PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Jun 21, 2017 at 11:08 AM
    #6841
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    the labor to produce them here is minimal
    T4RFTMFW likes this.
  2. Jun 21, 2017 at 11:15 AM
    #6842
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    I imagine it's mostly an organic process
  3. Jun 21, 2017 at 11:16 AM
    #6843
    T4RFTMFW
    T4RFTMFW Well-Known Member
  4. Jun 21, 2017 at 11:16 AM
    #6844
    ramonortiz55
    Ramon
    Texas
    stock
    Indeed, our processes are 100% earth friendly.
    Bannerman[QUOTED] likes this.
  5. Jun 21, 2017 at 11:20 AM
    #6845
    Bannerman
    Johnson
    Charlotte, NC
    It show up?
  6. Jun 21, 2017 at 11:40 AM
    #6846
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    I'm extremely happy for a 1st gen dbl cab option. My oem plastic rack is on its way out which will leave 8 sertnuts in the roof.
    Blackout14 likes this.
  7. Jun 21, 2017 at 3:38 PM
    #6847
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Came in today.
    Jack0928, dskakie, TACOVRD and 8 others like this.
  8. Jun 21, 2017 at 6:45 PM
    #6848
    Joethebugman
    Joethebugman Well-Known Member
    Joe
    '17 Trd OR DBCLB
    Where is everyone outing their first cross bar on the cabrack?
  9. Jun 21, 2017 at 7:42 PM
    #6849
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Mine is the same as the photo above your post.
  10. Jun 21, 2017 at 10:05 PM
    #6850
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    Cabrac users with 40" light bar mounted, are you experiencing glare? what level of glare? what type of bar are you using? what type of optics (spot, driving, flood? how are you combating it?
  11. Jun 21, 2017 at 11:14 PM
    #6851
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Same here.
    The rear one on mine is mounted vertical to clear the shark fin. Drilled an extra hole on each side rail for the second bolt hole.
  12. Jun 22, 2017 at 3:17 AM
    #6852
    Joethebugman
    Joe
    '17 Trd OR DBCLB
    Thanks @Naveronski & @RedBeard1. I get some noise from time to time and thought maybe that bar needed moved back a little. Maybe I just need to order the noise reducing trim piece.
  13. Jun 22, 2017 at 3:56 AM
    #6853
    RedBeard1
    Red
    Yeah the trim is the way it go.. The only time I hear mine is in a cross wind.
    I also have clear bra material across the top of my cab where the trim goes to prevent the paint from getting damaged there. Had a camper seal rub through the paint on my 85 Toyota cab so the clear stuff will slow that down.
  14. Jun 22, 2017 at 6:01 AM
    #6854
    Joe-Quin
    Joe-Quin Active Member
    San Antonio, Texas
    2017 Trd Sport
    Derp Badges & Grill Clazzio Covers
    Love the way the rack looks!! It is damn loud tho, I've already installed the plastic t slot covers and waiting on my noise reducing trim hopefully that makes a significant difference.
    Not sure if there's a difference in design but I bought the rack used and he had it for a year. I have the fairing at the lowest connection yet it's still 1/2" clearance. I thought some of yalls were damn near touching the roof?
  15. Jun 22, 2017 at 6:58 AM
    #6855
    winguyen
    winguyen Well-Known Member
    Kevin
    Watertown, MA
    2014 Pyrite-Mica DCSB TRD Off-Road
    You probably need to slide the whole rack backwards
  16. Jun 22, 2017 at 7:10 AM
    #6856
    m603holden
    Marteeen
    New England
    20170622_100547.jpg It's on. Failed with the weather strip. Easy enough fix for later.
    Jessrin, PS78, Jack0928 and 2 others like this.
  17. Jun 22, 2017 at 7:13 AM
    #6857
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    This
  18. Jun 22, 2017 at 7:24 AM
    #6858
    Bannerman
    Johnson
    Charlotte, NC
    Failed?
    Sleipnir likes this.
  19. Jun 22, 2017 at 7:46 AM
    #6859
    m603holden
    Marteeen
    New England
    Yep. Tried the holesaw method . The but grabbed while doing the middle hole and blew the side out.
    No biggie. Just going to cut my own rubber strips and 3m them down.
  20. Jun 22, 2017 at 7:50 AM
    #6860
    Bootleg_Flyer
    Bootleg_Flyer Well-Known Member
    Virginia
    17 DCSB Off-Road
    What kind of noise are you getting? Whistling, howling, humming/vibration, etc. can be fixed with adjustment but elevated levels of normal 'wind on metal' noise is part of the deal in my experience.
