PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Apr 26, 2017 at 6:46 AM
    #5981
    LEXICON
    LEXICON born where the prairies meet the rockies
    Courtney
    Canada
    2016DCLBBLACKTACOMATRDSPORT4X4PREMIUM
    Nothing worthy
    I'd suggest even one kayak. It makes mounting and removing the J rack easier and MUCH more stable and strong.
    As for the sunroof, you can open it but DONT pop it up!!!! LOL might break the glass or damage something. Once you mount it the proper way popping up the glass is no problem.
    Like so ~ yes, I drew that.....
    use "T" bolts slid into the rack that point straight up and whatever nut you choose for profile, I'm going to try the supplied wings nuts form the J rack and tighten up top. looks like they won't interfere with the kayak.
  2. Apr 26, 2017 at 8:40 AM
    #5982
    amirak
    amirak Well-Known Member
    what wheel size, tire size it that. did you lift it for the bigger tires?
    bshammer0 likes this.
  3. Apr 26, 2017 at 10:01 AM
    #5983
    LadyRed
    LadyRed Making all the right wrong turns
    Leah
    Florida/Mississippi
    2016 4x4 TRD OR DCSB
    OME Lift Total Chaos UCA SCS Ray 10s
    Wheel is 16x8. Tires 255/85/16. Lift is an Old Man Emu 2"
    amirak[QUOTED] likes this.
  4. Apr 26, 2017 at 11:13 AM
    #5984
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    The CVT summit series MT Denali 4+ person RTT is definitely over 250
  5. Apr 26, 2017 at 11:31 AM
    #5985
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    Holy crap, that is a lot of weight, I am not sure I would want that much up on the canopy. The one I am looking at is 165, but I have to put on a prinsu/frontrunner type rack on the canopy, that is if my canopy ever comes back from the dealer/manufacture for the leaks I am having, as the attachment method as far as I can tell will not work with a yakima rack. Damn hard shell RTT
    riz_atx[QUOTED] likes this.
  6. Apr 26, 2017 at 1:16 PM
    #5986
    duvinclunk
    duvinclunk Well-Known Member
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    :eek:
    Blackout14 likes this.
  7. Apr 26, 2017 at 1:19 PM
    #5987
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Time to go full #EAF..Build a trailer.
    With that much weight alone and then humans, you need to have something build to take that weight.
    riz_atx[QUOTED] and Blackout14 like this.
  8. Apr 26, 2017 at 7:23 PM
    #5988
    Fosk
    Fosk Well-Known Member
    Andrew
    Huntington Beach, CA
    10-12 weeks. I just ordered a rear HC with swingout.
  9. Apr 27, 2017 at 9:02 AM
    #5989
    Mabel
    Mabel Well-Known Member
    Carlos
    Central Oregon
    2017 MGM Tacoma DCLB TRD Off Road
    Hmmmm, would you be interested in selling it?! :D
    LTDSC likes this.
  10. Apr 27, 2017 at 9:13 AM
    #5990
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    No sir. Also, i have an Access Cab. It wont fit
    Mabel[QUOTED] likes this.
  11. Apr 27, 2017 at 9:24 AM
    #5991
    Mabel
    Carlos
    Central Oregon
    No worries at all! I hope it works well for you. Thanks for the quick response. :thumbsup:
    fatfurious2[QUOTED] likes this.
  12. Apr 28, 2017 at 11:57 AM
    #5992
    fatfurious2
    David
    Ashburn, VA
    What size step drill bit do i need?
  13. Apr 28, 2017 at 12:24 PM
    #5993
    fatfurious2
    David
    Ashburn, VA
    Id rather use a step bit than a regular bit. I guess i need to open the box and see if there are instructions
  14. Apr 28, 2017 at 12:39 PM
    #5994
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Use a step bit. There are instructions on his website. You'll love it
  15. Apr 28, 2017 at 1:31 PM
    #5995
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    FWIW I didn't use a step bit and drilled 10. Just used three different sizes, took longer but didn't make a mistake
    fatfurious2 likes this.
  16. Apr 28, 2017 at 2:10 PM
    #5996
    fatfurious2
    David
    Ashburn, VA
    Ive got both. We will see tomorrow
  17. Apr 28, 2017 at 3:11 PM
    #5997
    zscott
    zscott [OP] Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    What was the name on the order? I don't like to give away free coating but things do get jumbled on occasion.
  18. Apr 28, 2017 at 3:12 PM
    #5998
    zscott
    Zach
    Utah
    Step bit is the best but you usually will have to finish the hole with a normal bit. Some step bits don't have large enough "ledges" to go fully through the roof.
  19. Apr 28, 2017 at 3:13 PM
    #5999
    fatfurious2
    David
    Ashburn, VA
    The name was David Yue. But dont worry, im not complaining. I will plastidip on top of the powdercoat
  20. Apr 28, 2017 at 4:00 PM
    #6000
    Joethebugman
    Joethebugman Well-Known Member
    Joe
    '17 Trd OR DBCLB
    I'm excited! 6 days and counting.
