PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. May 30, 2019 at 11:35 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Look up Jesse Rizzo on YouTube, his buddy in a red tacoma has it mounted the way you’re talking about. He has a standard deflector without the cutout and mounted his above his rack with the mounts the light bar came with
  2. May 30, 2019 at 11:44 AM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    I did some internet stalking and I think he actually has an ExtremeLEDS system mounted on top as well as in his front bumper.
    https://extremeledlightbars.com/extreme-series-amber-and-white-light-bars#/pageSize=4&orderBy=0
    I think it's a bit too wide for the prinsu slot.
    Matmo215[QUOTED] likes this.
  3. May 30, 2019 at 12:28 PM
    Johnny77
    Johnny77 Well-Known Member
    Dustin
    San Diego, CA
    2019 Silver Sky Tacoma TRD O/R
    Found his IG - looks like he's got his mounted like the picture I shared.
    I was able to find this guy on IG who has it mounted the way I want it. I've reach out to him to see how he's got it mounted. Hopefully he responds.
    https://www.instagram.com/p/BpZcz_nhRWR/?utm_source=ig_web_copy_link
  4. May 30, 2019 at 12:32 PM
    BEAR_KNIFE_FIGHT
    Alex
    Minnesota
    Dope, nice work. Keep me posted, that's the bar I am looking at as well.
  5. May 31, 2019 at 4:52 AM
    jarett92
    jarett92 Well-Known Member
    Jarett
    Raleigh, NC
    Anyone have any experience with mounting a 99" (or 2500mm) awning across the cab and shell racks? I've been thinking about how to account for the relative movement between the two racks...is that necessary or am I overthinking it? Searched a lot and can't seem to find anyone with that set up.
  6. May 31, 2019 at 5:13 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I would only attach a longer awning to either the shell or cab only; NOT both.
    RobP62 likes this.
  7. May 31, 2019 at 5:21 AM
    jaredc2306
    jaredc2306 Well-Known Member
    Jared
    San Antonio, Tx
    2016 ACLB TRD OR Quicksand
    I have the batwing awning and I use the standard prinsu mounts. I only have it mounted to the toprac. It hangs in front rack but it is not attached. I will see if I have any pictures of it. I don't leave it mounted all the time so I can't take a pic right now.
  8. May 31, 2019 at 5:22 AM
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    I mounted it across both... haven't seen any issues.
    If my bed and cab are moving so independently of each other that this causes an issue I likely have much bigger problems on my hands.
    I have had this awning mounted like this while having done multiple cross country trips off roading and rocking crawling through the Rockies, Moab, desert...etc and have had zero issues. I would think those scenarios would have tested it enough.
  9. May 31, 2019 at 5:26 AM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    My set up...
    Matmo215, BYJOSHCOOK and jaredc2306 like this.
  10. May 31, 2019 at 5:40 AM
    DarkMark340
    DarkMark340 @TRDLess_Taco
    Mark
    Jacksonville
    2011 Black 4x4 Tacoma DCSB Base
    SUSPENSION: 3” Factory/Toytec Lift Blackout14 Custom Leaf Pack 5+1 HD Bilstein 5100 B100 Shocks Wheelers Off-Road U bolt Flip kit w/ Timbren Bump stops BAMF HD Rear Shackle Hangers ARMOR: SOS Off-road Concepts Sliders SOS Off-road Concepts High Clearance Rear Bumper Pelfreybilt Front Bumper Full Hoop GEAR: Smittybilt X20 10K Synthetic Line Winch Leer 100XQ Prinsu CABRAC & TOPRAC Simple Outdoors Skyloft Hardshell RTT Pope Overland Expedition 72” Awning 18x9 VTX Off-road Bronze Terra CaliRaised LED Lights FUTURE PURCHASES: SOS Off-road Concepts Full Skid Plates Relentless Fabrication Tailgate Reinforcement ARB Twin Compressor w/ Locker
    You do know the bed and cab flex independently ever so slightly... Right? If you haven't had any issues yet I'm happy to hear it but just for an extreme example...
    https://www.youtube.com/watch?v=p1LO6uxy11I
    RobP62 likes this.
  11. May 31, 2019 at 5:49 AM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    they flex, i had a buddy who did this and he eventually ran into problems where the mounts would bend and the mounting holes wallowed out
  12. May 31, 2019 at 5:51 AM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    Ever so slightly.... well aware. So much so that I would have a problem with this set up... I doubt it. The mounts/materials/length of awning are not so rigid that it doesn't allow for slight flexing so I have not seen it be an issue through some pretty strenuous terrain. I have also simultaneously had a long Yakima cargo box mounted across the bed and cab on the same trips without issue.
  13. May 31, 2019 at 6:45 AM
    jarett92
    Jarett
    Raleigh, NC
    I can see the shell move maybe an inch left and right over bumps through my rear window (its not mounted to the bed rails, just using 4 clamps with the bed rails right now). Think its better to mount to both racks and use plenty of mounting points to secure it or only mount to one rack and leave nearly half of it cantilevered?
    Also thought about making a long plate to mount the awning to, so the plate adds rigidity rather than the back of the awning. Or making some sort of mount for the shell portion that would support the weight of the awning vertically, but allow for side to side movement with a bushing or something.
  14. Jun 2, 2019 at 2:56 PM
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    Does anyone know if the Prinsu awning brackets will work with their load panels? Thanks
    @CBI Offroad Fab
  15. Jun 2, 2019 at 9:20 PM
    dustxking
    dustxking Well-Known Member
    Just got Prinsu installed, picked it up for 200$ used. Its very good condition but is faded from over the years. I have a question about the slots in the cross bars, since mine is most likely a 1st gen prinsu, is there a way I can put the cut outs in the cross bars like the new generation that is fairly easy to do? Reason I ask is so I dont have to undo the bar to add in a insert every time I want to add something or remove something.
  16. Jun 2, 2019 at 9:41 PM
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    It’s an early 2nd gen model. 1st gen racks are smaller and wouldn’t fit. If you have a router you could probably put a metal cutting bit on there and try to make the hole
  17. Jun 2, 2019 at 10:15 PM
    Desert Dog
    Desert Dog Well-Known Member
    Los Gatos
    2007 DCSB
    Work in progress
    No need to modify the bars. Get the drop in T-Nuts described in the thread
    "How-to-add-accessories-to-rack-w-o-having-to-unbolt-crossbars-or-drill-access-holes". its further down on the Prinsu page
    I got some of these and found they are easy to install and just as easy to remove or move. They're a bit pricey at $1 each but worth the convivence and being stainless won't rust up on you
  18. Jun 3, 2019 at 4:18 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I'm thinking he meant "1st gen made by prinsu" not "made for 1st gen". The earlier ones didn't have the drilled slots, and even earlier used different cross bars.
    You can get a reamer for a drill and probably do it. It may be difficult to keep the bit centered though. If you have a drill press it will be much easier and you can use a normal drill bit that is large enough.
  19. Jun 3, 2019 at 7:32 AM
    olecoot
    olecoot Well-Known Member
    Dennis
    Northeast Fl.
    2021 TRD OFFROAD 4X4
    3 + 1 Pro Comp 285 Falkin Wildpeaks Bed Cap
    I can't seem to find any side rails for my cap rack so I may end up making some from scratch. Has anyone put a roller bar on the rear with bearings for sorta rolling stuff up and over ? Just curious.
  20. Jun 3, 2019 at 8:19 PM
    dustxking
    Anyone have a 1x1 for my 3rd gen. Shark fin in the way and all.
