mad T
    Mad T Well-Known Member
    Thomas
    Georgia
    That's what I did. A lot of people use u-bolts though and go around the rail. I might switch to that because the u-bolts are bigger so it'll be stronger. I can take pics of my setup tonight. It works. If you was a quick release use (EO) 2 mounts. They are a little more expensive but very nice and easy to take your cases on and off without having to take all your gear out. undo the screws, so on ect.
  6. Jul 20, 2016 at 9:42 AM
    #4086
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Awesome! What were the bolts you used? I was thinking maybe 6 of them should be good.
    Whats this mount you're speaking of? Interested.. Maybe I can make something at work too. Hmmm...
  7. Jul 20, 2016 at 10:03 AM
    #4087
    BYJOSHCOOK
    Josh
    Check Out My Builds
    http://www.eo2fastener.com/
    Blackout14 likes this.
  8. Jul 20, 2016 at 10:05 AM
    #4088
    Jystr
    Jystr IG: TW_Jystr
    Leesville, LA
    2016 Barcelona Red Tacoma TRDOR
    See build thread
    2" ubolts through the bottom and around two of the beams.
    Mad T likes this.
  9. Jul 20, 2016 at 10:07 AM
    #4089
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Same, but damn those things are expensive!
  10. Jul 20, 2016 at 10:08 AM
    #4090
    Jystr
    Jystr IG: TW_Jystr
    Leesville, LA
    See build thread
    Yup the racks are nice but that's a lot of money lol...
    2" ubolts from Lowes worked beautifully
  11. Jul 20, 2016 at 10:13 AM
    #4091
    BYJOSHCOOK
    Josh
    Check Out My Builds
    That's a damn pelican case or rotopax
  12. Jul 20, 2016 at 10:15 AM
    #4092
    Jystr
    Jystr IG: TW_Jystr
    Leesville, LA
    See build thread
    Plus if you are mounting three items up there...300$ in mounting hardware on top of the 500$ prinsu rack, and then roughly 350$ in the mounted items...
  13. Jul 20, 2016 at 10:18 AM
    #4093
    Jystr
    Jystr IG: TW_Jystr
    Leesville, LA
    See build thread
    Lol right? I mean I understand that someone could just steal two of my cross bars and I'm SOL but they could reasonably do that with my bed rack and id be out even more money.
  14. Jul 20, 2016 at 10:26 AM
    #4094
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Easy enough. :thumbsup: how many did you end up using?
  15. Jul 20, 2016 at 10:34 AM
    #4095
    travel_taco
    travel_taco Gentlemans Sausage
    CO
    09 Rust Bucket
    anti-fuel saving mods
    I used a Hobie mirage pro angler 12 for 2 weeks of kayak fishing in the Florida Keys. Are you planning on taking your daughter on the kayak?
  16. Jul 20, 2016 at 10:50 AM
    #4096
    Jystr
    Jystr IG: TW_Jystr
    Leesville, LA
    See build thread
    4 total per case. Two up front and then two on the last rail
    Lined up where I wanted. Made the four holes (2 holes per ubolt) then slider them in, tightened the nut onto them and then cut the excess of the ubolt so I didn't have a massive thing sticking out.
  17. Jul 20, 2016 at 10:56 AM
    #4097
    travel_taco
    CO
    09 Rust Bucket
    Id look more at the 14 then. Both are really stable in the water but I'm thinking the extra room would be useful for having your daughter on there. The only thing that would be difficult with a kid on the kayak would be when your pedaling. The front storage area is pretty deep so your kid could sit in it while you pedal :notsure:. The only big downsize to the pro anglers is they are heavy sonsabishes, if you dont have anyone helping you load/unload look into building a wheel cart.
  18. Jul 20, 2016 at 10:57 AM
    #4098
    Mad T
    Thomas
    Georgia
    Just some small M5 screws I think? I grabbed them from work. Just make sure the head is small enough to slide in the frame. Had a lot of problems with that. But I might switch to the u-bolt idea. Either work!
  19. Jul 20, 2016 at 11:10 AM
    #4099
    travel_taco
    CO
    09 Rust Bucket
    Oh the pedaling alone makes it worth while. Everytime I use my sit-in kayak I contemplate getting a pro angler just to save my shoulders. I actually had an easier time of maneuvering the pro angler than I do my 10ft sit-in. The use of a rudder, pedals, and an anchor make the pro angler not feel like its huge. The weight also adds up quickly if you park somewhat far from the launch area. Beer and fishing gear get pretty heavy lol
  20. Jul 20, 2016 at 11:45 AM
    #4100
    travel_taco
    CO
    09 Rust Bucket
    Yea that's what I had in mind, you could even take the top off the lid compartment in the front and she could sit in it. I think it was maybe 6-8" deep.
    Either way sounds like a great idea to kayak and still spend time with your kid :thumbsup:
