PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Feb 19, 2015 at 6:50 AM
    #1501
    zscott
    zscott [OP] Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    No problem at all. You definitely have a nice solution that is hands down stronger than the standard tnuts from 80/20 and TSLOTS. That being said if I were just starting to setup my rack I certainly wouldnt hesitate to use the standard stuff. I guess I can't speak for the drop in tnuts but the economy slide in ones have held anything I have used them for (bike fork mount, pelican case full of gear, Rotopax full of fuel) just fine on a variety of trails and roads. Yes they could be improved As you have shown but they certainly are function as is.
  2. Feb 22, 2015 at 12:36 PM
    #1502
    omaguz
    omaguz Well-Known Member
    Omar
    Puerto Rico
    2016 4Runner Trail Edition, NON KDSS, Pirelli Scorpion's ATR 265/70/17 E Load, Canvas Back, BROG Built Roof Attic, Thule Roof Rack and a few other stuff!!!
    Hey Zach, sorry for not writing sooner, just to let you know the rack arrived and it is awesome. I did the initial install and I'm planning to finish tomorrow. Once again buddy thanks for your help!!!:D
  3. Feb 22, 2015 at 12:45 PM
    #1503
    BeaverYota
    BeaverYota Oregon State Edition
    Josh
    Lake St. Louis, MO
    Sold...
    I seriously want to get one of these. It's on my list
  4. Feb 22, 2015 at 1:51 PM
    #1504
    ThomasMore66
    Dallas/Fort Worth & Durango
    X2. Been on the list. Just have a few other things on the list ahead of it.
  5. Feb 22, 2015 at 2:05 PM
    #1505
    zscott
    Zach
    Utah
    Awesome. I saw that it had been delivered but was going to follow up just to make sure. One recommendation. Move the wind deflector down one setting on the holes along the angled part of the side rails. I have had some report a whistle at the setting you are showing it at, not all but some.
  6. Feb 22, 2015 at 2:14 PM
    #1506
    omaguz
    Omar
    Puerto Rico
    Will do, i'll send you pics once it has been mounted!!!
  7. Feb 23, 2015 at 9:35 AM
    #1507
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Working on a cover for the fairing Zach. This will sit on top of the aluminum fairing, and if everything goes right, it will light up nicely. :D
    I'm cutting 1/4" acrylic sheet on a laser table. The image is cut in reverse on the back of the sheet. I'll put a strip of color changing led's across the bottom. The parts that are just cut into the acrylic should light up.
  8. Feb 23, 2015 at 11:02 AM
    #1508
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    :popcorn:
  9. Feb 23, 2015 at 11:24 AM
    #1509
    SMKYTXN
    Nathan
    Houston
    DCFB
    I have the original image of the 2nd gen with a standard bed, so that's not an issue. I can convert practically any image for the covers.
    Can't use polycarbonate with the laser cutter. The fumes are poisonous, as in chlorine gas, which also destroys the laser. Don't wanna be the guy that does that.
  10. Feb 23, 2015 at 12:37 PM
    #1510
    SMKYTXN
    Nathan
    Houston
    DCFB
    Here are a couple of test shots. Still have to figure out the edge molding.
  11. Feb 23, 2015 at 12:54 PM
    #1511
    SMKYTXN
    Nathan
    Houston
    DCFB
    Hadn't thought about a glass shop. :thumbsup: I'll go see what I can find.
  12. Feb 23, 2015 at 3:24 PM
    #1512
    c0astie31
    c0astie31 TACO SUPREME
    Dennis
    Long Island ny
    2011 4Runner Trail Edition
    A LOT
    Any word on the 2010+ 4 runner rack?
  13. Feb 23, 2015 at 4:05 PM
    #1513
    zscott
    Zach
    Utah
    Should have some pics soon. The first ones are shipping out this week!
  14. Feb 24, 2015 at 4:38 PM
    #1514
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I wanted to share this to illustrate the sheer versatility of this product:
    Put my PrInSu racks to good use last week - picked up a bunch of 4'x10' sheets of mesh I had special ordered. Fork lifted the pallet right on top & with a few ratchet straps I was good to go. [​IMG]
    Click for full-size image (1024 x 768)
    Thanks again to Zach for an awesome product! :thumbsup:
    RileyLAFD likes this.
  15. Feb 24, 2015 at 4:58 PM
    #1515
    omaguz
    Omar
    Puerto Rico
    Finished the install today, but the weatherstrip was a pain in the ass. I opted to remove them completely until I can cut them to fit. The rack is just awesome Zach, Ill send some more pics tomorrow!!!:yay:
  16. Feb 24, 2015 at 6:39 PM
    #1516
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    I'd love to have one of these bad boys, but my "Taco mod fund" is tapped til the summertime. :( Subbed
  17. Feb 24, 2015 at 6:43 PM
    #1517
    Overkill07
    Overkill07 Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
    A few audio upgrades, tinted windows, remote start because it f'n hot in Texas! 6in Fabtech DB lift, 17x9 Fuel Trophy wheels, 315/70/17 Duratracs,BAMF 80in sliders w/kickout, Prinsu cab rack w/30in Heretic light bar, custom bedside decals, custom hi-lift jack brackets, US Offroad front bumper w/winch, bed rack with RTT, CB, Short wave base station, Ultra gauge, color matched grille surround, an ungodly amount of recover gear, ARB fridge, hood struts, RotoPax, traction pads.
    Not to hijack this thread but I would definitely be interested in buy such an item. :D
    :threadjacked:
  18. Feb 24, 2015 at 6:45 PM
    #1518
    Overkill07
    Overkill07 Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
    So what are the down falls to not re-installing the weather stripping/
  19. Feb 24, 2015 at 7:33 PM
    #1519
    zscott
    Zach
    Utah
    Not as good looking:notsure:
    I have had mine off on one side for about a year now with no ill effects. If you look really close, have OCD, or are tall and see the location regularly it might bother you. I am shorter so I don't see it unless I make an effort to look up there and usually don't have OCD too bad.
    It doesn't affect water proofing though.
  20. Feb 25, 2015 at 3:07 AM
    #1520
    omaguz
    Omar
    Puerto Rico
    I tried drilling a hole to make the spacers fit but it appears there is a metal strip in the middle of the weatherstrip that made the drill bit turn a bit sideways. In the end I was able to pass the biggest drill bit I had but the spacer wouldn't pass trough. It was close to 5:00pm so I ripped both strips and installed the rack without them. My buddy is bringing some sort of scissor to cut the strips as close to the spacers to keep it as factory looking as possible!!!:D
