PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Aug 11, 2017 at 7:11 PM
    #7501
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Mine is plastidip white. Doesn't look too bad. Black powdercoated under neath
  2. Aug 11, 2017 at 8:51 PM
    #7502
    TSki
    TSki Well-Known Member
    Tyler
    Salmon, Idaho
    2017 Silver Sky TRD Off-Road, 4x4, DCSB MT
    https://www.tacomaworld.com/threads/my-silver-gsu-build.460083/
    Go for it! I dropped my headliner and it wasn't nearly as rough of a project as I thought it would be!
  3. Aug 11, 2017 at 8:55 PM
    #7503
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    Did it tonight... it was a pain in the butt, mainly getting it out of the truck was the biggest and hardest part and not trying to bend it too much.
    But got it all out and ready to do the sound deadening tomorrow.
  4. Aug 11, 2017 at 9:02 PM
    #7504
    TSki
    Tyler
    Salmon, Idaho
    Ok now I'm impressed.. how did you get it out without bending? I just dropped it in the cab and then worked above it.
  5. Aug 11, 2017 at 9:05 PM
    #7505
    ETXTacoma
    Steven
    Tyler, Texas
    I had to bend it a little bit, but essentially have to have the rear driver side seat removed, no headrests, and then have the front seats folded up and all the way forward and I was able to get it out.
    It rebounds pretty well and once back installed, should not have an issue with it or anything.
    Will see how tomorrow goes as far as getting the material installed and all that.
  6. Aug 11, 2017 at 9:51 PM
    #7506
    Vandy09
    Vandy09 Well-Known Member
    2016 Tacoma TRD offroad
    Mine delivered today. My neighbor put it in the garage for me. Camt wait to get it installed
    Thanks Zach and congrats on your sale. I appreciate ya bro
  7. Aug 12, 2017 at 11:45 AM
    #7507
    Dave1410
    Dave1410 Member
    Dave
    Standish, ME
    Still haven't received my rack.
  8. Aug 13, 2017 at 8:47 AM
    #7508
    alvinfromhawaii
    alvinfromhawaii Well-Known Member
    Northern California
    2015 MGM Tacoma DCSB V6 TRD Offroad
    Supercharged, Magnaflow, Volant,
    Sna, BountyOR_VF2, Bill Bixby and 5 others like this.
  9. Aug 13, 2017 at 1:56 PM
    #7509
    Vandy09
    Link?
  10. Aug 13, 2017 at 1:57 PM
    #7510
    fatfurious2
    David
    Ashburn, VA
  11. Aug 13, 2017 at 4:42 PM
    #7511
    pescadoman66
    pescadoman66 Pescadoman66
    CJ
    Livermore, CA
    2017 TRD OR 4X4 Pro Wannabee Stormtrooper
    Tacoma Pro Front Grille Tailgate Letters Console Organizer Clazzio Seat Covers TRD front Grille Emblem Westin Drop Steps Front Widow Tint Tow Strap LED lights Sunshade Prinsu Rack BackFlip Cover rack accessories crutchfield speakers Front Tweeter speakers Tuffy box sound deadening mat Westin LED light bar Led switch Light bar bracket TRD Pro Tail lights TRD Pro Wheels BF Goodrich KO2 tires from America's Tire Old Man Emu Lift Coils - Coil Selection: 2887 Bilstein 5160 Rear Shock with Reservoir Bilstein 5100 Adjustable Front Struts HeadStrong 3 leaf progressive Add-a-leafs JBA UCA's Low Range OFF-Road 1.25" Cast aluminum blocks in the rear
    Just made the leap of faith on a purchase of the Prinsu. Thanks for all the info supplied to make my decision, hoping it is the right one as I have done so much research. Now it is just having patience and waiting for it to come.
  12. Aug 13, 2017 at 4:45 PM
    #7512
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    You won't be disappointed
    pescadoman66[QUOTED] likes this.
  13. Aug 13, 2017 at 4:46 PM
    #7513
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-354B Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Anyone using the load panels?
  14. Aug 13, 2017 at 7:32 PM
    #7514
    alvinfromhawaii
    Northern California
    This is a custom made mounting system for TRED Pros.
    You can read more about it here
  15. Aug 13, 2017 at 7:44 PM
    #7515
    Overkill07
    Overkill07 Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
    A few audio upgrades, tinted windows, remote start because it f'n hot in Texas! 6in Fabtech DB lift, 17x9 Fuel Trophy wheels, 315/70/17 Duratracs,BAMF 80in sliders w/kickout, Prinsu cab rack w/30in Heretic light bar, custom bedside decals, custom hi-lift jack brackets, US Offroad front bumper w/winch, bed rack with RTT, CB, Short wave base station, Ultra gauge, color matched grille surround, an ungodly amount of recover gear, ARB fridge, hood struts, RotoPax, traction pads.
    I'd like to know this also. Just found out about these earlier today in this thread. They look like they fit into the slots on the bars. I'm wondering how much the move around and if they make any noise.
  16. Aug 13, 2017 at 7:55 PM
    #7516
    Hilborn
    Michael
    Utah
    The load panels look like they could be the solution to all my gear mounting.
  17. Aug 13, 2017 at 10:55 PM
    #7517
    mrjoshyman
    mrjoshyman Well-Known Member
    Josh
    What do y'all use to mount spare tire on the rack...securely? ... aka a) not going to fly off when off road under heavy abuse, and b) not easy to steal
  18. Aug 14, 2017 at 8:12 PM
    #7518
    IYAOYAS
    IYAOYAS Active Member
    Christopher
    Twin Cities
    2012 TX TRD Double Cab
    265/75/16, Bilstein 5100's
    Also just purchased one! Hope it comes in time for a camping trip at the end of September. Are you putting a light bar on it? I ordered it with the cutout for a 40" light bar, but didn't get a bar yet. I like the Heretic look, but wish it could be all black like the Rigid Industries Midnight series. Will have to do a little more research.
  19. Aug 14, 2017 at 8:23 PM
    #7519
    Tyler07
    Tyler07 Well-Known Member
    Reno, NV
    2007 4x4 DCSB
    Would definitely check these out man:
    https://www.theretrofitsource.com/assemblies/off-road-lighting/xtorch-40-light-bar.html
    I personally have no firsthand experience with em, but they get amazing reviews on here and they've got something like a 10 year warranty I believe. I'm in the exact same boat as you- and this will be the route I go. You can't beat the price, and they're low profile. Personally, I think they look the best on these racks- just my opinion.
    CountryDan likes this.
  20. Aug 14, 2017 at 8:37 PM
    #7520
    IYAOYAS
    Christopher
    Twin Cities
    That one is definitely on my list. Thanks! I do need a low profile one so I can transport canoes.
    Tyler07[QUOTED] likes this.
