PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Sep 22, 2017 at 1:27 PM
    #7861
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Any downside to useing rubber washers and silicone under the spacers ? When bolting rack down?
  2. Sep 22, 2017 at 1:33 PM
    #7862
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    You will be sitting higher than it normally would with a washer under the spacer
    Blackout14 likes this.
  3. Sep 22, 2017 at 1:53 PM
    #7863
    Hawj123
    Hawj123 Well-Known Member
    NorCal
    06 Tacoma DCSB TRD OR
    On prinsu site trying to order a rack, does the powder coating not cost extra now???? Before it used to end up being like $500+ for the powder coat. Anyone???
  4. Sep 22, 2017 at 4:44 PM
    #7864
    Hawj123
    NorCal
    I guess we'll find out, decided to pull the trigger just BOUGHT IT!!!!
    Coop68, Rob Daman and EatSleepTacos like this.
  5. Sep 23, 2017 at 3:23 PM
    #7865
    famous187
    famous187 Active Member
    i ordered mine on 7/25 and received it this past Wednesday. I won't be able to install it until Friday but, i did go ahead and assemble it in my barn and everything went together nice. Looks very good.
    I have a Plano waterproof gun case that I am going to mount to it, should I use T-Nuts in the slots and bolt through the case or use 2" u bolts and go around the bars?
    thanks
  6. Sep 23, 2017 at 4:08 PM
    #7866
    JerryTaco
    JerryTaco Well-Known Member
    Got some things today
  7. Sep 23, 2017 at 7:09 PM
    #7867
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    I've thought about both ways- and I think the most secure way would be to go ahead and use the U bolts. You could put some rubber or vinyl between the Ubolt and the crossbars
  8. Sep 23, 2017 at 8:02 PM
    #7868
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    ordered mine. now the waiting game.
    YDCtaco and Hawj123 like this.
  9. Sep 23, 2017 at 9:14 PM
    #7869
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Marvelousone- I just put in my Prinsu cabrack on my white 4x4 too and drove with it for about 180 freeway miles today at about 70 mph. I noticed some wind noise and am ok with it, but noticed that most of the noise was from around the deflector (I have it in the middle setting). I see you put yours on the lowest setting and put something on the bottom of the deflector, too. What did you put on on it? Does it help with wind noise?
    Anyone else?
  10. Sep 23, 2017 at 9:36 PM
    #7870
    Taco Caliente
    Taco Caliente WTF?
    San Antonio, TX
    2019 TRD OR DCSB
    Almost everyone puts the wind deflector on the lowest setting. What you probably have seen on the bottom of it in pics is called Noise Reducing Edge Trim. It's an option that I purchased and it seems to help alot.
    Here's a link http://www.prinsudesignstudio.com/product-page/noise-reducing-edge-trim
  11. Sep 23, 2017 at 10:29 PM
    #7871
    OnHartung'sRoad
    Thanks for your time making this reply with a link, I will definately try out both of your suggestions! Thanks!
  12. Sep 24, 2017 at 4:09 AM
    #7872
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    T-nuts looks cleaner, and means less drilling.
    OnHartung'sRoad likes this.
  13. Sep 24, 2017 at 4:11 AM
    #7873
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    I’ve tried all the positions. Quietest for me was middle but while all 4 bolts are loose, pushing the nose of the fairing down and raising the top rear edge up to make the fairing angle more vertical. Then tighten bolts.
    When I moved the angle the other way making the fairway more horizontal, got a really bad vibration/harmonic sound.
    You’re just using the small amount of play due to the bolt hole size vs bolt diameter and maybe moving the fairing 1/2” at most but it does make a difference.
  14. Sep 24, 2017 at 4:14 AM
    #7874
    TSki
    TSki Well-Known Member
    Tyler
    Salmon, Idaho
    2017 Silver Sky TRD Off-Road, 4x4, DCSB MT
    https://www.tacomaworld.com/threads/my-silver-gsu-build.460083/
    I have a leak... so the crap silicon that I could find here locally in Germany didn’t work for crap. I need to rip it out and replace it with something better. Does anyone have any recommendations that I can purchase off of Amazon? I am looking for something better that will hold up. Currently my truck is hiding in the carport during rain until I can find something better.
  15. Sep 24, 2017 at 4:43 AM
    #7875
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    This looks like some good shit.
    https://www.amazon.com/Permatex-800...506253379&sr=8-3&keywords=automotive+silicone
    TSki[QUOTED] likes this.
  16. Sep 24, 2017 at 7:55 AM
    #7876
    TSki
    Tyler
    Salmon, Idaho
  17. Sep 24, 2017 at 8:39 AM
    #7877
    OnHartung'sRoad
    Thanks for your reply! I will try this before I take it fully off from the middle setting. Moving it more vertical will increase drag a bit, but the amount you are saying would be minimal - did the harmonics you mention when you pushed the top back more sound like a thumping sound? I had a bit of that happening in the current middle setting too.
  18. Sep 24, 2017 at 10:07 AM
    #7878
    famous187
    yeah thats what i was thinking, would look cleaner.
    i was thinking of using these:
    https://www.tnutz.com/product/ds-010-drop-in-t-nut-with-set-screw/
    in the crossbar , two on the first rail and two on the last rail. then use 1/4x20 bolts and fender washers through the bottom of the plano case.
  19. Sep 24, 2017 at 10:13 AM
    #7879
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    U bolts hold up better and are stronger
    scott96929 and Blackout14 like this.
  20. Sep 24, 2017 at 10:22 AM
    #7880
    OnHartung'sRoad
    It would be nice to get rectangular Ubolts that fit the bars tightly, then plastic dip the bolt parts that touch the bars.
    Keep in mind though that your weak points using either ubolts or tnuts will always be the same on a Prinsu rack: it's the four screws holding each of the bars to the sides.
    famous187 likes this.
