PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Nov 5, 2018 at 4:34 PM
    #9721
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    For the standard roof bolts or what I went with?
    thedzeffect[QUOTED] likes this.
  2. Nov 5, 2018 at 7:53 PM
    #9722
    thedzeffect
    thedzeffect Well-Known Member
    Danny
    Bridgetown
    14' DCSB TRD OR 2WD, 18 DCSB TRD OR 4X4
    The driver.
    Yeah standard length and what you did you go with? Trying to switch to stainless steel hardware
  3. Nov 5, 2018 at 8:07 PM
    #9723
    20tacoma17
    2017 DCLB Sport AT
    Standard length is 60mm with 40mm shoulder. The shoulder was too long for mine and would run out of threads before getting the rack tight. They even sent another set to try with no luck. So I bought 55mm with 30mm shoulder in SS.
  4. Nov 5, 2018 at 8:32 PM
    #9724
    thedzeffect
    Danny
    Bridgetown
    The driver.
    Damn where did you end up picking up the hardware? Seems hard to find online might have to go to a specialty bolt store :facepalm:
  5. Nov 5, 2018 at 8:42 PM
    #9725
    20tacoma17
    2017 DCLB Sport AT
    Ace hardware has a huge selection of everything including metric. At least here they do.
  6. Nov 5, 2018 at 10:02 PM
    #9726
    thedzeffect
    Danny
    Bridgetown
    The driver.
    Thanks for taking the time to answer my questions, Appreciate it :cheers:
    20tacoma17[QUOTED] likes this.
  7. Nov 5, 2018 at 10:21 PM
    #9727
    SCJeffro
    SCJeffro @Voodoo_Blu_Taco
    2021 Voodoo Blue TRD Sport
    So I see all kinds of posts with different color cross bars... my question is if I want all the cross bars to match can I request all black Bars from cbi?
  8. Nov 6, 2018 at 5:00 AM
    #9728
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    The only crossbar that comes silver is the one behind the windscreen and you cannot see it unless you're standing on top of the roof rack. No one on the ground walking around your truck should ever spot it.
  9. Nov 6, 2018 at 7:35 AM
    #9729
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I know you have your tent on top but if there's just enough room you might be able to do this
    But this would require you to take off your RTT. My buddy did the same thing with his awning and RTT on his 4th gen
    ready6delta and LTDSC[QUOTED] like this.
  10. Nov 6, 2018 at 7:37 AM
    #9730
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    I had my awning directly on my rack and the zipper pull was too low. It would get closed in the door or rub on the roof and scratch the paint.
    LTDSC[QUOTED] likes this.
  11. Nov 6, 2018 at 7:38 AM
    #9731
    SCJeffro
    I don't care, I don't want a silver one, I will know it is there and so will my OCD... So my question stands.
    if I want all the cross bars to match can I request all black Bars from CBI?
    @CBI Offroad Fab input?
  12. Nov 6, 2018 at 7:49 AM
    #9732
    CBI Offroad Fab
    CBI Offroad Fab Member Vendor
    Idaho Falls, ID
    Everything Toyota!
    SCJeffro[QUOTED] and SR-71A like this.
  13. Nov 6, 2018 at 7:50 AM
    #9733
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    Ive thought about that as well, with the tent i should have enough space and offset some mounts with the bars to balance out to not use the same tent bars. I also added two additional bars so when i remove the ones perma-mounted to the tent i wont have to keep replacing.
    my paints so old and faded and clear failing already i wouldnt even notice.
    BYJOSHCOOK[QUOTED] likes this.
  14. Nov 6, 2018 at 7:53 AM
    #9734
    hoarder23
    Shay
    NJ
    Scratches
    Closing the zipper in the door was the more annoying situation
  15. Nov 6, 2018 at 8:05 AM
    #9735
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    what size bolt or carriage bolt did you use in the awning track? i didnt end up going last night so i never bought any.
  16. Nov 6, 2018 at 8:21 AM
    #9736
    BYJOSHCOOK
    Josh
    Check Out My Builds
    The typical 1/4" bolt, can't remember the height but it was a the same size as Prinsu sent out with the old tie downs.
    Here's the only picture I have that you can really see the awning. Passenger side
  17. Nov 6, 2018 at 8:25 AM
    #9737
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    thank you! Ill see what i can work up. Ill take pics when im done with it.
  18. Nov 6, 2018 at 8:53 AM
    #9738
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    that looks like it would be a pain for the doors opening/closing though because the height.
  19. Nov 6, 2018 at 1:27 PM
    #9739
    BYJOSHCOOK
    Josh
    Check Out My Builds
    It's not too bad, did have an issue or two but I can't remember as he hasn't used it/seen him in a bit
  20. Nov 6, 2018 at 4:15 PM
    #9740
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    You could make it work but would have to figure out a different mounting solution than what it comes with. Probably tnuts in the channels and bolt through rack with lock washer and washer plate to tighten up.
