PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Jun 9, 2020 at 9:56 AM
    waytolatetothegame
    waytolatetothegame Well-Known Member
    James
    2016 Inferno Tacoma TRD OR
    Did you ever get a hardshell rrt on your setup? I currently have both the cabrack and toprack from prinsu on my truck. I just installed an iKamper Skycamp. I'm considered about the flex between the back rack and the cap rack. Just curious what you did. Thanks!
  2. Jun 11, 2020 at 6:40 AM
    InfernoMan
    InfernoMan Well-Known Member
    18 Tacoma Off Road - Inferno
    I just bought a prinsu rack. Quick question. Would you guys recommend drilling a hole through the rubber water guard or cutting it. I watched a youtube video of an install and the guy said you can do either method. He did the drill hole method but I am not sure that I would be as accurate as it would require.
    thanks
  3. Jun 11, 2020 at 7:26 AM
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    If you’re going for accuracy using a punch is the best method. You’ll have to flip the rubber over and cut out sections of a thin metal bar that runs the length of the rubber. Once you do that a leather lunch will go through it like butter. Definitely the most aesthetic solution.
  4. Jun 11, 2020 at 7:12 PM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
  5. Jun 12, 2020 at 2:34 AM
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    I had a roof near sandpiper on my toprack, for clearance I used 1x2 steel tubing between rack and tent base. No issues after that. 1” is all that’s really Usually needed.
  6. Jun 12, 2020 at 4:27 AM
    waytolatetothegame
    James
    I ended up going and getting anti-vibration rubber pads for air compressors and putting them on each crossbars where the tent bars touched. They work really well - add height and reduce the metal on metal wear/noise.
    ready6delta likes this.
  7. Jun 12, 2020 at 4:41 AM
    Hstone556
    Hunter
    Austin
    Sweet, i tried using a 1/2" plastic spacer but just needed a bit more height for when the truck was flexed out. It got annoying hearing the tent hit the cabrack on trails.
  8. Jun 12, 2020 at 8:54 AM
    Schlucki
    Schlucki Well-Known Member
    Rich
    North Dallas, TX
    2020 DCLB TRD OR 4X4 Cement Taco
    A growing list of stuff
    Does anyone have experience using a Prinsu top rack for transporting sheets of wood or drywall?
    My concern is that the sheets would be wider (48"-49") than the rack, and I would want to make sure that they can be secured well.
    Thanks!
  9. Jun 12, 2020 at 9:02 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I've done it plenty of times. No issues.
  10. Jun 12, 2020 at 9:13 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    I’ve done it a ton. Hell I’ve put 4 6x6 20ft long posts on top of my cab rack with no issues.
  11. Jun 12, 2020 at 1:49 PM
    Desert Dog
    Desert Dog Well-Known Member
    Los Gatos
    2007 DCSB
    Work in progress
    Just that much higher you need to lift the drywall. :rofl:
    In all honesty I have too many accessories already mounted to the rack so I still carry drywall in the bed, tallgate up with three 2x3s evenly spaced for support . Can get about 4 sheets before the snug top opening becomes too narrow for a 4 ft wide sheet
    Schlucki likes this.
  12. Jun 12, 2020 at 2:26 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Looks fantastic! Really great job! :thumbsup:
    ready6delta[QUOTED] and Schlucki like this.
  13. Jun 12, 2020 at 2:29 PM
    Schlucki
    Rich
    North Dallas, TX
    Good to know. It was mostly just about the width of the sheets.
    Holy crap. I thought I was bad with 12' poles.
    I will have zero permanently mounted accessories, so it will be wide open for whatever gear or crap to haul, and a good workout is good for you. (unless you throw your back out...)
  14. Jun 12, 2020 at 2:32 PM
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    Stuck out the over the hood and out the back of the truck:rofl:
    Schlucki[QUOTED] likes this.
  15. Jun 12, 2020 at 6:19 PM
    InfernoMan
    Do you know if that iKamper Skycamp would fit on the prinsu cabrack by itself? Without the toprack? I only have a cabrack and wondering if it would fit without purchasing a bed rack. Thanks.
  16. Jun 14, 2020 at 6:25 AM
    waytolatetothegame
    James
    I would say no to the Skycamp 4x, but the mini would fit.
    - Skycamp 4x is 160lbs and ~86” long
    - Skycamp mini is 125lbs and ~57” long
  17. Jun 14, 2020 at 6:46 AM
    EchoDeltaSierra
    EchoDeltaSierra Well-Known Member
    Georgetown, TX
    2020 TRD Off-Road
    Nitro 4.88 gears OME suspension ST/Maxx 255/85R16s
    I have what is likely a super-rookie question. Prinsu rack is successfully installed on my DCSB. I need a pair of traction boards in preparation for a beach. I'm gripped with indecision on which ones to order (either Maxtraxx or preferably RototraX) based on how to mount them. I want to mount the boards in a front-to-back orientation between a yet to be purchased driver side cargo box and my already installed passenger side awning.
    What mounting hardware is needed to accommodate this, and how is this positioned on the rack rails? I cannot seem to find what exactly would be require and a bit of guidance would be really appreciated.
    Thanks in advance.
    ready6delta and RobP62 like this.
  18. Jun 14, 2020 at 6:49 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Your cheapest option would be to us the Eye bolts that came with the rack, spread them as wide as the boards, and use bungee cords.
  19. Jun 14, 2020 at 10:11 AM
    Desert Dog
    Los Gatos
    2007 DCSB
    Work in progress
    Check out this link for some ideas under the Recovery Forum
    https://www.tacomaworld.com/threads/show-how-you-mount-your-traction-boards.480102/
  20. Jun 14, 2020 at 2:21 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Anyone have any luck adding longer bars to their Cabrac?
    might be carrying two canoes in the future and need 60+” bar widths.
