PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Jan 4, 2017 at 3:18 PM
    #5221
    zscott
    zscott [OP] Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    If you have the cutout and no lightbar it is going to make noise. No way around it except to put a lightbar on.
    pixelsailor likes this.
  2. Jan 4, 2017 at 4:06 PM
    #5222
    pixelsailor
    pixelsailor TTC #33
    Ben
    San Antonio
    Devourer of wallets
    things
    Welp, time to find a simple light bar. Anyone have a recommendation for one that won't break the bank? Looks like I need to do some research on installation.
  3. Jan 4, 2017 at 4:08 PM
    #5223
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    TRS has a good 40" for I think $300 or so. Bunch of guys run them
  4. Jan 4, 2017 at 9:05 PM
    #5224
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
  5. Jan 4, 2017 at 9:10 PM
    #5225
    ETXTacoma
    Steven
    Tyler, Texas
    I looked at the first post but did not see anything about it.
  6. Jan 4, 2017 at 9:18 PM
    #5226
    ETXTacoma
    Steven
    Tyler, Texas
    Blackout14 likes this.
  7. Jan 4, 2017 at 9:23 PM
    #5227
    ETXTacoma
    Steven
    Tyler, Texas
    I need to just go ahead and get the full size spare before I need it. Random google gave me that Yakima mount so wanted to see.
    Racks look so bare without anything mounted on them...
    So going to do Plano Case for Recovery/Spare Parts, Rotopax for fuel, and Maxtrax :spy: on the front rack and then do full size spare and the waterport on the shell rack along with the two awnings...
  8. Jan 5, 2017 at 6:23 AM
    #5228
    ETXTacoma
    Steven
    Tyler, Texas
    Will be a while before I am able to do a Swingout, so next best thing I guess.
  9. Jan 8, 2017 at 5:35 AM
    #5229
    ExpoFishTaco
    ExpoFishTaco Well-Known Member
    Charlotte NC
    '13 4X4 SR5 Double Cab
    None yet!
    Hey Zach just checking what current lead times are. Emailed a couple of times to check the status of my order but haven't heard back. Was hoping to get it before an upcoming trip but doesn't look like that will happen. Hope things are going well!
  10. Jan 8, 2017 at 4:58 PM
    #5230
    breader3
    breader3 2016 TRD Off-Road 4x4
    Brad
    Las Vegas
    Fundillo, Jamart5, ETXTacoma and 3 others like this.
  11. Jan 10, 2017 at 5:03 PM
    #5231
    Infernomedic
    Infernomedic Well-Known Member
    Matthew
    Murfreesboro Tennessee
    2016 Inferno Tacoma
    Prinsu Rack Bed cover
    Little something Ive been working on... Roof Rack Bike mounts using Yakima Parts...
    Parts Used: Yakima Landingpads
    Yakima Control Towers #11
    3/16 aluminum
    custom lathe milled inserts (could be made with washers...)
    **will be connecting to rack with 3/4 inch 1/4-20 carriage bolts and lock washers. this will allow for wide bars and narrow round bars with endless possibilities. can get the control towers and landing pads very cheap on eBay. With short round bar used.. ill still be about to mount the plano on other side of rack and it will be lockable. Part were dropped off to powder coater today and i'll update with finished product next week!!!
  12. Jan 10, 2017 at 5:47 PM
    #5232
    austinrauh
    austinrauh Well-Known Member
    Nevada
    05 AC OR
    I need help deciding which way I want to mount my water port, a. Is horizontal, I can make brackets so it sits lower I'm between two of the bars so only 3/4 of it is above the bars
    Or b. I do it long ways but this way it will be entirely above the rack, which would you choose?
    (Sorry for bad phone pics)
  13. Jan 10, 2017 at 6:18 PM
    #5233
    Infernomedic
    Matthew
    2016 Inferno Tacoma
    I think i would mount it between bars... less drag
  14. Jan 10, 2017 at 7:24 PM
    #5234
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Needs to be mounted upright though.
    Not much room to drop it..
    I mounted mine along the last crossbar, upright, and made a simple mount.
  15. Jan 10, 2017 at 7:40 PM
    #5235
    austinrauh
    Nevada
    05 AC OR
    Upright? How so?
  16. Jan 11, 2017 at 5:58 AM
    #5236
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Schrader valve at the top, outlet on the opposite end at the bottom.
    Sna, ChadsPride and BYJOSHCOOK like this.
  17. Jan 11, 2017 at 10:05 AM
    #5237
    austinrauh
    Nevada
    05 AC OR
    Sweet truck, I see. How does that have an effect on it? Mine is from a bed mount so the valve to connect my hose is on the top
  18. Jan 11, 2017 at 10:12 AM
    #5238
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Well when you pressurize it, you want all that pressure above the outlet as much as possible, to push out the water.
  19. Jan 11, 2017 at 12:15 PM
    #5239
    BFT18
    BFT18 Active Member
    Ian
    Santa Barbara, CA
    2016 Tacoma TRD OR 4x4 DCSB
    Does anyone want to trade a black 42" cutout Wind Deflector for a solid black, no cutout wind deflector?
    I am buying a light bar and need the cutout.
  20. Jan 11, 2017 at 12:15 PM
    #5240
    BFT18
    BFT18 Active Member
    Ian
    Santa Barbara, CA
    Does anyone have a CaliRaised light bar on their Prinsu Cabrack? What mounting hardware did you use? (do Prinsu's heretic light bar mounts work? Or do the CaliRaised brackets fit the Prinsu cabrack well?)
