PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Oct 25, 2017 at 6:09 AM
    #8201
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I used nearly 30 of these to fill all t-slots (front, top, bottom of bars) I wasn’t using and it nearly eradicated wind noise.
  2. Oct 25, 2017 at 6:41 AM
    #8202
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Can you post the link?
  3. Oct 25, 2017 at 6:48 AM
    #8203
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Naveronski[QUOTED] likes this.
  4. Oct 25, 2017 at 7:15 AM
    #8204
    Naveronski
    Fort Worth
  5. Oct 26, 2017 at 6:08 AM
    #8205
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    So if you are wondering what happens quicker..... a frame replacement or a prinsu rack...... looks like the winner is going to be the frame replacement
    CharlieCafe, Coop68 and BYJOSHCOOK like this.
  6. Oct 26, 2017 at 6:35 AM
    #8206
    Absolute Zero
    Absolute Zero Well-Known Member
    Ordered on Sept 5 (all black CABRAC, deflector with cutout, 1x1 bar for shark fin, edge trim) with an estimated shipping date of 10/16.
    CBI responded to my email on 10/16 with an update of 2-3 weeks delay due to supplier issues. CBI responded within 30 minutes to my email for an update on status.
    Got the shipping notice yesterday 10/25. No issues at all with the service so far.
    Hopefully everything comes out of the box ok!
  7. Oct 26, 2017 at 6:42 AM
    #8207
    EL_INGE2017
    EL_INGE2017 Instagram: @el_inge2017
    Juan Jose
    Los Angeles, CA
    2017 Silver Metallic TRD Off-Road
    TRD Pro Grill, BFG KO2 285/75/16, 16x8 SCS Ray 10 Wheels, Demello Off-Road Bolt-on Sliders, Pelfreybily Skid Plate, Kings 2.5 w/resi and adjusters front and back, clazzio Trd pro leather covers, Baja Designs Squadron-R fog lights, Evilheadlights BHLM headlights, Pelfreybilt Standard Rear Bumper and front aluminum bumper, ATH Bed Stiffners, KB Voodoo Hi Rise Bed Bars, TuffStuff4x4 RTT, SPC UCA
    Ordered mine on August 28 and received it last night. It’s built just need to work on the weather strips and then install. Any tips to get it done faster.
  8. Oct 26, 2017 at 6:44 AM
    #8208
    Naveronski
    Fort Worth
    Take your time.
    Use the punch.
    Poke through the tape, don't remove it all.
    Seal the bolts in the roof.
    EL_INGE2017[QUOTED] likes this.
  9. Oct 26, 2017 at 8:19 AM
    #8209
    dtc1nick
    dtc1nick Well-Known Member
    Nick
    Alta Loma, CA
    2016 Toyota Tacoma TRD Sport 4x4
    Falken Wildpeak 285/70R17 Wheels XD Series XD800 Pro Comp Nitro 3/1
    I'm doing mine this weekend and going to use a 3/4 inch hole saw. The reason why is because it's a pilot drill and a lot more accurate then a punch
  10. Oct 26, 2017 at 8:21 AM
    #8210
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I'd be curious to see how that works. :popcorn:
    Anyone else use a hole saw over a punch and did it come out cleaner?
  11. Oct 26, 2017 at 8:22 AM
    #8211
    bshammer0
    Brandon
    Nashville, TN
    I'd just buy more than you think you'd need. I bought 10, then needed more, and ordered another 10, and eventually ended up using about 27 of them b/c the more I added the more it reduced the wind noise. Only thing I don't have covered with them now is the rear t-slots and a couple I have some mounting hardware on. I love the modular design and ability to be flexible down the road but definitely didn't need all those t-slots exposed.
  12. Oct 26, 2017 at 8:24 AM
    #8212
    thewalkingdead
    thewalkingdead Well-Known Member
    I drilled no holes, used threaded rubber feet. Does this method compromise the structurally integrity significantly?
  13. Oct 26, 2017 at 9:17 AM
    #8213
    Taco Caliente
    Taco Caliente WTF?
    San Antonio, TX
    2019 TRD OR DCSB
    I used a hole saw, but would definitely use a hole punch if I were to do it again!
  14. Oct 26, 2017 at 9:28 AM
    #8214
    TVRPhoto
    TVRPhoto Well-Known Member
    Tyson
    2016 Toyota Tacoma TRD Off Road DCLB
    Careful...
    There are quite a few posts on this thread already of folks using hole saws only for it to snag the rubber and tear up the stripping. Use a punch if you can.
    PNWTacoma and geekhouse23 like this.
  15. Oct 26, 2017 at 9:38 AM
    #8215
    geekhouse23
    My point was that the punch will be MUCH cleaner :rolleyes:
    PNWTacoma and pescadoman66 like this.
  16. Oct 26, 2017 at 9:42 AM
    #8216
    dtc1nick
    Nick
    Alta Loma, CA
    thanks for the info, I'll buy both and see what results it get and let you know what happens, thanks!
  17. Oct 26, 2017 at 12:35 PM
    #8217
    Taco Caliente
    Taco Caliente WTF?
    San Antonio, TX
    2019 TRD OR DCSB
    Also, say you were off by 1/4" on your hole. It is much easier to make the hole oblong to fit with a hole punch than with a hole saw or knife.
    geekhouse23[QUOTED] likes this.
  18. Oct 26, 2017 at 2:54 PM
    #8218
    LadyRed
    LadyRed Making all the right wrong turns
    Leah
    Florida/Mississippi
    2016 4x4 TRD OR DCSB
    OME Lift Total Chaos UCA SCS Ray 10s
    Dremel helps with cutting the holes in the weather stripping. Tape off where you need to make the cuts before removing. Will make it easier.
  19. Oct 27, 2017 at 7:23 AM
    #8219
    CoBackCountry
    CoBackCountry Well-Known Member
    J
    Colorado
    Thanks guys... found a used Yakima fatcat6 on cl locally for $40 and it mounted right up with no problems
    Dogg23, Coop68 and foxrcing07 like this.
  20. Oct 27, 2017 at 7:33 AM
    #8220
    SilvFx
    SilvFx Well-Known Member
    Englewood, CO
    2010 Toyota FJ Cruiser
    Toytec Ultimate 3 Lift, RCI skids, 285/70/17 BFG AT KOs
    great price for fatcat6 ski rack.
