PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Feb 4, 2019 at 7:03 AM
    #9921
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    2-3 hours with a buddy and lots of BSing.
    Measure for the holes, use a hole punch (DO NOT DRILL), reinstall the weatherstripping, install the side rails first (leave them a little loose, install the front most and rear most crossbars and tighten down the side rails for good. Install the remaining crossbars and fairing and you're done.
    RobP62 and Manbun525[QUOTED] like this.
  2. Feb 4, 2019 at 7:43 AM
    #9922
    Manbun525
    Manbun525 Well-Known Member
    Jake
    Phoenix, AZ
    2017 Inferno Tacoma TRD OR DCLB
    5100@4 888 OME with HS 3 AAL Avid Sliders Prinsu Rack 285/75/16 Cooper Pros
    Do not drill bc, of the metal strip in there etc it'll just tear and twist and not get a clean hole? And when you say punch a hole like a hollow punch? What all is needed for that, just the hollow punch or do you need a press or some extra tool? and what size hole punch?
    Thanks
    RobP62 likes this.
  3. Feb 4, 2019 at 7:48 AM
    #9923
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Look at the bottom of this page. Youll see all the products people have linked in this thread. Hole punch on Amazon you need is right in that list
    Otherwise you should just need a BFH, and some work surface you dont care about like a 2x4. Also doing it on the ground/concrete/asphalt (vs a workbench) is supposed to work better.
    geekhouse23 and Manbun525 like this.
  4. Feb 4, 2019 at 7:56 AM
    #9924
    Manbun525
    Jake
    Phoenix, AZ
    :confused::amen: Ah Thanks a bunch did not know thread items could be and were linked down there. I see it, just wasn't 100% on how they worked but I see now, hammer, holed puncher, bang bang
    SR-71A[QUOTED] likes this.
  5. Feb 4, 2019 at 8:49 AM
    #9925
    wessyder
    wessyder Enlightened OR Bro who don't need no skewp
    2019 Tacoma TRD OR, basically an off road race truck
    Tied several boat anchors to my truck to destroy MPG.
    I used a drill (I'm sure a punch is better)....i just used a brand new sharp paddle bit. But yeah...a punch would be better.
  6. Feb 4, 2019 at 9:04 AM
    #9926
    geekhouse23
    For the metal strip, take a Dremel to the metal strip where you need to make the punch, take a fresh razor blade to cut the rubber between the underside of the weatherstripping and before the metal strip starts and then make the punch.
    Do not punch it until the metal strip is removed.
    iK0NiK likes this.
  7. Feb 5, 2019 at 9:02 AM
    #9927
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    This is exactly what I did. Mark the stripping for the holes while it's still on the vehicle, remove & cut the "T-Shaped" rubber channel on the underside of the weatherstripping with a box cutter, then dremel the metal that's exposed. 5 Holes each side. It's a very time consuming process, especially when you take the proper effort to mark the weatherstripping to insure you're making the holes in the right location. The 3/4" punch is the exact size of the OD of the Prinsu spacer, so the process isn't very forgiving if you don't punch in the exact right spot.
    Take your time and do it right. It's definitely worth it.
  8. Feb 5, 2019 at 9:09 AM
    #9928
    geekhouse23
    This.
    I would definitely make sure you give yourself enough time. After work might not be the best option @Manbun525
    If time is not on your side when you decide to do this, you will rush it and the end result will not be favorable.
    Manbun525 and RobP62 like this.
  9. Feb 5, 2019 at 10:04 AM
    #9929
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    What if you're a #RandyFab deciple? But more so along the lines of Dopey, one of the 7 dwarfs?
    geekhouse23[QUOTED] likes this.
  10. Feb 5, 2019 at 10:09 AM
    #9930
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Manbun525 and geekhouse23 like this.
  11. Feb 5, 2019 at 10:28 AM
    #9931
    geekhouse23
    SOL? :notsure:
    RobP62[QUOTED] likes this.
  12. Feb 6, 2019 at 5:53 AM
    #9932
    Manbun525
    Jake
    Phoenix, AZ
    Lots of help all, just prepping myself to get it done as smoothly as possible, one last question, I plan on just going to lowes with one of the star bolts to see what fits, but does anybody know ahead of time what size star bit the bolts are? They shoulda def came with a bit.
    I see I believe its T30
    TheZeesT likes this.
  13. Feb 6, 2019 at 5:57 AM
    #9933
    geekhouse23
    I was going to say T25 or T30 IIRC
    Manbun525[QUOTED] likes this.
  14. Feb 7, 2019 at 7:07 AM
    #9934
    Manbun525
    Jake
    Phoenix, AZ
    Rack is on, I had like 2-3 holes about 1/4-1/2" off so the black weather strip bunched up in the middle, will take each side off separately and the holes that are slightly off I will cut into a more oval shape so the weather strip can shift over into place.
    All in all not a bad install, once I get it tidied up and light bar installed ill post pics.
    When in comes to the light bar also, how do yall run the wiring? Down the windshield, into engine bay, hook up to battery, then run switch through firewall into left cab switch area. Does that little left switch area, (in third gen) where the rear window button is and bed light etc, does that just pop off, I don't wanna force anything and break a clip. Do you just pop the whole panel out then I have 1 blank button space, remove that and replace with my light bar button.
    Car electronics are not my strong suit:confused:
    medicfung likes this.
  15. Feb 7, 2019 at 7:09 AM
    #9935
    geekhouse23
    Correct. Down the a-pillar drip channel
  16. Feb 7, 2019 at 7:28 AM
    #9936
    OverlAnderson
    OverlAnderson A dude playing a dude disguised as another dude
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    does anyone know at the highest point of the rack from the roof how much height does this add?
  17. Feb 8, 2019 at 6:54 AM
    #9937
    VTacoma6
    VTacoma6 Well-Known Member
    Vince
    Florida
    2015 Toyota Tacoma Trd Sport 4x4
    16 inch Matte Bronze FN Countersteer Type X wheels 0 offset With Goodyear Duratracs 265/75R16
    Anyone have to use extra washers Between the topper rails and prinsu feet to help level the rack out? Before I had the washer the rack was pulling up on the rails causing leaks. Still have a little pull but not as bad. Took out the rail screws re-siliconed and put the washers on and haven’t had any leaks since, just curious if anyone else has had to do the same. 5669A3FD-5385-440E-A839-C610494FD848.jpg
  18. Feb 8, 2019 at 8:37 AM
    #9938
    Mista_G
    Mista_G Well-Known Member
    Costa Mesa, CA
    '13 DCLB 4x4
    Kings F/R 2.5" EXT w/700lb springs, JD Fab UCA’s w/ Lower Pivot Kit, Icon Progressive AAL (with TSB and overload in), CB drop, 285/75-17 nitto ridge grapplers, SCS Deep Dish Ray Dimes, Snugtop Rebel Shell, Prinsu Toprac, Gibson SS Catback Exhaust, ATH front /rear steel bumpers, CVT awning, Airflow snorkel, @ Shmellmopwho sliders, SC w/ @justdsm HPtune, 3° Cam Gears @mightytacoman, 2.8 smooth flow pulley, StopTech BBK
    Lots of people have issues with the feet pulling up the tracks. Most people stack washers, but not how you did it. Instead they stack them on the outside two carriage bolts that attach to the cross bars. Which requires longer carriage bolts for those outside attaching points depending on how many you need to stack.
    VTacoma6[QUOTED] likes this.
  19. Feb 8, 2019 at 12:18 PM
    #9939
    dskakie
    dskakie Well-Known Member
    Dan
    Northern CA
    2016 TRD OR DCSB
    I’ll try and grab some pics if I remember but yeah I ran the wiring down the windshield (there’s a pretty perfect size channel my wire fit in) then yeah go through the firewall and on that left side you can use a plastic trim tool to pop out just the panel that has the small cubby and 3-4 switches including the blank. I think there are 4 to 6 plastic clips along the sides
  20. Feb 8, 2019 at 1:20 PM
    #9940
    VTacoma6
    Vince
    Florida
    Thanks for the info, I will search around the form and try to find pictures of where people did that. Sounds like it could look cleaner.
