PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Jul 16, 2017 at 12:09 AM
    #7221
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    I did drill it out, but the hole ended up too big because the aluminum was so soft, now I'm a bit stuck. Guess I should pull all the bolts out and never sieze them
    That's exactly what I did. This all happened a week or two ago. Its just supported by one bolt right now...
  2. Jul 16, 2017 at 5:20 AM
    #7222
    Joethebugman
    Joethebugman Well-Known Member
    Joe
    '17 Trd OR DBCLB
    WormSquirts likes this.
  3. Jul 16, 2017 at 8:36 AM
    #7223
    WormSquirts
    Braeden
    BC
    Joethebugman[QUOTED] likes this.
  4. Jul 16, 2017 at 10:49 AM
    #7224
    Gin05
    Gin05 Well-Known Member
    gin
    WA
    2015 black DCSB 4x4 TRD OR
    one mod at a time!
    that's PITA! good thing i open/read this thread again. i just installed my prinsu last month. Need to re-done it and use anti-seize before this thing happen to my rack.
  5. Jul 16, 2017 at 11:12 AM
    #7225
    Taco Caliente
    Taco Caliente WTF?
    San Antonio, TX
    2019 TRD OR DCSB
    As found in a search:
    Galvanic Corrosion is corrosion damage created when dissimilar materials are joined by a corrosive electrolyte. Galvanic Corrosion is a common type of corrosion found in Marine Environments. For example, two dissimilar metals such as Stainless Steel and Aluminium touching and an electrolyte such as salt-water or even rain water (made worse if there is a high salt content in the atmosphere I.e. coastal). This is a problem on Yachts masts where Stainless Steel fasteners are in contact with Aluminium or Carbon Fibre masts.
    Source: http://www.anzor.com.au/blog/galvanic-corrosion-keep-those-metals-apart/
    Man, I'm glad I saw this as well. I've got one ordered and will certainly use anti seize when assembling.
  6. Jul 16, 2017 at 11:32 AM
    #7226
    TSki
    TSki Well-Known Member
    Tyler
    Salmon, Idaho
    2017 Silver Sky TRD Off-Road, 4x4, DCSB MT
    https://www.tacomaworld.com/threads/my-silver-gsu-build.460083/
    Yep.. I'm gonna dismantle and do the same.. better now than a year down the road when I have to fight it.
    Gin05[QUOTED] likes this.
  7. Jul 16, 2017 at 11:48 AM
    #7227
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Just learned about this in my Failure Analysis class. Good stuff :thumbsup: so it makes sense as to why my bed bolts are rusting :rolleyes:
  8. Jul 16, 2017 at 12:10 PM
    #7228
    Taco Caliente
    Taco Caliente WTF?
    San Antonio, TX
    2019 TRD OR DCSB
    I've been working in a FA lab for over 30 years and deal with all kinds of corrosion failures, but for some reason never even thought of this application.
  9. Jul 16, 2017 at 12:38 PM
    #7229
    Joethebugman
    Joe
    '17 Trd OR DBCLB
    Is this something that should be reapplied? Maybe yearly or every other year?
  10. Jul 16, 2017 at 1:19 PM
    #7230
    DaveEli
    DaveEli Well- Known Member
    David
    Virginia Beach
    2011 Tacoma Sport 4X4
    Icon Extended Travel Coilovers, King 700lb springs, All-Pro Expo leaf springs, All-pro U-Bolt flip kit, Icon 2.0 Series custom length rear shocks, Wheelers Superbump Bumpstops, All-Pro extended rear brake lines, Warn 86255 VR10000 10,000 lb winch, Warn 90287 wireless remote, Redline Hood Struts, AVS Bugflector II, Pelfreybilt front bumper with Rigid 92031 SR- Series White 20" Spot/Flood lightbar, Brute Force rear bumper with short swingarm, Famous Fabrication Rock Sliders, Pelfreybilt Skid Plates, Rigid 50231 D2 Driving Lights, Rigid 20221 Dually Spotlights, Rigid 98000 SR-M backup lights, ARB CKMTA12 "12V"on-board twin high performance air compressor, Dick Cepek DC-2 17x9" wheels, 285/70R17 Goodyear MTRs with Kevlar tires, Wet Okole seat covers,Airflow snorkle, ARE CX HD cap, Front Runner Slimline II cap rack, TRD cat back exhaust, AVS in channel window vents, Toyota door sill protectors, Pop & Lock tailgate lock, Husky Rear floorliners, WeatherTech Front Floorliners, DeeZee bed mat, Window tint, TRD drop in air filter, Plasmaglow led bed lights, Hi-Lift jack mounted on bed rail, IMMRYO Rear View Mirror Relocate, ARB 63 Quart fridge freezer, Arb ARB209 Snatch Block, ARB ARB730US 3" x 10' Tree saver, ARB ARB705US 2-3/8" x 30' recovery strap, Bubba Rope 7/8" x 30' original rope 28600 lbs, Bubba Rope Gator Jaw soft shackle 7/16.
    Finally getting around to installing my rack. I can't win. The hole for the air dam are not correct. But I am unclear as to which one is off. The first or second one. Any ideas?[​IMG][​IMG]
  11. Jul 16, 2017 at 1:22 PM
    #7231
    Taco Caliente
    Taco Caliente WTF?
    San Antonio, TX
    2019 TRD OR DCSB
    I'd imagine as long as you sealed the bolt head as well as the side rail to crossbar interface it should be good to go for years. Point is not to let any moisture in to serve as an electrolyte to create the galvanic corrosion process.
  12. Jul 16, 2017 at 1:37 PM
    #7232
    DaveEli
    David
    Virginia Beach
    You are right. I was so pissed off I didn't see that. The edge of the hole should be where I drew my line. One inch on center. Guess I have some grinding to do. Thanks. :thumbsup:
    Blackout14 likes this.
  13. Jul 16, 2017 at 1:48 PM
    #7233
    DIRTT_Fish
    DIRTT_Fish Well-Known Member
    2017 TRD OR DCSB
    Cbi t3, 888, HD Dakar, b110, wheelers bumps,ubolt flip, spc uca, +4" rear brake lines.
    Anyone know how long of a track I need for my Short box camper shell? Bought shell 2nd hand and it did not come with those tracks.
    Thank you!
  14. Jul 16, 2017 at 1:58 PM
    #7234
    DaveEli
    David
    Virginia Beach
    At least both sides are off the same.
  15. Jul 16, 2017 at 1:59 PM
    #7235
    DaveEli
    David
    Virginia Beach
    With my luck, figured it would just be me.:(
  16. Jul 17, 2017 at 10:04 AM
    #7236
    SilvFx
    SilvFx Well-Known Member
    Englewood, CO
    2010 Toyota FJ Cruiser
    Toytec Ultimate 3 Lift, RCI skids, 285/70/17 BFG AT KOs
    You can literally order these replacement bars yourself directly from 80/20 in black anodized cut to length with end taps of 1/4 x 20. Looks like they are ~$42 each. You can also get other size bars (1 x 1), etc. Not sure how much brain damage I would take over trying to install a time sert or helicoil
    https://8020.net/shop/1020-s-black-fb.html#
    Also agree about using antisieze (loctite is also an antisieze of sorts too). Given that it was only a couple months are you sure it wasnt cross threaded when it was first installed? Also, go easy on torquing these things down.
  17. Jul 17, 2017 at 10:42 AM
    #7237
    zscott
    zscott [OP] Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    I can't tell from your picture where this is located. Can you zoom out?
    DaveEli[QUOTED] likes this.
  18. Jul 17, 2017 at 10:44 AM
    #7238
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Zach, are you still shipping stuff or should I hit up CBI for the Noise reducing trim you were going to send?
  19. Jul 17, 2017 at 10:47 AM
    #7239
    zscott
    Zach
    Utah
    I am still shipping stuff. Basically anything prior to June 15th I am working on. Anything after that CBI will be taking care of. I should have most of my outstanding items done by the end of the month at the latest. I have your edge trim ready to go. Was looking to make sure it hadn't been shipped separately already.
    CharlieCafe likes this.
  20. Jul 17, 2017 at 10:51 AM
    #7240
    Bannerman
    Johnson
    Charlotte, NC
    Ok thanks, I'll be looking out for it. Rack is amazing by the way. Could not be happier!
    BYJOSHCOOK and Jack0928 like this.
