PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Jan 9, 2020 at 11:26 PM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    Just joined the club. This thing is a lot sturdier than I expected. Think I’m going to do a paracord grab handle on each side.
    2013XSPX, BYJOSHCOOK, RobP62 and 2 others like this.
  2. Jan 9, 2020 at 11:49 PM
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Area in the pic looks familiar. DVNP?
    Are there certain mounts for the rotopax that mount to the extruded aluminum tubing? If so I should store my fuel and water on the roof of my shell.
  3. Jan 10, 2020 at 12:00 PM
    kylehorvath
    kylehorvath Well-Known Member
    Kyle
    Humboldt/Tuolumne/Stanislaus
    2007 Access Cab, 4x4
    Over GVWR and I keep adding more metal
    Yep, making our way out of Saline over to Racetrack... fun trip, especially when a disabled Lexus blocked the path!
    Rotopax makes a bunch of mounts, singles and doubles.
    The Rotopax are all 2 gallon containers that interlock on the bottom. The idea sounds cool, modular and EAF, but trying to lift up the two interconnected fuel packs evenly up and over the tight mounting brackets is a pain in the ass, and venting them flat is not possible.
    My waters are secured with the FuelPax Delux mount and are able to be lifted one at a time as the spacing is wide enough that I dont need to interlock the water packs. The fuel is mounted on the universal plate, with the RotoPax Lox mounts. They are interlocked then placed on the mounts. I may ditch this method if I get a swing out. I opted to get the HC rear and no swingout since I stealth camp in the back so often. But It makes more sense to have the fuel mounted upright where it can be vented. Not a problem in the winter in DV, but Utah and crossing the Sierra in the summer causes them to swell like a balloon.
    RobP62 and ETAV8R[QUOTED] like this.
  4. Jan 11, 2020 at 12:55 AM
    Clayton4x4
    Clayton4x4 Well-Known Member
    2024 DCLB TRD Off Road
    I haven't had time, or much sun, to take pics overlooking the sound, but I'm totally mobbing this mall.
    crossrifles, RobP62 and w.adventures like this.
  5. Jan 11, 2020 at 2:16 AM
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Any of you guys having issues with the side bolts seizing up and not allowing you to move the cross bars around?
    After 3 years, the bolts are stuck, and I had to cut off the bolt heads to remove the bars. Those button heads are too flimsy and all got stripped. Then the bars would be trashed at that point with the stuck and broken bolts.
    I should have swapped them out to hex head bolts.
    RobP62, AugustaTaco and geekhouse23 like this.
  6. Jan 11, 2020 at 3:54 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I had that issue a few years back. I lost one bar due to two seized bolts. I cut the heads off and trashed the bar. I got a new one and then went through every bolt and used anti-seize. I think one or two other bars and bolts are seized up but they're the bars that never move (one is for my lightbar and one is for my maxtrax mounting solution so it's not that big of a deal).
    Use anti-seize on every single bolt.
  7. Jan 11, 2020 at 8:28 AM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Good to know!
  8. Jan 11, 2020 at 8:28 AM
    w.adventures
    Nowheresville, SC
    Thanks for the heads up!
  9. Jan 11, 2020 at 11:49 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :rofl:
    Clayton4x4[QUOTED] likes this.
  10. Jan 11, 2020 at 11:52 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Thanks for the Pro tip Dr. Funker :thumbsup:
    geekhouse23[QUOTED] likes this.
  11. Jan 12, 2020 at 7:38 PM
    tundraconvert
    tundraconvert Well-Known Member
    Eric
    San Diego
    2017 White Tacoma DCLB TRD OR
    Question for you guys using 1/4” carriage bolts on the Prinsu:
    how much are you having to grind down the heads to fit into the channels?
    I went to work with the grinder and there isn’t much left and they still barely fit. Am I missing something?
    RobP62 likes this.
  12. Jan 12, 2020 at 7:42 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    I'd try different bolts. My 1/4" bolts from Home Depot and Lowes have play in the channels when they aren't tightened
    RobP62 likes this.
  13. Jan 12, 2020 at 7:43 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    That's insane. Mine from Home Depot fit with plenty of play. I just wish I could have gotten some 1/2" or 3/4" but all they had were 1" and up.
  14. Jan 12, 2020 at 7:43 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    This ^^^^^ for me too.
  15. Jan 12, 2020 at 7:48 PM
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    The 1/4" bolts I have are 1/2" long from both HD and Lowes
    RobP62[QUOTED] likes this.
  16. Jan 12, 2020 at 8:52 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Did you get SS Matthew?
  17. Jan 12, 2020 at 8:54 PM
    tundraconvert
    Eric
    San Diego
    Damn. I bought them from HD. Took me over 1/2 hour to grind them all down In order to fit.
    Are you guys saying you have found bolts that fit straight into the channels?
    RobP62 likes this.
  18. Jan 12, 2020 at 9:05 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    The standard chrome plated fine thread carriage bolts slide right in. Where you at in SD? I have a few extras.
    RobP62 and tundraconvert[QUOTED] like this.
  19. Jan 12, 2020 at 9:06 PM
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    I'm pretty positive they are steel. They may be SS but im not honestly not sure what they are. They haven't rusted at all.
  20. Jan 12, 2020 at 9:50 PM
    tundraconvert
    Eric
    San Diego
    I’m in University City. I work in Kearny Mesa. Looking for 4 eight now at about an inch long.
    That’s crazy, because the ones I bought are no where near fitting without serious grinding.
    Maybe it’s because I bought SS?
    RobP62 likes this.
