PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Nov 17, 2014 at 12:53 PM
    #1121
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Zack do the fairings come with a contour to the window or all straight? Say if I wanted it contoured with the window would that cost more? Believe im just going to buy the rack and modify with a light bar of my choice when funds allow
  2. Nov 18, 2014 at 7:25 AM
    #1122
    zscott
    zscott [OP] Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    If you have a preference. Let me know. I started doing the curved ones in hopes of reducing the wind noise a little more. After testing curved and straight that are the same size I have found no difference in wind noise. The straight versions are easier to keep in stock because I can have them sheared or cut with a saw vs. waiting for the laser cutter.
  3. Nov 18, 2014 at 7:29 AM
    #1123
    ThomasMore66
    Dallas/Fort Worth & Durango
    What is the noise level like?
  4. Nov 18, 2014 at 7:32 AM
    #1124
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Zero with the deflector on.
    Gets really bad without it on around 25-30 mph. That was when my brain couldn't figure out that the 2 aluminum, non-black anodized bars were for the deflector :eek: But I have it on all the time now.
  5. Nov 18, 2014 at 7:35 AM
    #1125
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Okay, so on the website with the white double cab in "recent news" with the fuel wheels has a standard rack w/ a contoured fairing?
  6. Nov 18, 2014 at 7:37 AM
    #1126
    ThomasMore66
    Curved or straight?
  7. Nov 18, 2014 at 7:40 AM
    #1127
    geekhouse23
    Straight? :notsure:
    When I ordered from Zach, I made no special requests for the deflector.
  8. Nov 18, 2014 at 7:40 AM
    #1128
    zscott
    Zach
    Utah
    I don't hear it at all, but my MT's are getting noisy as they wear. Pretty sure they conceal any other noises.
  9. Nov 18, 2014 at 7:45 AM
    #1129
    zscott
    Zach
    Utah
    Yes we put a contoured deflector on that one. The curve is so minor it is hard to tell on most of them unless you put a straight edge up there. Also, to answer your question, his is the standard rack with powdercoating.
  10. Nov 18, 2014 at 7:45 AM
    #1130
    zscott
    Zach
    Utah
    Looks like yours is probably contoured as well.
  11. Nov 18, 2014 at 7:48 AM
    #1131
    zscott
    Zach
    Utah
    They both look and function great, I have had a combination of both curved and straight on my truck at various times to test different ones out for differences.
  12. Nov 18, 2014 at 8:40 AM
    #1132
    JediNinja
    JediNinja I Give No F#$%!
    Nevada
    10' MGM DC TRD/OR 4x4
    Stuff
    Has anybody found a good shovel mount that works well with the rack? I'm currently looking and just curious if anyone has used one or found one that will work well.
  13. Nov 18, 2014 at 8:43 AM
    #1133
    zscott
    Zach
    Utah
    Mountain State Overland just bolted some quick fists to the crossbars and mounted their shovel that way.
  14. Nov 18, 2014 at 9:06 AM
    #1134
    JediNinja
    Nevada
    Stuff
    perfect thanks
  15. Nov 18, 2014 at 9:18 AM
    #1135
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    Zach has been one of the best people I've done business with. He was open to all my ideas and let me know from his experience what would work. My endless descriptions through PMs and emails didn't deter him from being patient and kind. I wish I had the pleasure of doing business in person but for now I'm stoked to support his company on my truck everyday. Thanx again Zach. And now the hard part of waiting for it to be fabbed and delivered starts :playball:
  16. Nov 18, 2014 at 9:24 AM
    #1136
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :woot:
    Bout time... :rolleyes:
  17. Nov 18, 2014 at 10:40 AM
    #1137
    loco
    loco Who wants to ride my Brack Burrito???
    Phil
    Virginia Beach, VA
    1996 Diesel Land Cruiser AKA Brack Burrito
    Well its a land Cruiser with a diesel so I've got that going for me.
    If you want secure you could easily mount a Pelfrey Bilt up there and have a secure axe and shovel mount also made of aluminum.
  18. Nov 18, 2014 at 6:18 PM
    #1138
    TheGreatPear
    TheGreatPear Well-Known Member
    Alex
    Gunsan, South Korea
    2013 DCSB TRD OR 4x4 V6 6 Speed
    Hey Zach, I think the "purchase" button on your site is broken. Its not working for me :notsure:
  19. Nov 18, 2014 at 6:39 PM
    #1139
    zscott
    Zach
    Utah
    It keeps popping up even when I remove it. Wix:rolleyes: The shopping cart feature of our site hasn't been setup yet. If you would like to order just send me an email and we can get it taken care of.
  20. Nov 18, 2014 at 6:45 PM
    #1140
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I explored the quick fist idea on the side of my cab and cap racks but the shovel will slip or spin lose and rub against your truck. The quick fist just does clamp down tight enough to hold the shovel with the blade perfectly vertical...hope that makes sense.
