PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Feb 14, 2017 at 9:31 AM
    #5401
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Anyone has the bolts seized up inside the crossbars? I didn't use any loctite, but one of the bolts won't budge for me to remove the bar. I might have stripped the bolt head too.
  2. Feb 16, 2017 at 1:50 PM
    #5402
    hackeradam
    hackeradam @the.trd.pro
    Adam
    HTX
    2017 Cement LT TRD Pro | 1965 FJ40 383 SBC
    Single row. No prob
  3. Feb 16, 2017 at 2:46 PM
    #5403
    austinrauh
    austinrauh Well-Known Member
    Nevada
    05 AC OR
    Did you ever get eh wind deflector?
    I just switched to the 40" cutout and have the full one
  4. Feb 16, 2017 at 4:10 PM
    #5404
    winguyen
    winguyen Well-Known Member
    Kevin
    Watertown, MA
    2014 Pyrite-Mica DCSB TRD Off-Road
    Nah I haven't heard back from him. Is yours powder coated?
  5. Feb 16, 2017 at 10:52 PM
    #5405
    austinrauh
    Nevada
    05 AC OR
    yeah, like the textured powder coat
  6. Feb 17, 2017 at 6:15 AM
    #5406
    CoMtnFJ
    CoMtnFJ Member
    My prinsu will be arriving soon and I am trying to figure out what my options are as far as a shovel, axe, and hi lift mounts are concerned.
    Has anyone had any success using front runner mounts on their prinsu? I read that they may be compatible but have never actually seen pics of front runner mounts on prinsu racks. I have also read people are using pelfreybilt mounts but haven't seen any pics of trucks using the shovel/axe mount on the prinsu. If you have had success using either, will you please post a pic?
    I saw the info on the quickfists, which is a solid solution for the axe/shovel, but would love to know if anyone has other suggestions for the hi lift outside of the pelfreybilt.
    Thanks!
    Kyitty likes this.
  7. Feb 17, 2017 at 6:39 AM
    #5407
    G.T.
    G.T.
    CONUS
    First, welcome to TacomaWorld.
    I don't mount heavy tools to the side of mine for fear of the mounts coming lose and that tool becoming "Exhibit A" in a manslaughter case against me. If you plan to put a jack or similar heavy tool up there seriously consider mounting it onto the decking of the rack for some added safety.
    In the end remember that I'm just an old geezer that worries about crap like that so your mileage may vary.
    And again, welcome to TacomaWorld.
    Kyitty and ETXTacoma like this.
  8. Feb 17, 2017 at 9:20 AM
    #5408
    alvinfromhawaii
    alvinfromhawaii Well-Known Member
    Northern California
    2015 MGM Tacoma DCSB V6 TRD Offroad
    Supercharged, Magnaflow, Volant,
    I was wondering the same if the Frontrunner Hi-lift jack mount would work. I saw a picture of the Pelfrey mount on this thread somewhere but not with the jack mounted to it.
    CoMtnFJ[QUOTED] likes this.
  9. Feb 17, 2017 at 9:24 AM
    #5409
    duvinclunk
    duvinclunk Well-Known Member
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    This is something I've been wondering for a while...since the Frontrunner system uses a similar channel cross bar setup, can you use any Frontrunner accessories with the Prinsu rack?
  10. Feb 17, 2017 at 9:29 AM
    #5410
    alvinfromhawaii
    Northern California
    I also wonder what kind of stress it would put on the rack side rails. Looking at the pictures on their website, it looks like it would fit but unclear if the space between the flat part and the bolts is wide enough or too wide for the prinsu rack thickness.
  11. Feb 17, 2017 at 9:33 AM
    #5411
    CoMtnFJ
    CoMtnFJ Member
    I think I may just go the Pelfrey route since it is proven to work with our rack. I just wish there were cheaper options...
    I am going to pull the trigger on the dual jerry can mount and see if it works. From what i can tell from the pics, it should mount as long as the bolts are compatible... We will see...
  12. Feb 17, 2017 at 9:35 AM
    #5412
    alvinfromhawaii
    Northern California
    Please post pics of your install.
    CoMtnFJ[QUOTED] and socalktk like this.
  13. Feb 17, 2017 at 9:43 AM
    #5413
    alvinfromhawaii
    Northern California
    Here is what I did for securing the roof lightbar wire to my windshield. Used these cable mounts https://smile.amazon.com/gp/product/B00FH6HYWO/ref=oh_aui_search_detailpage?ie=UTF8&psc=1, replaced the adhesive with https://smile.amazon.com/gp/product/B002JOVUO0/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    The reason being is that I didn't want to block the channel where the water drains or gunk up with silicone adhesive. Plus this method is removable
    Toynado and ajmogen like this.
  14. Feb 17, 2017 at 1:30 PM
    #5414
    pruchai
    pruchai KAMA3
    San Diego, CA
    ‘07 Saab 9-7x 4.2i (it identifies as a Tacoma)
    Not enough...
    I just punched holes in my rain gutter and used zip ties. The wire is practically invisible
    https://www.tacomaworld.com/threads/how-to-run-wires-next-to-windshield.327470/page-2#post-12532769
  15. Feb 17, 2017 at 3:18 PM
    #5415
    Taka The Tacoma
    Taka The Tacoma Enjoy the Roy
    2017 SR 2.7L 4WD
    TRD Rims, duratrac tires
    Finally got my prinsu attached to my topper! Absolutely love it!
  16. Feb 17, 2017 at 7:30 PM
    #5416
    pruchai
    pruchai KAMA3
    San Diego, CA
    Not enough...
    Btw, does anyone have problems with these 3-4 piece Heretic light bars rattling/vibrating? I have to take mine off every couple of months to re-tighten the brackets that hold the pieces together. When I take the bar off to re-tighten I clamp it down to my work bench of make sure everything is straight, but after a while it just starts to sag and vibrates when I hit a bump or a pothole. Im at the point where I'm ready to get rid of this thing and get a 1 piece 40" bar. Either that, or get some kind of L-bracket to add additional support in the middle. Or have someone make me a single piece bracket that will attach to the rack and lights will attach to it.
    EDIT: I had someone with a plasma cutter to make me some brackets
    https://www.tacomaworld.com/threads...racks-bs-thread.317754/page-145#post-10873320
  17. Feb 17, 2017 at 7:31 PM
    #5417
    RBfastback
    RBfastback It's Got Electrolytes
    mike
    FL
    16 mgm TRD off road
    just ordered mine 2 days ago,
    around how long is the wait at?
  18. Feb 17, 2017 at 7:34 PM
    #5418
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    I ordered a replacement air-dam panel with 40" cut-out on 14 January 2017, with no further word on it yet since receiving confirmation of payment. A good question..
  19. Feb 17, 2017 at 7:38 PM
    #5419
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Do you have a better pic of how the bars attach to themselves? Blue locktite and/or lock washers come to mind.
  20. Feb 17, 2017 at 7:39 PM
    #5420
    RBfastback
    mike
    FL
    16 mgm TRD off road
    yeah i've called 3 times, left voicemails, pm'd on the forum and facebook messaged all with no replys
